查看: 3374|回复: 0
[LV工具模块] LabVIEW 2014 Unit Test Framework Toolkit Win32Eng LabVIEW单元测试框架工具包UTF2014
  • 签到天数: 3843 天
    连续签到: 36 天
    发表于 2020-7-23 23:48:44 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW单元测试框架工具包可自动执行LabVIEW VI单元测试,帮助您轻松进行功能验证。
    LabVIEW单元测试框架工具包是一个LabVIEW附加软件,可帮助您自动完成功能验证,并验证应用程序是否正常运行。您可以生成单元测试或者导入使用Microsoft Excel等编辑器创建的文本文档里的测试参数。测试可包含多种测试用例,这些用例决定了各种数据类型(包括数组和簇) 的输入值和预期输出。您将可识别错误输出的来源、跟踪代码覆盖率,并生成HTML、ATML/XML或ASCII格式的验证文档。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版与ZIP版内容一样,EXE版为NI当年发行版,ZIP版为NI后期重新压制的版本。
    EXE版:
    ZIP版:
    EXE版:
    请注册登录视觉论坛会员,购买附件查看
    ZIP版:
    请注册登录视觉论坛会员,购买附件查看
    UTF2014.txt (524 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2014 Unit Test Framework Toolkit Readme
    Version 14.0.0
    June 2014
    This file contains important information about the Unit Test Framework Toolkit, including system requirements, installation instructions, and known issues.
    The LabVIEW 2014 Unit Test Framework Toolkit is the upgrade version of the LabVIEW 2013 Unit Test Framework Toolkit. The Unit Test Framework Toolkit provides interactive tools you use to create, configure, manage, and execute tests that check VIs for functional correctness.
    The Unit Test Framework Toolkit has the following requirements:
    • LabVIEW 2014 Base, Full, or Professional Development System (32-bit)
    • At least 64 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2014.
    You can install all of your LabVIEW products—including the Unit Test Framework Toolkit—using the LabVIEW 2014 Platform media. Refer to the LabVIEW Installation Guide on the LabVIEW Platform media for installation instructions and system requirements.
    To request additional LabVIEW Platform media, refer to the National Instruments website.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Unit Test Framework Toolkit.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Unit Test Framework Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Unit Test Framework Toolkit are located in the labview\examples\Unit Test Framework directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    Finding All Programs
    NI LabVIEW Unit Test Framework Toolkit Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Unit Test Framework Toolkit will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of the Unit Test Framework Toolkit that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2008–2014 National Instruments. All rights reserved.
    GMT+8, 2026-4-1 10:50
