查看: 6928|回复: 0
[LV工具模块] LabVIEW 2020 Control Design and Simulation Module Win32Eng LabVIEW控制设计和仿真模块CDSIM2020
    13 小时前
  • 签到天数: 3843 天
    连续签到: 36 天
    发表于 2020-7-19 00:00:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW控制设计与仿真模块可用于仿真动态系统、设计控制器,并将控制系统部署至实时硬件。
    LabVIEW控制设计与仿真模块是一款与LabVIEW平台相集成的附加软件,提供了内置并行机制、多核和多速率技术等编程能力以及用来部署至实时硬件的工具。您可将测量功能集成到用于系统识别、模型校准或模型验证的设计中。然后将算法部署至NI实时嵌入式硬件,实现快速控制原型和硬件在环(HIL)应用。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    离线安装版:
    在线安装版:
    链接: 请注册视觉论坛用户,登录后购买附件下载查看,充值请联系在线客服提取码: 请注册登录视觉论坛会员,购买附件查看
    离线安装版:
    请注册登录视觉论坛会员,购买附件查看
    在线安装版:
    请注册登录视觉论坛会员,购买附件查看
    CDSIM2020.txt (598 Bytes, 下载次数: 16, 售价: 10 圆)
    LabVIEW 2020 Control Design and Simulation Module Readme
    March 2020
    This file contains important information about the LabVIEW Control Design and Simulation Module, including system requirements, installation instructions, and known issues.
    Limitations on Windows (64-bit), macOS, and Linux
    Control Design and Simulation Module Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    The Control Design and Simulation Module provides tools with which you can analyze open-loop model behavior, design closed-loop controllers, simulate dynamic systems, and deploy models and control systems to real-time hardware. The Control Design and Simulation Module also provides tools to complete the entire system identification process, which involves building mathematical models of a dynamic system based on a set of measured stimulus and response data samples.
    Use the Control Design Assistant to load and save models, perform analysis on systems, and design controllers. Refer to the Control Design Assistant Readme for information about the Control Design Assistant.
    Use the System Identification Assistant to create a project that encompasses the whole system identification process. Refer to the System Identification Assistant Readme for information about the System Identification Assistant.
    In addition to the system requirements for the LabVIEW Development System, the Control Design and Simulation Module has the following requirements:
    • LabVIEW 2020 Full or Professional Development System
    • At least 800 MB of disk space
    • (Optional) LabVIEW MathScript Module for designing, analyzing, and simulating linear controller models using a text-based language
    The Control Design and Simulation Module supports the following operating systems:
    WindowsWindows 10 (version 1909)/8.1 Update 11/7 SP12
    Windows Server 2016
    Windows Server 2012 R21
    Windows Server 2008 R2 SP12
    Note  Refer to Control Design and Simulation Module Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    Note  In 2016 the Control Design and Simulation Module dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2020 Control Design and Simulation Module will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2020 Control Design and Simulation Module to an unsupported OS. Additionally, after installing the LabVIEW 2020 Control Design and Simulation Module, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    macOSmacOS 10.14 or 10.15
    LinuxopenSUSE LEAP 15.0
    openSUSE LEAP 15.1
    Red Hat Enterprise 7
    Red Hat Enterprise 8
    CentOS 7
    CentOS 8
    Note  The LabVIEW 2020 Control Design and Simulation Module for Linux requires a 64-bit distribution and does not support 32-bit applications.
    The following features are available on Windows 32-bit or Windows only:
    • (Windows 32-bit) Control Design Assistant
    • (Windows 32-bit) Real-Time support
    • (Windows 32-bit) System Identification Assistant
    • (Windows) System Identification VIs
    (Windows)
    NI installs the Control Design and Simulation Module using NI Package Manager. If you do not already have NI software installed, the Control Design and Simulation Module installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    You can also install LabVIEW and the Control Design and Simulation Module using the LabVIEW Platform media.
    (macOS, Linux)
    You can install the Control Design and Simulation Module using the LabVIEW media for macOS/Linux. Refer to the LabVIEW Media Readme for macOS/Linux for instructions on how to install the Control Design and Simulation Module.
    You can access the software and documentation known issues list online. Visit ni.com/info and enter the Info Code lvcdsm2020ki for an up-to-date list of known issues in the LabVIEW Control Design and Simulation Module.
    (Windows) Refer to the LabVIEW Help, accessible from Help»LabVIEW Help from LabVIEW, for information about the Control Design and Simulation Module.
    (macOS and Linux) Launch LabVIEW and select Help»Control Design and Simulation Module to launch the LabVIEW Control Design and Simulation Module Help.
    Refer to the LabVIEW Control Design User Manual for conceptual information about using the control design functionality of the Control Design and Simulation Module. Open this manual by navigating to the labview\manuals directory and opening CD_User_Manual.pdf.
    Refer to the LabVIEW Control Design and Simulation Module Algorithm References manual for information about algorithms implemented in the Control Design and Simulation Module and their corresponding references. Access the LabVIEW Control Design and Simulation Module Algorithm References manual by navigating to the labview\manuals directory and opening CDreference.pdf.
    (Windows) Refer to the LabVIEW System Identification VIs Algorithm References manual for information about algorithms implemented in the System Identification VIs and their corresponding references. Access the LabVIEW System Identification VIs Algorithm References manual by navigating to the labview\manualsdirectory and opening SIreference.pdf.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Control and Simulation folder to access the LabVIEW examples for the Control Design and Simulation Module. You also can find the LabVIEW examples for the Control Design and Simulation Module in the labview\examples\Control and Simulation directory and the (Windows) labview\examples\System Identification directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The Control Design and Simulation Module will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2007–2020 National Instruments. All rights reserved.
    375312G-01
    GMT+8, 2026-4-1 13:53
