查看: 5886|回复: 0
[LV工具模块] LabVIEW 2020 Model Interface Toolkit Win32Eng LabVIEW模型接口工具包MIT2020
    13 小时前
  • 签到天数: 3843 天
    连续签到: 36 天
    发表于 2020-7-19 23:46:01 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW模型接口工具包可帮助您在开发控制系统时集成模型集成。
    LabVIEW模型接口工具包是使用VeriStand模型框架的附加软件。借助该附加软件,您可以将各种软件环境中的仿真模型和控制算法集成到LabVIEW和LabVIEW Real-Time模块中。您可以从LabVIEW控制设计和仿真模块以及第三方建模环境(例如The MathWorks,Inc. Simulink软件和C/C ++)导入控制算法和系统模型。您还可以组合来自多个仿真环境的模型,并同时运行多个模型。Simulink是MathWorks公司的注册商标。
    文件大小: 1093875712 字节 (1.02 GB)
    修改日期: 2020-05-12 01:16
    MD5: 98703f20fae8eae2453f94b4a2cd1701
    SHA1: 15837bdd7ce1abc62aa933727ad100d71f0e6b05
    SHA256: c2b7aa1c68ff2ea56d5258f458829c876730e7dd00834cc30af7f60b4897c17a
    CRC32: eab65136
    百度网盘下载和NI官方下载地址:
    请注册登录视觉论坛会员,购买附件查看
    MIT2020.txt (659 Bytes, 下载次数: 17, 售价: 10 圆)
    LabVIEW 2020 Model Interface Toolkit Readme
    May 2020
    This file contains important information about the LabVIEW Model Interface Toolkit, including installation instructions, system requirements, and known issues.
    Accessing the Software and Help
    Use the LabVIEW Model Interface Toolkit to connect simulation models from a variety of simulation environments and programming languages to real-world I/O.
    The LabVIEW 2020 Model Interface Toolkit requires the LabVIEW 2020 Full or Professional Development System (32-bit) and any system requirements for LabVIEW 2020. Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2020.
    To integrate and run your existing compiled models, you need only the Model Interface Toolkit installed. However, to perform other tasks with models you need additional software, as the following list describes:
    • To develop a model using MathWorks Simulink® application software, you must be a licensed user of and have the following software installed on the host computer:
      • MathWorks MATLAB® software (32-bit or 64-bit versions)
      • MathWorks Simulink software.
    • To compile a model developed using MathWorks Simulink software, you must be a licensed user of and have the following software installed on the host computer:
      • MathWorks Real-Time Workshop® (Simulink Coder®).
      • VeriStand Model Framework. You must complete step 3 of the Installation Instructions section to install the VeriStand Model Framework item on the feature selection screen of the VeriStand installer. Refer to the NI website for a list of compilers that are tested and supported.
    • To compile a LabVIEW VI into a .lvmodel or .lvmodelso file you can load and run, you must complete step 3 of the Installation Instructions to install the VeriStand LabVIEW Model Support item on the feature selection screen of the VeriStand installer.
    If you use other modeling environments, contact your model vendor for requirements for developing a model and converting it into a compiled model.
    The LabVIEW Model Interface Toolkit supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2016, the LabVIEW Model Interface Toolkit dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2020 Model Interface Toolkit will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2020 Model Interface Toolkit to an unsupported OS. Additionally, after installing the LabVIEW 2020 Model Interface Toolkit, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support for 2020, refer to KB 79UC78LS, Why Does my LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?.
    The Model Interface Toolkit 2020 supports the following application software versions, including service packs.
    Versions Supported by Model Interface Toolkit
    LabVIEW Full or Professional Development System (32-bit)2020
    Use NI Package Manager or NI Software Product Downloads to install the LabVIEW 2020 Model Interface Toolkit.
    The VeriStand Model Framework contains changes to the files you use to develop and compile models in C/C++ and third-party modeling environments. If your system contains models compiled with previous versions of the Model Framework, choose from the following options for continuing to use the models in VeriStand 2020:
    • If you do not need to update your model or deploy it to Intel x64-based targets that run NI Linux Real-Time, you can continue to use the model as-is.
    • If you need to update functionality of your model that does not require the changes in the latest version of the Model Framework, you can recompile the model against the deprecated Model Framework files. These files are installed at \VeriStand\version\ModelInterface\custom\src\obsolete. However, you cannot deploy the recompiled model to Intel x64-based targets that run NI Linux Real-Time.
    • To use the new features in the latest version of the Model Framework, or if you need to deploy the model to Intel x64-based targets that run NI Linux Real-Time, update and recompile the models using the 2020 version of the Model Framework. Update your models according to the following differences between new files in the Model Framework and the deprecated files they replace:
      • ni_modelframework.h contains the following differences from NIVERISTAND_API.h:
        • Implements fixed-width data types from the C99 standard, such as replacing int with int32_t where applicable.
        • Replaces use of the long data type with int32_t or uint32_t where applicable to achieve cross-platform compatibility.
      • ni_modelframework.c contains the following differences from codegen.c:
        • This file is installed on disk at \src\ni_modelframework.c rather than in the directory.
        • USER_TakeOneStep() now returns an int32_t value rather than void. If the function completes successfully, it returns NI_OK. If an error occurs, this function returns NI_ERROR.
        • The USER_ModelName global variable is a const char and replaces the ModelName variable.
        • The USER_Builder global variable is a const char and replaces the build variable.
        • The USER_BaseRate global variable is a const char and replaces the baserate variable.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the LabVIEW 2020 Model Interface Toolkit.
    For a complete list of the IDs and titles of the issues fixed in this release, see LabVIEW Model Interface Toolkit 2020 Bug Fixes. If you have a Bug or Legacy ID, you can search the list to validate that the issue has been fixed.
    To access the Model Interface Toolkit VIs, select View»Functions Palette from the block diagram in LabVIEW and navigate to the Control Design & Simulation»Model Interface palette. You also can right-click any blank space on the block diagram to display the Functions palette.
    Refer to the Toolkits»Model Interface Toolkit book on the Contents tab of the LabVIEW Help for more information about the Model Interface Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Model Interface Toolkit are located in the labview\examples\Control and Simulation\Model Interface directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The example models included with the Model Framework are located at \VeriStand\version\ModelInterface\custom\examples.
    Important Information
    © 2013-2020 National Instruments. All rights reserved.
    375381E-01
    GMT+8, 2026-4-1 13:53
