查看: 4944|回复: 0
[LV工具模块] LabVIEW 2019 Sound and Vibration Analysis Win32ENG LabVIEW声音和振动工具包NISV2019-32
    12 小时前
  • 签到天数: 3843 天
    连续签到: 36 天
    发表于 2020-7-19 17:27:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW声音和振动工具包提供了音频测试、声学测量和振动测量应用所需的函数和显示控件。
    LabVIEW声音和振动工具包是一个软件附加组件,包含易于使用的功率谱、正弦扫频和倍频程分析VI。它还可进行音频和失真测量、频率分析、频率响应测量和瞬态分析。该工具包还对分析解决方案进行了更新,以符合不断发展的IEC标准。LabVIEW声音和振动工具包提供了50多个可立即运行的LabVIEW示例,旨在帮助用户快速开始开发应用程序。
    在2019~2021版本,使用32位、64位分开安装文件的方式,在2018及之前的版本,2023Q3及之后版本则使用同一个安装文件,即同一安装文件可支持32位、64位LabVIEW,与VISION模块类似。具体的请查看下面的自述文件。
    SV2016版的安装包比SV2015版的安装小了近1GB,从自述文件中看到,主要是少了SV快速VI和SVA的助手工具,如果要安装SV快速VI和SVA助手,则需要使用2015及以前的版本:
    Note: Sound and Vibration Express VIs and the Sound and Vibration Assistant are not instalLED by NI Sound and Vibration Measurement Suite 2016. Side-by-side installation is supported; therefore you may install the Sound and Vibration Assistant from NI Sound and Vibration Toolkit or NI Sound and Vibration Measurement Suite 2015 or earlier.
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    请注册登录视觉论坛会员,购买附件查看
    SV2019.txt (299 Bytes, 下载次数: 32, 售价: 10 圆)
    LabVIEW 2019 Sound and Vibration Toolkit Readme
    Version 19.0.0
    March 2019
    This file contains information about LabVIEW support for the NI Sound and Vibration Toolkit (Base and Full). This file also provides you with help resources you can use while working with the software. Refer to the National Instruments Web site for a comparison between Sound and Vibration Toolkit (Base) and Sound and Vibration Toolkit (Full).
    This file contains the following information:
    Redistributing Executable Sound and Vibration Applications
    Accessing Sample Projects
    The NI Sound and Vibration Toolkit provides comprehensive configuration, measurement-analysis, and visualization tools for audio, noise-vibration-harshness (NVH), and machine condition monitoring (MCM) applications. Based on an open-analysis capability and a flexible measurement library, the NI Sound and Vibration Toolkit presents a unique, software-based measurement approach to creating customized applications. Learn more about the sound and vibration software at ni.com/soundandvibration.
    Back to Top
    The Sound and Vibration Toolkit Base/Full have the following requirements:
    • At least 1 GB of available disk space
    • At least 1 GB of RAM
    • NI-DAQmx 19.0 or later installed for NI-DAQmx support
    Back to Top
    The following table lists the NI application software versions, including service packs, supported by the Sound and Vibration Toolkit. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI Sound and Vibration Toolkit 2019
    NI LabVIEW (32- and 64-bit) Full or Professional Development System2019
    NI LabVIEW Real-Time Module2019
    Note: Sound and Vibration Express VIs and the Sound and Vibration Assistant are not installed by NI Sound and Vibration Toolkit 2019. Side-by-side installation is supported; therefore you may install the Sound and Vibration Assistant from NI Sound and Vibration Toolkit or NI Sound and Vibration Measurement Suite 2015 or earlier.
    Back to Top
    You must be logged in with administrator privileges to install the Sound and Vibration Toolkit.
    Installing from the LabVIEW 2019 Platform media
    You can install all of your LabVIEW products—including the Sound and Vibration Toolkit—using the LabVIEW Platform media. Refer to the LabVIEW Installation Guide on the LabVIEW Platform media for installation instructions and system requirements.
    To request additional LabVIEW Platform media, refer to the National Instruments website.
    Note If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
    Installing from the Sound and Vibration Toolkit DVD
    Complete the following steps to install the Sound and Vibration Toolkit:
    • Disable any automatic virus detection programs before installation. Some virus detection programs interfere with the installation program.
    • Insert the Sound and Vibration Toolkit DVD and follow the instructions that appear on the screen.
    • After installation, enable any virus detection programs you disabled and run a virus scan.
    • Restart the computer.
    • Activate the Sound and Vibration Toolkit Base or Full using the NI License Manager.
    Back to Top
    Back to Top
    New Features: Sound and Vibration Toolkit
    The Sound and Vibration Toolkit includes the following new features:
    Support for LabVIEW 2019
    Support for LabVIEW 2019 does not remove previously installed support for LabVIEW 2018 and earlier.
    Support for Gabor Analyses on Linux real-time targets
    Runtime support on Linux targets is supported for online and offline analyses.
    Enhanced Examples for Audio Test
    • Stimulus-Response Examples use channel wires to communicate data from DAQmx Engine to Measurement-Analysis Loop.
    • Synchronization pulse automatically correlated to align channels with different signal path delays.
    Back to Top
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the Sound and Vibration Toolkit.
    Back to Top
    You can access a list of bug fixes online. Refer to the National Instruments Web site for a list of bug fixes in the Sound and Vibration Toolkit.
    Back to Top
    If you want to redistribute executables built with the Sound and Vibration Toolkit or any of its components, you must purchase the appropriate NI Sound and Vibration Software Run-Time License. The part number for the NI Sound and Vibration Software Run-Time License is 779875-35. Contact National Instruments to purchase the NI Sound and Vibration Software Run-Time License.
    Back to Top
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help in LabVIEW, for information about the Sound and Vibration VIs. Sound and Vibration Toolkit documentation is located in the LabVIEW Help in the following location: LabVIEW Help»Toolkits»Sound and Vibration Toolkit.
    Back to Top
    Accessing the Sample Projects
    To access the sample projects and templates from the New Project dialog, select Sample Projects in the left pane and navigate to the project that best matches your application requirements.
    Back to Top
    You can find LabVIEW examples for the Sound and Vibration VIs using the NI Example Finder. Select Help»Find Examples to launch the NI Example Finder. On the Browse page, the Sound and Vibration example VIs are located in the Toolkits and Modules»Sound and Vibration folder.
    You also can find LabVIEW examples for the Sound and Vibration VIs in the labview\examples\Sound and Vibration and the labview\examples\Order Analysis directories.
    Back to Top
    Back to Top
    Back to Top
    Back to Top
    © 2007–2019 National Instruments. All rights reserved.
    375332E-01
    GMT+8, 2026-4-1 12:43
