查看: 2923|回复: 0
[LV工具模块] LabVIEW 2017 Desktop Execution Trace Toolkit Win32/64ENG LabVIEW2017桌面执行跟踪工具包DETT2017
  • 签到天数: 3843 天
    连续签到: 36 天
    发表于 2020-7-13 23:55:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    DETT2015版本之前的版本,仅适用32位的LabVIEW,DETT2016版本之后的版本,则32位和64位同时适配,但是仅一个安装文件,不另外区分安装版本。
    LabVIEW桌面执行跟踪工具包可以帮助您执行高级调试所需的动态代码分析。
    LabVIEW桌面执行跟踪工具包可以在运行时跟踪LabVIEW VI在Windows系统中的执行情况,以检测和定位代码中可能会影响性能或导致意外行为的问题。该工具包提供了VI事件、队列操作、参考泄漏、内存分配、未处理的错误和子VI执行的时间顺序图。借助这个工具包,即可根据LabVIEW程序的框图,通过编程方式生成用户定义的事件。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版和ZIP版内容一样,EXE为NI当年发行版,ZIP为NI后期重新压制版本。
    EXE版:
    ZIP版:
    EXE版:
    请注册登录视觉论坛会员,购买附件查看
    ZIP版:
    请注册登录视觉论坛会员,购买附件查看
    DETT2017.txt (529 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2017 Desktop Execution Trace Toolkit for Windows Readme
    June 2017
    This file contains important information about the LabVIEW 2017 Desktop Execution Trace Toolkit for Windows, including system requirements, installation instructions, and known issues.
    The Desktop Execution Trace Toolkit for Windows captures execution data from LabVIEW applications running on the desktop. The toolkit displays the data it captures, called trace data, as events in a table pane that you can browse, save, or export to a text file. For each execution event, the table pane displays the type of event, the time the event occurs, the VI in which the event occurs, and any additional details that are available. Use trace data to debug and optimize large LabVIEW applications, including those with multiple loops, client-server architectures, dynamically loaded VIs, and so on.
    In addition to the system requirements for the LabVIEW Development System, the Desktop Execution Trace Toolkit has the following requirements:
    • One of the following versions of LabVIEW Base, Full, or Professional Development System:
      • 2014 (32-bit)
      • 2015 (32-bit)
      • 2016 (32-bit or 64-bit)
      • 2017 (32-bit or 64-bit)
    • Pentium 4 processor or equivalent
    • At least 1 GB of disk space
    Note  The LabVIEW 2017 Professional Development System license activates the LabVIEW 2017 Desktop Execution Trace Toolkit.
    The Desktop Execution Trace Toolkit supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2016 the Desktop Execution Trace Toolkit dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2017 Desktop Execution Trace Toolkit will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2017 Desktop Execution Trace Toolkit to an unsupported OS. Additionally, after installing the LabVIEW Desktop Execution Trace Toolkit, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    You can install all of your LabVIEW products—including the Desktop Execution Trace Toolkit—using the LabVIEW 2017 Platform media.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the LabVIEW 2017 Desktop Execution Trace Toolkit.
    Refer to the LabVIEW Help, accessible from Help»LabVIEW Help from LabVIEW, for information about the Desktop Execution Trace Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»Desktop Execution Trace folder to access the examples. You also can find the examples for the Desktop Execution Trace Toolkit in the labview\examples\Desktop Execution Tracedirectory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    © 2008–2017 National Instruments. All rights reserved.
    375337C-01
    GMT+8, 2026-4-1 11:07
