查看: 3384|回复: 0
[LV工具模块] LabVIEW 2017 64bit Control Design and Simulation Module Win64Eng LabVIEW控制设计和仿真模块CDSIM2017-64bit
    12 小时前
  • 签到天数: 3843 天
    连续签到: 36 天
    发表于 2020-7-18 23:54:14 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW控制设计与仿真模块可用于仿真动态系统、设计控制器,并将控制系统部署至实时硬件。
    LabVIEW控制设计与仿真模块是一款与LabVIEW平台相集成的附加软件,提供了内置并行机制、多核和多速率技术等编程能力以及用来部署至实时硬件的工具。您可将测量功能集成到用于系统识别、模型校准或模型验证的设计中。然后将算法部署至NI实时嵌入式硬件,实现快速控制原型和硬件在环(HIL)应用。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版与ZIP版内容一样,EXE版为NI当年发行版,ZIP版为NI后期重新压制的版本。
    EXE版:
    ZIP版:
    EXE版:
    请注册登录视觉论坛会员,购买附件查看
    ZIP版:
    请注册登录视觉论坛会员,购买附件查看
    CDSIM2017-64.txt (524 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2017 Control Design and Simulation Module Readme
    March 2017
    This file contains important information about the LabVIEW 2017 Control Design and Simulation Module, including system requirements, installation instructions, and known issues.
    Limitations on Windows (64-bit), OS X, and Linux
    The Control Design and Simulation Module provides tools with which you can analyze open-loop model behavior, design closed-loop controllers, simulate online and offline systems, and conduct physical implementations. The Control Design and Simulation Module also provides tools to complete the entire system identification process, which involves building mathematical models of a dynamic system based on a set of measured stimulus and response data samples.
    Use the Control Design Assistant to load and save models, perform analysis on systems, and design controllers. Refer to the Control Design Assistant Readme for information about the Control Design Assistant.
    Use the System Identification Assistant to create a project that encompasses the whole system identification process. Refer to the System Identification Assistant Readme for information about the System Identification Assistant.
    In addition to the system requirements for the LabVIEW Development System, the Control Design and Simulation Module has the following requirements:
    • LabVIEW 2017 Full or Professional Development System
    • At least 800 MB of disk space
    • (Optional) LabVIEW MathScript RT Module for designing, analyzing, and simulating linear controller models using a text-based language
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2017.
    The Control Design and Simulation Module supports the following operating systems:
    WindowsWindows 10/8.11/7 SP12
    Windows Server 2012 R21
    Windows Server 2008 R2 SP12
    Note  In 2016 the Control Design and Simulation Module dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2017 Control Design and Simulation Module will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2017 Control Design and Simulation Module to an unsupported OS. Additionally, after installing the LabVIEW 2017 Control Design and Simulation Module, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    OS XOS X 10.11 or 10.12
    LinuxopenSUSE LEAP 42.1
    openSUSE LEAP 42.2
    Red Hat Enterprise Linux Desktop + Workstation 6.x
    Red Hat Enterprise Linux Desktop + Workstation 7.x
    Scientific Linux 6.x
    CentOS 7
    The Control Design and Simulation Module on Windows (64-bit), OS X, and Linux does not support the following features:
    • Control Design Assistant
    • Real-Time support
    • System Identification VIs
    (Windows)
    You can install all of your LabVIEW products—including the Control Design and Simulation Module—using the LabVIEW 2017 Platform media.
    (OS X)
    Complete the following steps to install the Control Design and Simulation Module on OS X:
    • Insert the Control Design and Simulation Module installation media and open NI LabVIEW 2017 Control Design and Simulation Module 64-bit.pkg located under the Mac OS X subdirectory.
    • Select Continue to run a program to determine if the Control Design and Simulation Module can be installed on your system.
    • Follow the instructions that appear on the screen and continue to the Destination Select screen.
    • In the Destination Select screen, you must select the location where a compatible version of LabVIEW is installed. Otherwise, the installation will not complete.
    • After you select the destination directory, continue to follow the instructions that appear on the screen.
    (Linux)
    Complete the following steps to install the Control Design and Simulation Module on Linux:
    • Insert the Control Design and Simulation Module installation media. Use mount /mnt/cdrom to mount the media. On some systems, the media mounts automatically.
    • To change the current directory to the mounted media, enter the following command according to the Linux operating system on which you run the Control Design and Simulation Module:
      cd /mnt/cdrom/Linux_32-bit or cd /mnt/cdrom/Linux_64-bit
      sh ./INSTALL
    To uninstall the Control Design and Simulation Module on Linux, enter the following command:
    sh ./UNINSTALL
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in LabVIEW 2017 Control Design and Simulation Module.
    (Windows) Refer to the LabVIEW Help, accessible from Help»LabVIEW Help from LabVIEW, for information about the Control Design and Simulation Module.
    (OS X and Linux) Launch LabVIEW and select Help»Control Design and Simulation Module to launch the LabVIEW Control Design and Simulation Module Help.
    Refer to the LabVIEW Control Design User Manual for conceptual information about using the control design functionality of the Control Design and Simulation Module. Open this manual by navigating to the labview\manuals directory and opening CD_User_Manual.pdf.
    Refer to the LabVIEW Control Design and Simulation Module Algorithm References manual for information about algorithms implemented in the Control Design and Simulation Module and their corresponding references. Access the LabVIEW Control Design and Simulation Module Algorithm References manual by navigating to the labview\manuals directory and opening CDreference.pdf.
    (Windows 32-bit) Refer to the LabVIEW System Identification VIs Algorithm References manual for information about algorithms implemented in the System Identification VIs and their corresponding references. Access the LabVIEW System Identification VIs Algorithm References manual by navigating to the labview\manuals directory and opening SIreference.pdf.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Control and Simulation folder to access the LabVIEW examples for the Control Design and Simulation Module. You also can find the LabVIEW examples for the Control Design and Simulation Module in the labview\examples\Control and Simulation directory and the (Windows 32-bit) labview\examples\System Identification directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    © 2007–2017 National Instruments. All rights reserved.
    375312C-01
    GMT+8, 2026-4-1 12:29
