查看: 3636|回复: 0
[Patch补丁] NI VeriStand 2010f3Patch Win32Eng PC版完整版及运行版NIVS2010f3补丁
    半小时前
  • 签到天数: 3829 天
    连续签到: 22 天
    发表于 2020-7-24 23:36:41 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    安装该补丁前请先安装VERISTAND2010
    NI VeriStand 2010 Win32Eng PC版完整版及运行版
    http://visionbbs.com/thread-24453-1-1.html
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    请注册登录视觉论坛会员,购买附件查看
    VS2010f3patch.txt (253 Bytes, 下载次数: 0, 售价: 1 圆)
    NI VeriStand 2010 Readme
    August 2010
    This file contains important information about NI VeriStand 2010, including system requirements and installation instructions.
    Migrating from NI VeriStand 2009 to 2010
    NI VeriStand is configuration-based testing software, allowing you to develop, prototype, and test control systems using hardware I/O and your simulation models. The NI VeriStand software framework enables you to perform real-time or PC-based test configuration and execution that can be easily customized and extended with LabVIEW, NI TestStand, and other software tools.
    NI VeriStand includes a run-time editable user interface as well as a test manager you can use to configure and implement triggered multi-file data logging, real-time test sequencing, stimulus generation and playback, and model calibration.
    You can run the NI VeriStand installer on the following operating systems:
    • Windows XP (32-bit)
    NI VeriStand runs as a 32-bit application on all operating systems.
    NI VeriStand does not support Windows 2000/NT/Me/98/95, Windows XP x64, or the Windows Server non-R2 editions.
    To configure and run a simulation using your existing compiled model, you need only NI VeriStand installed. To develop a model and convert it into a compiled model using The MathWorks, Inc. Simulinkо application software, you must be a licensed user of and have the following software installed on the host computer:
    • The MathWorks, Inc. MATLABо software and The MathWorks, Inc Simulinkо application software release 14.x, 2006a, 2006b, 2007a, 2007b, 2008a, 2008b, 2009a, 2009b, or 2010a
    • The MathWorks, Inc. Real-Time Workshopо software release 14.x, 2006a, 2006b, 2007a, 2007b, 2008a, 2008b, 2009a, 2009b, or 2010a
    • Microsoft Visual C++ 6.0, .NET 2003, 2005 (Professional or Express), or 2008 (Professional or Express)
    To develop a model and convert it into a compiled model using other modeling environments, contact your model vendor for requirements.
    To create custom devices, menu items, workspace controls and indicators, timing and sync devices, or Stimulus Profile Editor headers, you must have LabVIEW 2010 installed.
    To run a simulation on a real-time (RT) target, the target must have NI VeriStand installed. You can install software on the target using Measurement & Automation Explorer (MAX). The RT target must meet the following minimum system requirements:
    • PXI controller/desktop PC with at least 256 MB of RAM or a cRIO/sbRIO with at least 128 MB of RAM
    • LabVIEW 2010 Real-Time Module
    Complete the following steps to install NI VeriStand.
    Note  Some virus detection programs interfere with the installer. Disable any automatic virus detection programs before you install. After installation, check your computer for viruses and enable any virus detection programs you disabled.
    • Insert the NI VeriStand installation media and follow the instructions that appear on the screen.
    • (Optional) Activate NI VeriStand when prompted by the installer, or activate at a later time using the NI License Manager.
    • (Optional) If using NI-XNET, insert the NI-XNET installation media and follow the instructions that appear on the screen.
    Search the KnowledgeBase for information about installation order if you are using NI TestStand or LabVIEW with NI VeriStand.
    The .rig, .in4, .et1, and .et2 file formats are no longer supported in NI VeriStand 2010. Use the mutation tool, available in the Tools menu of the Getting Started window, to mutate your files to the current version. Refer to the NI VeriStand Help for information on new file formats in NI VeriStand 2010.
    The .NET API no longer supports the Run Workspace File function (the Run Workspace File VI if you are using the LabVIEW API). Use the Connect to System function (the Connect to System VI in LabVIEW) instead.
    Refer to the NI VeriStand Help, accessible by selecting Help»Search the NI VeriStand Help from the pull-down menu in NI VeriStand.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in NI VeriStand 2010.
    Refer to the National Instruments Web site to view a list of issues fixed in NI VeriStand 2010.
    © 2010 National Instruments Corporation. All rights reserved.
    NI VeriStand, LabVIEW, National Instruments, NI, ni.com, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the Trademark Information at ni.com/trademarks for other National Instruments trademarks.
    MATLABо, Real-Time Workshopо, and Simulinkо are registered trademarks of The MathWorks, Inc.
    Only Licensed Use is Permitted
    You are only permitted to use this product in accordance with the accompanying license agreement. All rights not expressly granted to you in the license agreement accompanying the product are reserved to NI. Further, and without limiting the forgoing, no license or any right of any kind (whether by express license, implied license, the doctrine of exhaustion or otherwise) is granted under any NI patents or other intellectual property right of NI with respect to any other product(s) of NI or of anyone else (including without limitation, the MATLAB, Simulink and or the Real-Time Workshop software of The MathWorks, Inc.), including without limitation, the right to use any of these other products. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction.
    GMT+8, 2026-3-18 09:26
