查看: 3624|回复: 0
[LV工具模块] LabVIEW 2014 FPGA Module Win32Eng LabVIEW2014FPGA模块LVFPGA2014英文版
    12 小时前
  • 签到天数: 3843 天
    连续签到: 36 天
    发表于 2020-8-4 18:11:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    下载地址1:
    请注册登录视觉论坛会员,购买附件查看
    下载地址2:
    请注册登录视觉论坛会员,购买附件查看
    FPGA2014.txt (366 Bytes, 下载次数: 2, 售价: 10 圆)
    LabVIEW 2014 FPGA Module Readme
    Version 14.0.0
    June 2014
    This file contains important information about the LabVIEW FPGA Module, including installation instructions, known issues, and a partial list of bugs fixed for LabVIEW 2014 FPGA Module.
    FPGA Module System Requirements
    Supported FPGA Targets for FPGA IP Builder
    NI LabVIEW FPGA Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    The development computer is a PC or NI PXI/PXI Express system on which you install LabVIEW and the LabVIEW FPGA Module. You also can install the Xilinx compilation tools on your development computer to compile LabVIEW FPGA VIs locally. However, if the FPGA design or target requires more than 2 GB of memory, National Instruments recommends installing the Xilinx compilation tools on a separate computer. This computer is referred to as the remote compile worker.
    Refer to the support document at ni.com for more information about the NI hardware supported by each Xilinx compilation tool.
    Development Computer
    • LabVIEW 2014 Full or Professional Development Systems (32-bit)
    • 11 GB additional disk space
    • Memory1:
      • At least 4 GB of RAM for Virtex-6 and later2 FPGA targets
      • Windows 7 (32-bit)
      • Windows 7 (64-bit with 32-bit LabVIEW installed)
      • Windows Vista (32-bit)
      • Windows Vista (64-bit with 32-bit LabVIEW installed)
      • Windows XP Professional (Service Pack 3)
      • Windows Server 2003 R2 (32-bit)3
      • Windows Server 2008 R2 (64-bit with 32-bit LabVIEW installed)
      • Windows Server 2012 R2 (64-bit with 32-bit LabVIEW installed)
      Note: The LabVIEW 2014 FPGA Module does not support Windows 8 or Windows 8.1.
      Note: National Instruments recommends a 64-bit OS for the computer on which you install the Xilinx Compilation Tools.
    • FPGA device
    • Device driver software—To program most devices with the LabVIEW 2014 FPGA Module, install the NI-RIO 14.0 driver software. Refer to the hardware documentation for different requirements for a specific device.
    1Memory requirements vary according to both the FPGA target and the FPGA VI you create for that target. To determine your memory needs, monitor the memory usage of the xst.exe process in the Windows Task Manager.
    2You must use a 64-bit OS to address 4 GB of RAM.
    3The LabVIEW FPGA Module does not support the Windows Server non-R2 editions.
    If you install the FPGA Compile Farm Server on a separate computer, you can configure that computer to be a remote compile server. If you install the Xilinx Compilation Tools on a separate computer, you can configure that computer to be a remote compile worker.
    Refer to the Setting Up a Remote Compile Server or Compile Worker section of the LabVIEW FPGA Module Release and Upgrade Notes for information about setting up and using a local or remote compile server or compile worker. Refer to the support document at ni.com for more information about the NI hardware supported by each Xilinx compilation tool.
    The remote compile server must meet the following minimum system requirements:
    • 35 MB free disk space
    • 1 GB RAM
      • Windows 7 (32-bit or 64-bit)
      • Windows Vista (32-bit or 64-bit)
    • Web browser for accessing compile job queues via the NI Web-based Configuration & Monitoring Service FPGA Compile Farm Console
    Each computer that you want to use as a compile worker must meet the following minimum system requirements:
    • 11 GB of disk space for the complete set of Xilinx compilation tools
      • Windows XP Professional (32-bit or 64-bit)
      • Red Hat Enterprise Linux 6.3
    You can install all of your LabVIEW products—including the FPGA Module, FPGA Compile Farm Server, and FPGA IP Builder—using the LabVIEW 2014 Platform media. You can find installation instructions for the FPGA Module along with activation instructions in the following locations:
    • LabVIEW FPGA Module Release and Upgrade Notes, which are available online at ni.com/manuals as well as on the LabVIEW 2014 Platform media.
    • LabVIEW 2014 Installation Guide, which is available in your FPGA Module software kit.
    To request additional LabVIEW 2014 Platform media, refer to the National Instruments website.
    FPGA IP Builder supports only a subset of FPGA targets. Refer to the National Instruments website for a list of supported targets.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the FPGA Module.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2014 FPGA Module. This is not an exhaustive list of issues fixed in the current version of the LabVIEW 2014 FPGA Module. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    467926ERROR:Place:1136 - This design contains a global buffer instance driving a non-clock load (Not a recommended design for Spartan-6 targets).
    461748579x Streaming Tx example Code Generation Errors for 5793 with 7975R.
    442452Clock Selection Window doesn't allow me to choose a clock.
    441704Built-in FIFOs Error in LabVIEW FPGA Co-simulation.
    440269FPGA Bitfile causes filename error, throws LabVIEW into unrecoverable state.
    438611Open Dynamic Bitfile Reference (ODBR) yields a bad reference but no error when inside a loop.
    438368[Sampling Probes] Multiple reruns of a VI quickly cause errors and hang of sampling probe watch window.
    436905"Bind FPGA host reference to type definition" overwrites ctl file without any warning.
    432892Regeneration of support files for Xilinx CoreGen fails when LabVIEW version is changed.
    428544FPGA Compile translation step in 2013 adds over 2 hours to compilation time from 2011.
    412592Cannot run FPGA VI in interactive mode (run button doesn't do anything) if LabVIEW Default Directory has been modified.
    412467Handshake Primitives won't simulate in Dynamic Dispatch VIs.
    411611DSP48E Slices cec does not behave correctly in simulation.
    401588Unsupported Control Type in a diagram disable structure causes internal compilation error.
    393669Switching input order on FPGA Timed Loop causes compile error.
    389331Spartan-6 BRAM items use more resources than necessary.
    381497Simulation behavior doesn't match hardware with indicator and local Read inside SCTL.
    380249Access violation crash when compiling converted 1D LUT FPGA express VI.
    367915Incorrect DMA Write node behavior with implicit enable removal.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the LabVIEW 2014 FPGA Module.
    For more information about automating the installation of NI products, refer to the following articles on ni.com:
    The National Instruments LabVIEW FPGA Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of the LabVIEW FPGA Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2003–2014 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    \National Instruments\LabVIEW 2014\FPGA\Legal\
    The Python_2.5_notice.pdf file contains a third-party copyright notice for third-party components used by certain FPGA Module features. The following directory is the default installation location for the file, but the location might vary depending on the configuration of the local computer:
    Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on National Instruments trademarks. Xilinx® is a registered trademark of Xilinx, Inc. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    GMT+8, 2026-4-1 12:54
