查看: 2471|回复: 0
[LV工具模块] LabVIEW 2013 SP1 FPGA Module Win32Chn LabVIEW2013SP1FPGA模块LVFPGA2013SP1中文版
    7 小时前
  • 签到天数: 3528 天
    发表于 2020-8-4 18:06:51 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    FPGA2013SP1CHN.txt (275 Bytes, 下载次数: 0, 售价: 10 元)
    校验和
    MD5: 5d2d935f0a7ed8a53d48bbb0e11546c6
    SHA1: 4df28973dfafc28cc6e6ee6053334265186bf3be
    SHA256: ac83c2e9cde89d64716529df8a2692e69199585d0838c9d0f2bf98746aaf93af
    CRC32: 65ac3de8
    LabVIEW 2013 SP1 FPGA Module Readme
    Version 13.0.1
    December 2013
    This file contains important information about the LabVIEW FPGA Module, including installation instructions, known issues, and a partial list of bugs fixed for LabVIEW 2013 SP1 FPGA Module.
    NI LabVIEW FPGA Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    Important Information
    The development computer is a PC or NI PXI/PXI Express system on which you install LabVIEW and the LabVIEW FPGA Module. You can use this computer to compile FPGA VIs, but if the FPGA design or target requires more than 2 GB of memory, National Instruments recommends installing the LabVIEW FPGA compilation tools on a separate computer. This computer is referred to as the remote compile server.
    Development Computer
    • LabVIEW 2013 SP1 Full or Professional Development Systems (32-bit)
    • 11 GB additional disk space
    • Memory1:
      • At least 4 GB of RAM for Virtex-6 and later2 FPGA targets
      • Windows 7 (32-bit)
      • Windows 7 (64-bit with 32-bit LabVIEW installed)
      • Windows Vista (32-bit)
      • Windows Vista (64-bit with 32-bit LabVIEW installed)
      • Windows XP Pro (Service Pack 3)
      • Windows Server 2003 R2 (32-bit)3
      • Windows Server 2008 R2 (64-bit with 32-bit LabVIEW installed)
      • Windows Server 2012 R2 (64-bit with 32-bit LabVIEW installed)
      Note: The LabVIEW 2013 SP1 FPGA Module does not support Windows 8 or Windows 8.1.
    • FPGA device
    • Device driver software—To program most devices with the LabVIEW 2013 SP1 FPGA Module, install the NI-RIO 13.1 driver software. Refer to the hardware documentation for different requirements for a specific device.
    1Memory requirements vary according to both the FPGA target and the FPGA VI you create for that target. To determine your memory needs, monitor the memory usage of the xst.exe process in the Windows Task Manager.
    2You must use a 64-bit OS to address 4 GB of RAM.
    3The LabVIEW FPGA Module does not support the Windows Server non-R2 editions.
    You can install all of your LabVIEW products—including the FPGA Module–using the LabVIEW 2013 SP1 Platform DVDs. You can find installation instructions for the FPGA Module along with activation instructions in the following locations:
    • LabVIEW FPGA Module Release and Upgrade Notes, which are available in your FPGA Module software kit or online at ni.com/manuals.
    • LabVIEW 2013 SP1 Installation Guide, which is available in your LabVIEW software kit.
    • LabVIEW 2013 SP1 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    • Activation Instructions for National Instruments Software, which are available on the LabVIEW installation media.
    To request additional LabVIEW 2013 SP1 Platform DVDs, refer to the National Instruments website.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the FPGA Module.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2013 SP1 FPGA Module. This is not an exhaustive list of issues fixed in the current version of the LabVIEW 2013 SP1 FPGA Module. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    ID
    Fixed Issue
    413898Coercion dots on Invoke Methods cause LabVIEW to require saving without any code changes.
    418820Desktop Execution node does not recognize controls inside a tab control.
    421382While loops with loop timer can overflow waveform type and cause graph control draw to hang.
    421717[Sampling Probes] Sampling sources on while loops in the FPGA context can hang the VI's execution.
    421750[Sampling Probes] Multiple reruns of the VI with sampling probes can cause a loss of waveform graph formatting.
    422537[Sampling Probes] Placing a sampling probe under the FPGA sampling source when the FPGA VI is free running can cause LabVIEW to crash.
    422548LabVIEW can crash if Open Dynamic Bitfile Reference node is used under certain circumstances.
    424257Reentrancy settings of some FPGA VIs causing poor performance with FPGA project load and memory usage.
    425084[Linear Algebra] Matrix Transpose function is showing wrong Throughput information in the context help.
    426585Configuring a memory project item while the FPGA VI using the memory is not open causes the memory to not take the project item changes.
    427033Using <+-,32,16> fixed point values in the LabVIEW 2013 FPGA Module can cause VI corruption.
    431290FIFO datatype may not be updated properly.
    435147Data corruption issue for a To FXP conversion on FPGA.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the LabVIEW 2013 SP1 FPGA Module.
    The National Instruments LabVIEW FPGA Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of the LabVIEW FPGA Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2003–2013 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    \National Instruments\LabVIEW 2013\FPGA\Legal\
    The Python_2.5_notice.pdf file contains a third-party copyright notice for third-party components used by certain FPGA Module features. The following directory is the default installation location for the file, but the location might vary depending on the configuration of the local computer:
    Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on National Instruments trademarks. Xilinx® is a registered trademark of Xilinx, Inc. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    GMT+8, 2025-4-29 15:26
