查看: 2986|回复: 0
[LV工具模块] LabVIEW 2012 VI Analyzer Toolkit Win32Eng LV2012VI分析仪工具包2012VIA
  • 签到天数: 3843 天
    连续签到: 36 天
    发表于 2020-7-15 16:51:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW VI分析工具包用于进行静态代码分析,以提高LabVIEW代码的质量和可读性。
    LabVIEW VI分析仪工具包是一个LabVIEW附加软件,用于优化LabVIEW图形化代码。借助该工具,您可以配置超过90种内置测试,以便自动化审核代码和分析应用程序中所有VI的静态代码,或者您可以使用测试创建向导来自行创建测试程序。LabVIEW VI分析工具包提供的调试工具可帮助您避免使用可能会影响应用程序性能、功能和可维护性的编程技术。此外,您还可以要求开发团队采用高效的编程方法和代码风格,以确保代码的可读性和功能性。
    百度网盘下载(限速,请开会员或使用破解限速工具):
    EXE版和ZIP版内容一样,EXE为NI当年发行版,ZIP为NI后期重新压制版本。
    EXE版:
    ZIP版:
    EXE版:
    请注册登录视觉论坛会员,购买附件查看
    ZIP版:
    请注册登录视觉论坛会员,购买附件查看
    VIA2012.txt (527 Bytes, 下载次数: 2, 售价: 10 圆)
    LabVIEW 2012 VI Analyzer Toolkit Readme
    Version 12.0.0
    June 2012
    This file contains important information about the LabVIEW VI Analyzer Toolkit, including installation instructions and known issues.
       Mac OS X
       Linux
    Using the VI Analyzer Toolkit
    Additions to the LabVIEW Help
    Using Spell Check Word List
    In addition to the system requirements for the LabVIEW Development System, the VI Analyzer Toolkit has the following requirement:
    • LabVIEW 2012 Base, Full, or Professional Development System (32-bit)
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2012.
    Installation InstructionsWindows
    You can install all of your LabVIEW products—including the VI Analyzer Toolkit—using the LabVIEW 2012 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments website.
    Mac OS X
    Complete the following steps to install the LabVIEW VI Analyzer Toolkit on Mac OS X.
    Note  Disable any automatic virus detection programs before you install because some virus detection programs may interfere with the installer. After installation, check your computer for viruses and enable any virus detection programs you disabled.
    • Insert and browse to the LabVIEW 2012 VI Analyzer Toolkit installation CD.
    • Open LabVIEW2012VIAnalyzer.mpkg, located in the LabVIEW_2012\Mac OS X directory.
    Complete the following steps to uninstall the LabVIEW 2012 VI Analyzer Toolkit on Mac OS X.
    • During installation, the VI_Analyzer_2012_Uninstall.sh uninstallation script is created in the VI Analyzer directory. Drag the VI_Analyzer_2012_Uninstall.sh uninstallation script to the prompt in a Terminal window.
    • Press Return and follow the instructions provided by the script.
    • After uninstalling the VI Analyzer Toolkit, manually delete the uninstallation script.
    Linux
    Complete the following steps to install the LabVIEW VI Analyzer Toolkit on Linux.
    • Insert the LabVIEW 2012 VI Analyzer Toolkit installation CD.
    • From the Terminal window, navigate to the LabVIEW_2012/Linux directory on the installation CD.
      ./INSTALL
    Note  If you encounter a message of bad interpreter: Permission denied, the CD might not have mounted with executable permissions. To work around this issue, enter the following command:
    /bin/sh ./INSTALL
    After you install the VI Analyzer Toolkit, select Tools»VI Analyzer»Analyze VIs in LabVIEW to run the VI Analyzer. You also can use the VI Analyzer VIs, located on the Functions palette. Refer to the LabVIEW Help and the LabVIEW VI Analyzer Toolkit User Guide for more information about using the VI Analyzer Toolkit.
    The VIAn Get Tests VI includes a Test Descriptions output that returns an array of the test descriptions, which correspond to the names in Test Names.
    For a list of the copyrights, conditions, and disclaimers regarding the word list used in the automatically generated inflection database, refer to the AGID_4.0_notice.pdf and AGID_4.0_license.pdf files in the Licenses directory on the VI Analyzer Toolkit installation media.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the LabVIEW 2012 VI Analyzer Toolkit.
    The following table contains the IDs and titles of a subset of issues fixed in the LabVIEW 2012 VI Analyzer Toolkit. This table is not an exhaustive list of issues fixed in the current version of the VI Analyzer Toolkit. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    IDLegacy IDFixed Issue
    300708VI Analyzer Panel Size and Position test returns an error on blank VIs
    302260Error for window bounds in failure message doesn't give the specific bounds that need adjustment
    305580Scalar Chart Updates Test Doesn't Catch "Value" property usage on non-English LabVIEW
    307530VI Analyzer is unable to recognize and report a default icon
    Important Information
    © 2005–2012 National Instruments. All rights reserved.
    GMT+8, 2026-4-1 10:53
