查看: 3578|回复: 0
[LV工具模块] LabVIEW 2009SP1 Unit Test Framework Toolkit Win32Eng LabVIEW单元测试框架工具包UTF2009SP1
    12 小时前
  • 签到天数: 3843 天
    连续签到: 36 天
    发表于 2020-7-24 00:29:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW单元测试框架工具包可自动执行LabVIEW VI单元测试,帮助您轻松进行功能验证。
    LabVIEW单元测试框架工具包是一个LabVIEW附加软件,可帮助您自动完成功能验证,并验证应用程序是否正常运行。您可以生成单元测试或者导入使用Microsoft Excel等编辑器创建的文本文档里的测试参数。测试可包含多种测试用例,这些用例决定了各种数据类型(包括数组和簇) 的输入值和预期输出。您将可识别错误输出的来源、跟踪代码覆盖率,并生成HTML、ATML/XML或ASCII格式的验证文档。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版与ZIP版内容一样,EXE版为NI当年发行版,ZIP版为NI后期重新压制的版本。EXEt版:
    ZIP版:
    EXE版:
    请注册登录视觉论坛会员,购买附件查看
    ZIP版:
    请注册登录视觉论坛会员,购买附件查看
    UTF2009SP1.txt (568 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2009 SP1 Unit Test Framework Toolkit Readme
    Version 9.0.1
    December 2009
    This file contains information to introduce you to the LabVIEW Unit Test Framework Toolkit. This file also provides you with help resources you can use while working with the Unit Test Framework Toolkit. The file contains the following information that you need to understand.
    New Features and Changes
    The LabVIEW 2009 SP1 Unit Test Framework Toolkit is the upgrade version of the LabVIEW Unit Test Framework Toolkit 1.0. The Unit Test Framework Toolkit provides interactive tools you use to create, configure, manage, and execute tests that check VIs for functional correctness.
    • Improvements to using setup and teardown VIs and the Test Properties dialog box to test LabVIEW class objects, images, and refnums.
      • You can pass parameters into setup VIs. Configure the input values on the Test Cases page of the Test Properties dialog box.
      • You can evaluate the outputs of teardown VIs. Configure the expected output values on the Test Cases page of the Test Properties dialog box.
    • You can run tests of all child classes that make up a LabVIEW class.
    The computer you are using must meet the minimum system requirements to run the Unit Test Framework Toolkit:
    • Windows 7/Vista/XP/2000
    • A minimum of 32 MB free of disk space
    • LabVIEW 2009 Service Pack 1 (SP1) Development System
    Note: National Instruments is committed to maintaining compatibility with Microsoft Windows technology changes. However, NI has become aware of a number of issues of potential significance regarding Microsoft Windows 7. To learn how Windows 7 affects your use of NI products, visit ni.com/info and enter the Info Code windows7.
    You can install all of your LabVIEW products—including the Unit Test Framework Toolkit—using the LabVIEW 2009 SP1 Platform DVDs. You can find installation instructions for the Unit Test Framework Toolkit along with activation instructions in the following locations:
    • LabVIEW 2009 Service Pack 1 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2009 SP1 Platform DVDs, refer to the National Instruments Web site.
    Refer to the LabVIEW Help, accessible by selecting Help»Search the LabVIEW Help from the pull-down menu in LabVIEW, for information about the Unit Test Framework Toolkit.
    LabVIEW examples for the Unit Test Framework Toolkit are located in the labview\examples\Unit Test Framework folder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the Unit Test Framework Toolkit.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW Unit Test Framework Toolkit. If you have a bug ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the Unit Test Framework Toolkit.
    Bug IDFixed Issue
    129118Wrong filter configuration does not always give a warning message
    141551Saving and loading date/time values causes a 1 hour difference in some situations
    134676Shared Variable does not get highlighted when a test fails
    134474Unit Test Framework Results window does not show pass/fail info for test repetitions
    137169Aborting test execution does not work for user-defined test VIs with infinite loops
    137607HTML report does not contain the error detail information
    135602Controls with the same name on the front panel are not supported for a VI under test
    138166"Find VI" does not work after creating a new test in auto populating folder
    137827Array Range (Limit Array) comparison type does not work for enum arrays
    138374Checking whether setup or teardown VIs have duplicate control names
    138800Tests fail for subroutine priority VIs
    138801User defined test VI default folder isn't relative to the VI or project
    138802Dimension index not visible for array controls when using big font size
    136833Errors that occur in user-defined tests do not appear in the Unit Test Framework Results window
    138575Unit Test Framework Results window does not show up in Windows taskbar
    138423The Run Tests from File VI produces load conflicts when the library names collide
    138194Unit Test Framework will hang if two controls in a cluster on the front panel of a target VI have the same name
    137011Unchecked outputs are checked after importing values from VI
    140508Cannot drag lvtest files into lvlib
    133136Test Properties dialog box does not show up on the Windows taskbar
    176574Unit Test Framework crashes LabVIEW when user loads certain NI SoftMotion axis interface
    Important Information
    © 2009 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-4-1 12:19
