查看: 4739|回复: 1
[LV工具模块] LabVIEW 2014 Control Design and Simulation Module Win32Eng LabVIEW控制设计和仿真模块CDSIM2014
    发表于 2020-7-18 23:40:06 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW控制设计与仿真模块可用于仿真动态系统、设计控制器,并将控制系统部署至实时硬件。
    LabVIEW控制设计与仿真模块是一款与LabVIEW平台相集成的附加软件,提供了内置并行机制、多核和多速率技术等编程能力以及用来部署至实时硬件的工具。您可将测量功能集成到用于系统识别、模型校准或模型验证的设计中。然后将算法部署至NI实时嵌入式硬件,实现快速控制原型和硬件在环(HIL)应用。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版与ZIP版内容一样,EXE版为NI当年发行版,ZIP版为NI后期重新压制的版本。
    EXE版:
    ZIP版:
    EXE版:
    请注册登录视觉论坛会员,购买附件查看
    ZIP版:
    请注册登录视觉论坛会员,购买附件查看
    CDSIM2014.txt (506 Bytes, 下载次数: 13, 售价: 10 圆)
    LabVIEW 2014 Control Design and Simulation Module Readme
    Version 14.0.0
    June 2014
    This file contains important information about the LabVIEW Control Design and Simulation Module, including new features, system requirements, installation instructions, known issues, and a partial list of bugs fixed for the LabVIEW 2014 Control Design and Simulation Module.
    The Control Design and Simulation Module provides tools with which you can analyze open-loop model behavior, design closed-loop controllers, simulate online and offline systems, and conduct physical implementations. The Control Design and Simulation Module also provides tools to complete the entire system identification process, which involves building mathematical models of a dynamic system based on a set of measured stimulus and response data samples.
    Use the Control Design Assistant to load and save models, perform analysis on systems, and design controllers. Refer to the Control Design Assistant Readme for information about the Control Design Assistant.
    Use the System Identification Assistant to create a project that encompasses the whole system identification process. Refer to the System Identification Assistant Readme for information about the System Identification Assistant.
    (Windows) The LabVIEW 2014 Control Design and Simulation Module includes the System Identification VIs and the System Identification Assistant for you to develop models of a system based on a large set of raw data. You can complete the entire system identification process, from analyzing the raw data to validating the identified model, by using the System Identification VIs and the System Identification Assistant.
    In addition to the system requirements for the LabVIEW Development System, the Control Design and Simulation Module has the following requirements:
    • LabVIEW 2014 Full or Professional Development System (32-bit)
    • At least 800 MB of disk space
    • (Optional) LabVIEW MathScript RT Module for designing, analyzing, and simulating linear controller models using a text-based language.
    • (Control Design Assistant or System Identification Assistant) NI SignalExpress 2014
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2014.
    (Linux and OS X) Limitations on Desktop Linux and OS X
    The Control Design and Simulation Module on desktop Linux and OS X does not support the following features:
    • Control Design Assistant
    • Real-Time support
    • System Identification VIs
    (Windows) You can install all of your LabVIEW products—including the Control Design and Simulation Module—using the LabVIEW 2014 Platform media. Refer to the LabVIEW Installation Guide on the LabVIEW Platform media for installation instructions and system requirements.
    To request additional LabVIEW Platform media, refer to the National Instruments website.
    (OS X) Complete the following steps to install the Control Design and Simulation Module for OS X from the NI LabVIEW 2014 Control Design and Simulation Module installation CD:
    • Insert the NI LabVIEW 2014 Control Design and Simulation Module installation CD and open LabVIEW2014CDSim.mpkg located under the Mac OS X directory.
    • Select Continue to run a program to determine if the Control Design and Simulation Module can be installed on your system.
    • Follow the instructions that appear on the screen and continue to the Destination Select screen.
    • In the Destination Select screen, you must select the location where a compatible version of LabVIEW is installed. Otherwise, the installation will not complete.
    • After you select the destination directory, continue to follow the instructions that appear on the screen.
    (Linux) Complete the following steps to install the Control Design and Simulation Module for Linux from the NI LabVIEW 2014 Control Design and Simulation Module installation CD:
    • Insert the NI LabVIEW 2014 Control Design and Simulation Module installation CD. Use mount /mnt/cdrom to mount the CD. On some systems, the CD mounts automatically.
    • To change the current directory to the mounted CD, enter the following command:
      cd /mnt/cdrom
      sh ./INSTALL
      If you encounter the following message: "bad interpreter: Permission denied", the CD may not have mounted with executable permissions. To work around this, enter the following command:
      /bin/sh ./INSTALL
    Installing the Control Design Assistant and System Identification Assistant
    You must install NI SignalExpress before you can install the Control Design Assistant or System Identification Assistant. Refer to the Control Design Assistant Readme and System Identification Assistant Readme for information about installation instructions.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Control Design and Simulation Module.
    The following items are the IDs and titles of a subset of issues fixed in the Control Design and Simulation Module. This is not an exhaustive list of issues fixed in the current version of the Control Design and Simulation Module. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    401515LabVIEW crashes when you run the EKF test twice
    414394ss, tf, and zpk blocks do not have terminals wired when converting models
    415368CD&Sim External Model.vi dll path is absolute, causing application distribution problems
    423484LabVIEW crashes when running one simulation example in some cases
    423624Cannot specify a value for the Initial state estimate xhat(t0) parameter in the Continuous Observer Function
    433909The Simulation Model Converter is broken in 2013
    443391The Simulation Loop do not recompile code when going from 32 to 64 bit on the same platform
    461393The Control & Simulation Loop cannot use the 1 MHz clock on Linux RT targets
    The LabVIEW Control Design User Manual contains conceptual information about using the control design functionality of the Control Design and Simulation Module. Open this manual by navigating to the labview\manuals directory and opening CD_User_Manual.pdf.
    The LabVIEW Control Design and Simulation Module Help contains conceptual, how-to, and reference information about the Control Design and Simulation Module.
    (Windows) Complete the following steps to access this help file:
    • Launch LabVIEW.
    • Select Help»LabVIEW Help to launch the LabVIEW Help.
    • Click the Contents tab.
    • On the Contents tab, navigate to the Control Design and Simulation Module book.
    (OS X, Linux) Complete the following steps to access this help file:
    • Launch LabVIEW.
    • Select Help»Control Design and Simulation Module to launch the Control Design and Simulation Module Help.
    Refer to the LabVIEW Control Design and Simulation Module Algorithm References manual for information about algorithms implemented in the Control Design and Simulation Module and their corresponding references. Access the LabVIEW Control Design and Simulation Module Algorithm References manual by navigating to the labview\manuals directory and opening CDreference.pdf.
    Refer to the LabVIEW System Identification VIs Algorithm References manual for information about algorithms implemented in the System Identification VIs and their corresponding references. Access the LabVIEW System Identification VIs Algorithm References manual by navigating to the labview\manualsdirectory and opening SIreference.pdf.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Control and Simulation folder to access the LabVIEW examples for the Control Design and Simulation Module. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the LabVIEW examples for the Control Design and Simulation Module in the labview\examples\Control and Simulation directory and the labview\examples\System Identification directory.
    Using NI Launcher
    Finding All Programs
    NI LabVIEW Control Design and Simulation Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Control Design and Simulation Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of LabVIEW Control Design and Simulation Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2007–2014 National Instruments. All rights reserved.
    GMT+8, 2026-1-13 09:38
