查看: 3363|回复: 0
[LV工具模块] LabVIEW 2010 Control Design and Simulation Module Win32Eng LabVIEW控制设计和仿真模块CDSIM2010
    12 小时前
  • 签到天数: 3843 天
    连续签到: 36 天
    发表于 2020-7-18 19:28:53 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW控制设计与仿真模块可用于仿真动态系统、设计控制器,并将控制系统部署至实时硬件。
    LabVIEW控制设计与仿真模块是一款与LabVIEW平台相集成的附加软件,提供了内置并行机制、多核和多速率技术等编程能力以及用来部署至实时硬件的工具。您可将测量功能集成到用于系统识别、模型校准或模型验证的设计中。然后将算法部署至NI实时嵌入式硬件,实现快速控制原型和硬件在环(HIL)应用。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    请注册登录视觉论坛会员,购买附件查看
    CDSIM2010.txt (247 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2010 Control Design and Simulation Module Readme
    Version 10.0.0
    June 2010
    The LabVIEW 2010 Control Design and Simulation Module provides tools with which you can analyze open-loop model behavior, design closed-loop controllers, simulate online and offline systems, and conduct physical implementations. This file contains the following information about the Control Design and Simulation Module.
       Limitations on Mac OS X and Linux
    Version 2010 Features and Changes
    Installation/Upgrading Instructions
       Mac OS X
       Linux
    The Control Design and Simulation Module has the following requirements:
    • LabVIEW 2010 Full or Professional Development System
    • At least 350 MB additional disk space for Control Design and Simulation Module support
    • (Optional) LabVIEW MathScript RT Module. In LabVIEW 2009, LabVIEW MathScript became the LabVIEW MathScript RT Module. You cannot run VIs from previous versions of LabVIEW that contain MathScript Nodes until you install and activate the MathScript RT Module or remove the MathScript Nodes from the VIs. If you have already purchased the MathScript RT Module, select Help»Activate LabVIEW Components to activate the product.
    • (Optional) LabVIEW SignalExpress. If you plan to install the LabVIEW Control Design Assistant, you first must install LabVIEW SignalExpress.
    You can run the LabVIEW Control Design and Simulation Module installer on the following operating systems:
    • Windows XP (32-bit)
    • Mac OS X 10.5.0 or later
    • Red Hat Enterprise Linux WS 4 or later
    • openSUSE 11.0 or later
    The LabVIEW Control Design and Simulation Module installer does not support Windows 2000/NT/Me/98/95 or the Windows Server non-R2 editions.
    The LabVIEW Control Design and Simulation Module on Mac OS X and Linux does not support the following features:
    • LabVIEW Control Design Assistant
    • Real-Time support
    The LabVIEW 2010 Control Design and Simulation Module incorporates the following new features and changes.
    Enabled and Triggered Subsystems
    When you use subsystems on a simulation or block diagram, you can configure those subsystems to execute only when enabled or triggered. An enabled subsystem is one that executes when a Boolean input to the subsystem receives a TRUE value. A triggered subsystem is one that executes when an input signal to the subsystem crosses 0 or an offset from 0 that you specify. The same subsystem can be both enabled and triggered, and you can specify the behavior of individual outputs of the subsystem when that subsystem does not execute.
    To configure enabling or triggering for a subsystem, double-click the subsystem to display the Subsystem Configuration dialog box. Select Execution Control from the Parameters list and use the options under Parameter Information to configure the basic execution behavior of the subsystem. Select individual outputs from the Parameters list to configure the behavior of those outputs when the subsystem does not execute.
    Note: The Simulation Model Converter also supports the conversion of your .mdl files that contain enabled and triggered subsystems.
    Performance Enhancements
    In previous versions of the LabVIEW Control Design and Simulation Module, some users experienced slow load times for simulation diagrams. The LabVIEW 2010 Control Design and Simulation Module improve load times for simulation diagrams.
    Keyboard Shortcuts for Subsystems
    The following table lists new keyboard shortcuts you can use to display the front panel and block diagram of a simulation subsystem.
    Note: The key in these shortcuts corresponds to the (Mac OS X) key.
    Keyboard ShortcutDescription
    Ctrl-double-clickDisplays the block diagram of the subsystem.
    Shift-double-clickDisplays the front panel of the subsystem.
    DAE Solvers
    You can use the Implicit Systems functions to solve differential algebraic equations (DAEs) on a simulation diagram or within a Control & Simulation Loop. These functions enable you to use DAEs in building a simulation. Previous versions of the Control Design and Simulation module supported only ordinary differential equation (ODE) solvers. Navigate to Control Design & Simulation»Simulation»Implicit Systems on the Functions palette to access the following new functions:
    • Algebraic Variable
    • Implicit State
    • Implicit Variable
    Note: You must select the BDF solver in the Configure Simulation Parameters dialog box to use these functions.
    Save for Previous
    In previous versions of the LabVIEW Control Design and Simulation Module, you could not save a VI that contained a Control & Simulation Loop for a previous version of LabVIEW. In the LabVIEW 2010 Control Design and Simulation Module, you can save VIs that contain a Control & Simulation Loop for LabVIEW 2009. You cannot save these VIs for LabVIEW versions prior to 2009.
    Simulation Model Converter Enhancements
    The Simulation Model Converter converts your .mdl files that contain enabled and triggered subsystems and configures the resulting subsystems in LabVIEW. Select Tools»Control Design and Simulation»Simulation Model Converter to launch the Simulation Model Converter dialog box and convert your .mdl files.
    Support for Stateflow® Conversion with the Simulation Model Converter
    In previous versions of the LabVIEW Control Design and Simulation Module, the Simulation Model Converter did not support the conversion of statecharts developed with The MathWorks, Inc. Stateflow® application software. In the LabVIEW 2010 Control Design and Simulation Module, the Simulation Model Converter converts statecharts developed with The MathWorks, Inc. Stateflow® application software into statecharts usable within the LabVIEW Statechart Module.
    Note: To convert statecharts developed with The MathWorks, Inc. Stateflow® application software to statecharts usable within the LabVIEW Statechart Module, you must install the LabVIEW Statechart Module. Visit the National Instruments Web site for more information about the LabVIEW Statechart Module.
    (Windows) You can install all of your LabVIEW products—including the Control Design and Simulation Module—using the LabVIEW 2010 Platform DVDs. You can find installation instructions for the Control Design and Simulation Module along with activation instructions in the following locations:
    • LabVIEW 2010 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2010 Platform DVDs, refer to the National Instruments Web site.
    (Mac OS X) Complete the following steps to install the LabVIEW 2010 Control Design and Simulation Module for Mac OS X from the LabVIEW Control Design and Simulation Module installation CD.
    • Insert the LabVIEW 2010 Control Design and Simulation Module installation CD and open LabVIEW2010CDSim.mpkg located under the LabVIEW_2010\Mac OS X directory.
    • Select Continue to run a program to determine if the Control Design and Simulation Module can be installed on your system.
    • Follow the instructions that appear on the screen and continue to the Select Destination dialog box.
    • In the Select Destination dialog box, click the Choose button and select the version of LabVIEW to which you want to install the Control Design and Simulation Module.
    Note: You must click the Choose button for a proper installation. If you do not select a location where LabVIEW is installed or you select a non-compatible version of LabVIEW, the installation will not complete.
    • After you select the destination directory, click the Continue button to complete the installation.
    (Linux) Complete the following steps to install the LabVIEW 2010 Control Design and Simulation Module for Linux from the LabVIEW Control Design and Simulation Module installation CD.
    • Insert the LabVIEW 2010 Control Design and Simulation Module installation CD. Use mount /mnt/cdrom to mount the CD. On some systems, the CD mounts automatically.
    • To change the current directory to the mounted CD, enter the following command:
      cd /mnt/cdrom
      sh ./INSTALL
      If you encounter the following message: "bad interpreter: Permission denied", the CD may not have mounted with executable permissions. To work around this, enter the following command:
      /bin/sh ./INSTALL
    The LabVIEW Control Design User Manual contains conceptual information about using the control design functionality of the Control Design and Simulation Module. Open this manual by selecting Start»All Programs»National Instruments»LabVIEW 2010»LabVIEW Manuals and opening CD_User_Manual.pdf or by navigating to the labview\manuals directory and opening CD_User_Manual.pdf.
    The LabVIEW Control Design and Simulation Module Help contains conceptual, how-to, and reference information about the Control Design and Simulation Module.
    (Windows) Complete the following steps to access this help file.
    • Launch LabVIEW.
    • Select Help»LabVIEW Help to launch the LabVIEW Help.
    • Click the Contents tab.
    • On the Contents tab, navigate to the Control Design and Simulation Module book.
    (Mac OS X, Linux) Complete the following steps to access this help file.
    • Launch LabVIEW.
    • Select Help»Control Design and Simulation Module to launch the Control Design and Simulation Module Help.
    Refer to the LabVIEW Control Design Toolkit Algorithm References for information about algorithms implemented in the LabVIEW Control Design and Simulation Module and their corresponding references. Access the LabVIEW Control Design Toolkit Algorithm References by navigating to the labview\manuals directory and opening CDreference.pdf.
    Refer to the labview\examples\Control and Simulation directory for example VIs that demonstrate common tasks using the Control Design and Simulation Module. You also can access these VIs by selecting Help»Find Examples from the pull-down menu and selecting Toolkits and Modules»Control Design and Simulation in the NI Example Finder window. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Known Issues with Version 2010
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW 2010 Control Design and Simulation Module.
    The following items are the IDs and titles of a subset of issues fixed between the LabVIEW 2009 Control Design and Simulation Module and the LabVIEW 2010 Control Design and Simulation Module. This is not an exhaustive list of issues fixed in the current version of the Control Design and Simulation Module. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    36748Simulation Model Converter: Incorrect implementation of Selector block (Legacy ID: 3Z5925DL)
    48302Broken Save and Load buttons in configuration dialog boxes (Legacy ID: 3QPBCTDL)
    123506Cannot linearize subsystem with empty array default values
    131426Upgrading a Simulation VI may result in a broken VI
    133330Seed terminal not available for Correlated Random Gaussian Noise VI
    143597Simulation Model Converter: Converter produces no VI and gives internal errors if an initialization script has errors
    151578BDF solver gets wrong answer when integrating the derivative of a step function
    163739Documentation: Control Design MathScript functions not listed by "help classes"
    167978MathScript: eig function does not support Control Design data-types
    168606Documentation: Help for CD Continuous Kalman Filter has wrong equations
    171665Documentation: Context help missing for Estimation Function controls
    172353State-space to transfer function conversion loses zeros
    172859Simulation Model Converter crashes when converting models with a The MathWorks, Inc. MATLAB Fcn block on Mac OS X or Linux
    173772Single-stepping subsystems do not execute in LabVIEW built applications.
    174446Changing connector pane for subsystem may cause subsystem to fail to compile
    174532Documentation: CD Continuous Algebraic Riccati Equations VI help is incorrect
    174799Documentation: Control Design Assistant examples do not have links to help
    175551Subsystems fail to autosave correctly
    175715Vector Transport Delay causes runtime error on ARM
    175716Generated C code for Control & Simulation loop fails to compile if "Generate Debug Info" is TRUE
    175721Vector Discrete Unit Delay causes runtime error on ARM
    175932Control Design Assistant appears twice in Activation Wizard
    175933Documentation: Error in the online help of the CD Continuous Lyapunov Equation VI (Legacy ID: 4ACCJK7G)
    176322Estimation examples do not run on Mac or Linux without changes
    177810Simulation diagram remains broken after a feedback cycle is undone
    177828Error on Simulation diagram with calculation cycles, even if memory functions are used
    178167Simulation Model Converter: Cannot convert Sine and Cosine for older models
    178362Right-clicking a subsystem triggers an unnecessary recompile
    180442Nested Case Structures in simulations with local and global variables might fail to compile
    180486SimDiagSupport.cpp crash when placing Diagram Disable structure around indicators in subsystem
    182237Documentation: Simulation Model Converter dialog box missing documentation for some items
    182510In some cases, VI does not break wire on simulation diagram
    184542Documentation: EMI_GetCurrentVersion function not documented
    188235Documentation: Documentation does not match the input of CD Draw Model Equation VI
    191403Vector instances of Buffer XY Graphs have problems with long histories
    191430Error 1357 when running Simulation Model Converter twice without closing
    192535Choosing "Config page only" for EMI Parameters still allows parameters to come from terminals
    193893Documentation: Finalization step for SubVI node setup is treated as a minor step
    195465Cannot synchronize Control & Simulation Loop to timing source on ARM
    198784Control & Simulation Loop priority cannot be 0
    198882Converter: Control & Simulation Loop created from Simulation Model Converter returns error -820 when used with hardware timing
    205013Transfer Function returns error -2381 for Model Numerator = [0] and Denominator = [1]
    214160Right-clicking the Input Node of a Control & Simulation Loop and selecting "Remove Input" causes error
    214904Documentation: MathScript: Help for Control Design classes not available
    216739Subsystem does not appear broken when opened with a missing a subVI
    219640MathScript: Bode (num, den) does not work
    221138MIMO State-Space Function does not Recover from NaN input even after reinitializing execution
    224821Documentation: Document limit on Control & Simulation Loop "Priority Range" (1 to 65535)
    232863Example of iopzgraph does not generate plot correctly
    Important Information
    © 2010 National Instruments Corporation. All rights reserved.
    Simulink® is the registered trademark of The MathWorks, Inc.
    GMT+8, 2026-4-1 12:54
