查看: 3256|回复: 0
[LV工具模块] LabVIEW 2017 Unit Test Framework Toolkit Win32Eng LabVIEW单元测试框架工具包UTF2017
  • 签到天数: 3843 天
    连续签到: 36 天
    发表于 2020-7-24 00:08:42 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    UTF2016版开始,支持64位的LabVIEW,即有UTF2016-64bit的版本。
    LabVIEW单元测试框架工具包可自动执行LabVIEW VI单元测试,帮助您轻松进行功能验证。
    LabVIEW单元测试框架工具包是一个LabVIEW附加软件,可帮助您自动完成功能验证,并验证应用程序是否正常运行。您可以生成单元测试或者导入使用Microsoft Excel等编辑器创建的文本文档里的测试参数。测试可包含多种测试用例,这些用例决定了各种数据类型(包括数组和簇) 的输入值和预期输出。您将可识别错误输出的来源、跟踪代码覆盖率,并生成HTML、ATML/XML或ASCII格式的验证文档。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版与ZIP版内容一样,EXE版为NI当年发行版,ZIP版为NI后期重新压制的版本。
    EXE版:
    链接: 请注册视觉论坛用户,登录后购买附件下载查看,充值请联系在线客服提取码: 请注册登录视觉论坛会员,购买附件查看
    ZIP版:
    EXE版:
    请注册登录视觉论坛会员,购买附件查看
    ZIP版:
    请注册登录视觉论坛会员,购买附件查看
    UTF2017.txt (536 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2017 Unit Test Framework Toolkit Readme
    March 2017
    This file contains important information about the LabVIEW 2017 Unit Test Framework Toolkit, including system requirements, installation instructions, known issues, and a partial list of bugs fixed for this release.
    The Unit Test Framework Toolkit provides interactive tools to create, configure, manage, and execute tests that check VIs for functional correctness.
    In addition to the system requirements for the LabVIEW Development System, the Unit Test Framework Toolkit has the following requirements:
    • LabVIEW 2017 Base, Full, or Professional Development System
    • At least 64 MB of disk space
    Note  The LabVIEW 2017 Professional Development System license activates the LabVIEW 2017 Unit Test Framework Toolkit.
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2017.
    The Unit Test Framework Toolkit supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2016 the Unit Test Framework Toolkit dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2017 Unit Test Framework Toolkit will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2017 Unit Test Framework Toolkit to an unsupported OS. Additionally, after installing the LabVIEW 2017 Unit Test Framework Toolkit, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    You can install all of your LabVIEW products—including the Unit Test Framework Toolkit—using the LabVIEW 2017 Platform media.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in LabVIEW 2017 Unit Test Framework Toolkit.
    The following item is the ID and title of a subset of issues fixed in the Unit Test Framework Toolkit. This is not an exhaustive list of issues fixed in the current version of the Unit Test Framework Toolkit. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    601133VIs with special characters in a control's label cannot be loaded in a blank .lvtest created from the "My Computer" project item
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Unit Test Framework Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»Unit Test Framework folder to access the example. You also can find the examples for the Unit Test Framework Toolkit Toolkit in the labview\examples\Unit Test Framework directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    © 2008–2017 National Instruments. All rights reserved.
    375338C-01
    GMT+8, 2026-4-1 10:46
