查看: 2677|回复: 0
[LV工具模块] LabVIEW 2014 Desktop Execution Trace Toolkit Win32ENG LabVIEW2014桌面执行跟踪工具包DETT2014
    2 小时前
  • 签到天数: 3563 天
    连续签到: 8 天
    发表于 2020-7-13 23:46:29 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    DETT2015版本之前的版本,仅适用32位的LabVIEW,DETT2016版本之后的版本,则32位和64位同时适配,但是仅一个安装文件,不另外区分安装版本。
    LabVIEW桌面执行跟踪工具包可以帮助您执行高级调试所需的动态代码分析。
    LabVIEW桌面执行跟踪工具包可以在运行时跟踪LabVIEW VI在Windows系统中的执行情况,以检测和定位代码中可能会影响性能或导致意外行为的问题。该工具包提供了VI事件、队列操作、参考泄漏、内存分配、未处理的错误和子VI执行的时间顺序图。借助这个工具包,即可根据LabVIEW程序的框图,通过编程方式生成用户定义的事件。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版和ZIP版内容一样,EXE为NI当年发行版,ZIP为NI后期重新压制版本。
    EXE版:
    ZIP版:
    EXE版:
    请注册登录视觉论坛会员,购买附件查看
    ZIP版:
    请注册登录视觉论坛会员,购买附件查看
    DETT2014.txt (529 Bytes, 下载次数: 2, 售价: 10 元)
    LabVIEW 2014 Desktop Execution Trace Toolkit for Windows Readme
    Version 14.0.0
    June 2014
    This file contains important information about the LabVIEW Desktop Execution Trace Toolkit for Windows, including installation instructions, a partial list of bugs fixed for the Desktop Execution Trace Toolkit 2014, and known issues.
    The LabVIEW Desktop Execution Trace Toolkit for Windows captures execution data from LabVIEW applications running on the desktop. The toolkit displays the data it captures, called trace data, as events in a table pane that you can browse, save, or export to a text file. For each execution event, the table pane displays the type of event, the time the event occurs, the VI in which the event occurs, and any additional details that are available. Use trace data to debug and optimize large LabVIEW applications, including those with multiple loops, client-server architectures, dynamically loaded VIs, and so on.
    In addition to the system requirements for the LabVIEW Development System, the Desktop Execution Trace Toolkit has the following requirements:
    • LabVIEW 2011 Base, Full, or Professional Development System (32-bit) or later
    • At least 1 GB of disk space
    • Pentium 4 processor or equivalent
    You can install all of your LabVIEW products—including the Desktop Execution Trace Toolkit—using the LabVIEW 2014 Platform media. Refer to the LabVIEW Installation Guide on the LabVIEW Platform media for installation instructions and system requirements.
    To request additional LabVIEW Platform media, refer to the National Instruments website.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Desktop Execution Trace Toolkit.
    The following items are the IDs and titles of a subset of issues fixed in the Desktop Execution Trace Toolkit. This is not an exhaustive list of issues fixed in the current version of the Desktop Execution Trace Toolkit. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    412912LabVIEW crashes when the VI under trace contains a string control wired to the Generate User-Defined Trace Event function
    413502The Desktop Execution Trace Toolkit does not accurately identify creation/destruction of data value references
    Refer to the LabVIEW Desktop Execution Trace Toolkit for Windows Help, accessible by selecting File»Help»Launch Help, for information about the Desktop Execution Trace Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»Desktop Execution Trace folder to access the example. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for the Desktop Execution Trace Toolkit in the labview\examples\Desktop Execution Trace directory.
    Using NI Launcher
    Finding All Programs
    NI LabVIEW Desktop Execution Trace Toolkit for Windows Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Desktop Execution Trace Toolkit for Windows will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of the Desktop Execution Trace Toolkit that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2008–2014 National Instruments. All rights reserved.
    For patents covering the National Instruments products/technology, refer to the appropriate location: the patents.txt file on your media or the National Instruments Patent Notice at ni.com/patents.
    举报
    GMT+8, 2025-6-10 11:23
