查看: 3580|回复: 0
[NI软件产品] NI VeriStand 2011SP1 Win32Eng PC版完整版及运行版NIVS2011SP1
  • 签到天数: 3829 天
    连续签到: 22 天
    发表于 2020-7-24 23:53:33 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    请注册登录视觉论坛会员,购买附件查看
    VS2011SP1.txt (254 Bytes, 下载次数: 2, 售价: 10 圆)
    NI VeriStand 2011 SP1 Readme
    May 2012
    This file contains important information about NI VeriStand 2011 SP1, including system requirements and installation instructions.
    Simulation Models
    Real-Time Targets
    .NET
    NI VeriStand is configuration-based testing software, allowing you to develop, prototype, and test control systems using hardware I/O and your simulation models. The NI VeriStand software framework enables you to perform real-time or PC-based test configuration and execution that can be easily customized and extended with LabVIEW, NI TestStand, and other software tools.
    NI VeriStand includes a run-time editable user interface as well as a test manager you can use to configure and implement triggered multi-file data logging, real-time test sequencing, stimulus generation and playback, and model calibration.
    You can run the NI VeriStand installer on the following operating systems:
    NI VeriStand runs as a 32-bit application on all operating systems.
    NI VeriStand does not support Windows 2000/NT/Me/98/95, Windows XP x64, Windows XP Service Pack 1, or the Windows Server non-R2 editions.
    Simulation Models
    To configure and run a simulation using your existing compiled model, you need only NI VeriStand installed.
    To develop a model using The MathWorks, Inc. Simulink® application software, you must be a licensed user of and have the following software installed on the host computer:
    • The MathWorks, Inc. MATLAB® software (the 32-bit version) and The MathWorks, Inc Simulink® application software release 14.x, 2006a, 2006b, 2007a, 2007b, 2008a, 2008b, 2009a, 2009b, 2010a, 2010b, or 2011a (the 32-bit version).
    Note  NI VeriStand does not support the 64-bit versions of the MathWorks, Inc. MATLAB® software or The MathWorks, Inc Simulink® application software.
    To compile a model developed using The MathWorks, Inc. Simulink® application software for use on a Microsoft Windows or LabVIEW Real-Time Target, you must be a licensed user of and have the following software installed on the host computer:
    • The MathWorks, Inc. Real-Time Workshop® (Simulink Coder®) software release 14.x, 2006a, 2006b, 2007a, 2007b, 2008a, 2008b, 2009a, 2009b, 2010a, 2010b, or 2011a.
    For deploying a compiled model to a LabVIEW Real-Time target, the following compilers are tested and supported:
    • Microsoft Visual C++ 6.0, .NET 2003, 2005 (Professional or Express), or 2008 (Professional or Express)
    Refer to the LabVIEW Real-Time documentation and The MathWorks, Inc Simulink® application software documentation for your installed version for more detailed information about Microsoft Visual C++ support. You also can refer to the KnowledgeBase on ni.com for more information about NI VeriStand version compatibility.
    To develop a model and convert it into a compiled model using other modeling environments, contact your model vendor for requirements.
    Real-Time Targets
    To run a simulation on a real-time (RT) target, the target must have NI VeriStand installed. You can install software on the target using Measurement & Automation Explorer (MAX). The RT target must meet the following minimum system requirements:
    • PXI controller/desktop PC with at least 256 MB of RAM or a CompactRIO/Single-Board RIO with at least 128 MB of RAM
    To create custom devices, menu items, workspace controls and indicators, or timing and sync devices, you must have LabVIEW 2011 or 2011 SP1 installed.
    Note The LabVIEW functionality in NI VeriStand always requires like-numbered versions.
    .NET
    The NI VeriStand .NET APIs require the following Microsoft software:
    • Microsoft .NET Framework 3.5 SP1, which uses Microsoft .NET Common Language Runtime (CLR) 2.0
    • A .NET environment capable of interacting with .NET Framework 3.5 based assemblies, such as Microsoft Visual Studio 2008 SP1 or LabVIEW 2011
    Complete the following steps to install NI VeriStand.
    • Some virus detection programs interfere with the installer. Disable any automatic virus detection programs before you install. After installation, check your computer for viruses and enable any virus detection programs you disabled.
    • (Optional) To use LabVIEW with NI VeriStand, install the like-numbered version of LabVIEW on the host computer.
    • Insert the NI VeriStand installation media and follow the instructions that appear on the screen.
    • Install the NI-DAQmx driver software from the NI Device Drivers DVD or any NI DAQmx driver DVD.
    Note The NI-DAQmx driver software is required to deploy a system definition to any platform, including the localhost running Windows.
    • (Optional) If using NI-XNET, insert the NI-XNET installation media and follow the instructions that appear on the screen.
    • (Optional) Activate NI VeriStand when prompted by the installer, or activate at a later time using the NI License Manager.
    Updates and Notifications
    National Instruments releases critical software updates after product release using the NI Update Service. Visit ni.com/info and enter updates to view a list of all currently available updates.
    National Instruments provides notification of certain critical issues at install time. Visit ni.com/info and enter notifications to view a list of current product notifications.
    NI VeriStand includes the following documentation resources:
    ResourceContentsAccess Instructions
    NI Veristand HelpConceptual, how-to, and reference information for using NI VeriStand.In software: Help»Search the NI VeriStand Help
    OR
    Windows Start menu: All Programs»National Instruments»NI VeriStand»VeriStand Help
    NI VeriStand .NET API HelpReference information for the .NET APIs included with NI VeriStand. You can access these assemblies from any .NET-compatible programming language or environment, including NI LabVIEW™ and NI TestStand™.Windows Start menu: All Programs»National Instruments»NI VeriStand»VeriStand .NET API Help.
    Using the NI VeriStand Model FrameworkInformation about how to use the NI VeriStand Model Framework to compile your existing C and C++ model code so you can load your models in NI VeriStand. You can access this guide from the .\xxx\ModelInterface\custom directory, where xxx is the directory you specified when you installed the NI VeriStand Model Framework.
    Note You must explicitly select NI VeriStand Model Framework when you run the NI VeriStand installer. It does not install by default.
    Note If you install NI VeriStand with the compatible version of LabVIEW, you also can access a subset of the NI VeriStand Help, including information about the NI VeriStand VIs and extending NI VeriStand functionality with LabVIEW, from the LabVIEW Help. From the pull-down menu in LabVIEW, select Help»LabVIEW Help.
    NI VeriStand includes several types of examples:
    • NI VeriStand Project—An example NI VeriStand project, including related items such as a system definition, a Workspace screen file, compiled models, and NI-XNET files, are located in the <;Public Documents>\National Instruments\NI VeriStand\Projects\Example directory.
    • Stimulus Profile Editor—NI VeriStand Stimulus Profile Editor examples are located in the <;Public Documents>\National Instruments\NI VeriStand\Examples directory.
      Tip On Windows 7/Vista, the default location of the <;Public Documents> directory is C:\Users\Public\Public Documents.
    • LabVIEW API—LabVIEW examples that use the NI VeriStand API are located in the <;Program Files>\National Instruments\LabVIEW 2011\examples\NI Veristand directory.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in NI VeriStand 2011 and 2011 SP1.
    The following items are the IDs and titles of a subset of issues fixed in NI VeriStand 2011 SP1. This is not an exhaustive list of issues fixed in the current version of NI VeriStand. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    297664Memory leak when opening and closing the Workspace window repeatedly
    314089A profile is editable by drag/drop while it is running
    315109System Explorer gives Error 1430 when you try to close it from the Parameters or Signals configuration page
    316701Alarm Command procedure on the second target only allows selecting alarm from first target
    317821The Fault function in a real-time sequence does not completely fault the channel
    319336Converting a VI to a .lvmodel file fails if the VI was last saved in a version of LabVIEW older than 2011
    320477Selecting File»Save As from an existing stimulus profile produces exception
    320604Cannot programmatically set model inport and outport default values
    321434Imported model information and rate are not correct in NI VeriStand 2011
    322684Real-time sequence expressions do not allow constant values of 10^10 and greater
    323469Incorporate definitions for Stimulus Profile Editor and Real-Time Sequences in the NI VeriStand Help
    325080Cyclic CAN Frames are sent with 1 ms rate regardless of what is dictated in the XNET database
    327030Disable variable does not disable frames in legacy NI-CAN devices
    328143File path dialog error in the Stimulus Profile Editor when trying to create a new log file
    328974Raw frame logging does not log LIN and FlexRay frames
    328975Bus monitor does not show LIN frames
    329328Maximum convert clock setting is not applied when selected
    329713Triggered XNET frame is sent the very first time without respecting the default value of the signal
    331647TDMS logs have non-standard and inconsistent unit definitions
    335859Inports and outports do not get imported if their paths are too long
    338386Sequence with undeclared variables do not show errors in the Stimulus Profile Editor but fails to compile
    341766NI VeriStand crashes during undeploy with CloseOperation.cpp error
    You also can refer to the National Instruments Web site to view a list of issues fixed in the previous release of NI VeriStand.
    © 2009-2012 National Instruments. All rights reserved.
    MATLAB®, Real-Time Workshop®, and Simulink® are registered trademarks of The MathWorks, Inc.
    GMT+8, 2026-3-18 09:30
