查看: 7782|回复: 1
[LV工具模块] LabVIEW 2018 Analytics and Machine Learning Toolkit Win32Eng LV分析和机器学习工具包AML2018
    2 小时前
  • 签到天数: 3790 天
    连续签到: 41 天
    发表于 2020-7-18 17:47:14 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW分析和机器学习工具包将预测分析和机器学习集成到LabVIEW中。
    LabVIEW分析和机器学习工具包(LabVIEW Analytics and Machine Learning Toolkit)包含用于训练机器学习模型的虚拟仪器,可通过异常检测和分类以及聚类算法,从大量数据中识别出模式(pattern)。这些模型可以识别NI Linux Real-Time和Microsoft Windows硬件上的新数据模式。该工具包适用于状态监测和预测性维护应用,并提供入门指南和真实示例。注册商标Linux的使用获得了Linus Torvalds专属授权商LMI的再授权,Linus Torvalds拥有Linux注册商标在全球范围内的所有权。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    请注册登录视觉论坛会员,购买附件查看
    AML2018.txt (297 Bytes, 下载次数: 15, 售价: 10 圆)
    LabVIEW 2018 Analytics and Machine Learning Toolkit Readme
    July 2018
    This file contains important information about the LabVIEW 2018 Analytics and Machine Learning Toolkit, including system requirements, installation instructions, and new features.
    The Analytics and Machine Learning Toolkit includes VIs for training machine learning models to discover patterns in large amounts of data. You can deploy trained machine learning models to detect anomalies, recognize patterns, or make predictions in new data.
    In addition to the system requirements for the LabVIEW Development System, the Analytics and Machine Learning Toolkit has the following requirements:
    • LabVIEW 2018 Full or Professional Development System
    • At least 1 GB of disk space
    • 1 GB RAM
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2018.
    The Analytics and Machine Learning Toolkit supports the following operating systems:
    • Windows 10 (version 1709)/8.1 Update1/7 SP12
    Double-click the setup.exe file in the root directory of the Analytics and Machine Learning Toolkit installer and follow the instructions on the screen to install the Analytics and Machine Learning Toolkit.
    The LabVIEW 2018 Analytics and Machine Learning Toolkit includes the following new features:
    • Support for LabVIEW 2018 (64-bit)
    • Improvements to VIs that allow performing batch training when you have a large number of data files. Refer to the Analytics and Machine Learning Toolkit»Getting Started with Machine Learning topic on the Contents tab in the LabVIEW Help for more information about batch training.
    Enhancements to Analytics and Machine Learning VIs
    The Analytics and Machine Learning VIs have the following changes:
    • The Load Data (2D Array) VI includes the load data mode input, which specifies how the VI loads data.
    • The following VIs include the Batch polymorphic instance, which allows you to perform batch training when you have a large training data set.
      • Initialize Anomaly Detection Model (GMM-CV) VI
      • Initialize Anomaly Detection Model (PCA T2Q) VI
      • Initialize Anomaly Detection Model (SOM-MQE) VI
      • Normalize VI
      • PCA VI
      • Train Anomaly Detection Model VI
    The Analytics and Machine Learning Toolkit supports all NI Linux Real-Time hardware models. For more information about NI Linux Real-Time hardware models, visit ni.com/info and enter the Info Code exxjax.
    Refer to the LabVIEW Help, accessible from Help»LabVIEW Help in LabVIEW, for information about the Analytics and Machine Learning Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»Analytics and Machine Learning folder to access the examples.
    © 2017–2018 National Instruments. All rights reserved.
    377061B-01
    GMT+8, 2026-2-1 23:46
