查看: 3488|回复: 0
[LV工具模块] LabVIEW 2011 Unit Test Framework Toolkit Win32Eng LabVIEW单元测试框架工具包UTF2011
    3 小时前
  • 签到天数: 3705 天
    发表于 2020-7-23 23:37:46 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW单元测试框架工具包可自动执行LabVIEW VI单元测试,帮助您轻松进行功能验证。
    LabVIEW单元测试框架工具包是一个LabVIEW附加软件,可帮助您自动完成功能验证,并验证应用程序是否正常运行。您可以生成单元测试或者导入使用Microsoft Excel等编辑器创建的文本文档里的测试参数。测试可包含多种测试用例,这些用例决定了各种数据类型(包括数组和簇) 的输入值和预期输出。您将可识别错误输出的来源、跟踪代码覆盖率,并生成HTML、ATML/XML或ASCII格式的验证文档。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版与ZIP版内容一样,EXE版为NI当年发行版,ZIP版为NI后期重新压制的版本。
    EXE版:
    ZIP版:
    EXE版:
    请注册登录视觉论坛会员,购买附件查看
    ZIP版:
    请注册登录视觉论坛会员,购买附件查看
    UTF2011.txt (524 Bytes, 下载次数: 2, 售价: 10 圆)
    LabVIEW 2011 Unit Test Framework Toolkit Readme
    Version 11.0.0
    June 2011
    This file contains information about the LabVIEW 2011 Unit Test Framework Toolkit. This file also provides you with help resources you can use while working with the Unit Test Framework Toolkit.
    The LabVIEW 2011 Unit Test Framework Toolkit is the upgrade version of the LabVIEW 2010 Unit Test Framework Toolkit. The Unit Test Framework Toolkit provides interactive tools you use to create, configure, manage, and execute tests that check VIs for functional correctness.
    The computer you are using must meet the minimum system requirements to run the Unit Test Framework Toolkit:
    • Supported operating systems:
      • Windows XP Service Pack 2 or later
    • A minimum of 32 MB free disk space
    • LabVIEW 2011 Base, Full, or Professional Development System (32-bit)
    Note: The Unit Test Framework Toolkit does not support Windows NT/Me/2000/98/95 or the Windows Server non-R2 editions.
    You can install all of your LabVIEW products—including the Unit Test Framework Toolkit—using the LabVIEW 2011 Platform DVDs. You can find installation instructions for the Unit Test Framework Toolkit along with activation instructions in the following locations:
    • LabVIEW 2011 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2011 Platform DVDs, refer to the National Instruments Web site.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from the pull-down menu in LabVIEW, for information about the Unit Test Framework Toolkit.
    LabVIEW examples for the Unit Test Framework Toolkit are located in the labview\examples\Unit Test Framework folder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the Unit Test Framework Toolkit.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2011 Unit Test Framework Toolkit. If you have a bug ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the Unit Test Framework Toolkit.
    239900UTF 2009 SP1 breaks the NI Requirements Gateway 1.1 example installed by UTF Toolkit.
    243187UTF shows reference leaks in DETT.
    244238Using Not a Path for expected value with Path Indicators results in failed test cases
    246939NIRG UTF Test Definition (LVTEST) type does not specify the display field for the Test Reference reference.
    253649UTF generated incomplete and incorrect report.
    254286Misspelling and incorrect capitalization in UTF HTML & ASCII reports.
    254858Generating ATML/XML reports causes HTML reports to lose the Test Details section.
    276209Creating user-defined tests in a project crashes LabVIEW 2010.
    278336Dialogs look bad in Windows 7.
    Important Information
    © 2011 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-11-7 11:19
