查看: 2426|回复: 0
[LV工具模块] LabVIEW 2010 Advanced Signal Processing Toolkit Win64ENG LabVIEW2010高级信号处理工具包ASPT2010-64 64位Windows英语测试版
    7 小时前
  • 签到天数: 3528 天
    发表于 2020-7-12 21:01:56 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    ASPT工具包,在2009到2017年版本之间,有64位的测试版,但是NI官方一直到APST2018才正式发布64位版本。我方视觉论坛提供了ASPT2009-APST2017的64位版本下载。具体的可在本论坛搜索相应的版本。
    LabVIEW高级信号处理工具包是一组软件工具,可用于执行时频分析、时序分析和小波分析。
    LabVIEW高级信号处理工具包是LabVIEW的一个附加软件,提供有时频分析、时序分析和小波分析工具。该附加工具内含LabVIEW数字滤波器设计工具包,您可单独购买这一工具包。为了有效地提取信号隐藏的信息,应选择适当的分析工具。您可以将时频分析工具用于具有缓慢变化的光谱内容的进化信号,用于静止信号的时间序列分析工具,以及用于描述短时事件的进化信号和瞬态信号的小波分析工具。您还可以将分析代码部署到NI实时嵌入式硬件。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    请注册登录视觉论坛会员,购买附件查看
    ASPT2010-64.txt (239 Bytes, 下载次数: 1, 售价: 10 元)
    NI LabVIEW 2010 (64-bit) Advanced Signal Processing Toolkit Readme
    February 2011
    Note: The software technology available on NI Labs is experimental and has not yet been released for large-scale commercial use or fully tested by NI. Refer to ni.com/labs for more information about NI Labs products.
    The LabVIEW 2010 Advanced Signal Processing Toolkit (64-bit) is an NI Labs product. This file contains information to introduce you to the Advanced Signal Processing Toolkit (64-bit). This file also provides you with help resources you can use while working with the Advanced Signal Processing Toolkit (64-bit). The file contains the following information that you need to understand.
    New Features and Changes
    Activation Notice
    Uninstallation Instructions
    The LabVIEW 2010 Advanced Signal Processing Toolkit (64-bit) is the upgrade version of the LabVIEW 2009 Advanced Signal Processing Toolkit (64-bit). The Advanced Signal Processing Toolkit (64-bit) provides VIs for time frequency analysis, time series analysis, and wavelet analysis.
    Use the Time Frequency Analysis VIs to transform a time domain signal to a linear or quadratic time-frequency domain representation. You can extract useful information from the time-frequency domain representation of a signal, or you can process a time-frequency domain representation and reconstruct a time domain signal.
    Use the Time Series Analysis VIs to perform preprocessing, statistical analysis, correlation analysis, spectrum estimation, and model estimation on a univariate or multivariate (vector) time series. You can extract useful information from the time series with different analysis methods for different applications.
    Use the Wavelet Analysis VIs to perform transforms and inverse transforms between a signal and the wavelet coefficients of the signal. You can use the Feature Extraction VIs to perform denoising, detrending, probability density function estimation, peak detection, edge detection, and ridge detection on a 1D or 2D signal.
    • This version includes the following new VIs:
      • TSA Bicoherence—Use this VI to compute the bicoherence of a univariate time series.
      • WA Set Coefficients of Discrete Wavelet Transform—Use this VI to set specific coefficients that you compute from the discrete wavelet transform.
      • WA Set Coefficients of Integer Wavelet Transform—Use this VI to set specific coefficients that you compute from the integer wavelet transform.
      • WA Set Coefficients of Undecimated Wavelet Transform—Use this VI to set specific coefficients that you compute from the undecimated wavelet transform.
      • WA Online Detrend—Use this VI to remove the trend from 1D streaming signals by setting the approximation coefficients to zeros.
      • WA Online Multiscale Peak Detection—Use this VI to detect peaks or valleys in a streaming signal.
    • This version includes the following changed VIs:
      • TSA Bispectrum—This VI includes the following new or changed parameters that enable this VI to examine whether the phase components at specific frequencies are coupled.
        • initialize? (F) specifies whether the input block of data is the first block.
        • averaging parameters specifies how this VI computes the averaging.
        • averaging done? returns whether the averaging process is complete.
        • length specifies the length of the sliding window that divides the time series into subsequences.
        • frequency bins specifies the number of frequency bins for which this VI computes the bispectrum.
      • TSA MUSIC—The default value for noise subspace is –1, which means this VI calculates an appropriate value for noise subspace.
      • WA Multiscale Peak Detection—Use this VI to detect peaks or valleys in an offline signal.
      • TFA Dual Window—In previous versions, this VI contains the transform info and expansion info outputs. In this version, these outputs are replaced by the analysis info and synthesis info outputs.
      • Dual Window—In previous versions, this Express VI contains the transform info and expansion info outputs. In this version, these outputs are replaced by the analysis info and synthesis info outputs.
      • TFA Read from File, TSA Read from File, and WA Read from File—These VIs contain the number of rows, start of read offset, and delimiters inputs. Use the number of rows input to specify the maximum number of rows in a spreadsheet text file. Use the start of read offset input to specify the position in the file, measured in rows, to begin reading. Use the delimiters input to specify an array of strings used to separate fields in a spreadsheet text file.
      • WA Arbitrary Path Reconstruction—In previous versions, this VI contains the source input. In this version, this input is replaced by the source coefficients input. Use the source coefficients input to specify the coefficients for reconstructing a time waveform.
    Refer to the LabVIEW Help for more information about using these VIs.
    The computer you are using must meet the following minimum system requirements to run the Advanced Signal Processing Toolkit (64-bit):
    • Windows 7 64-bit/Vista 64-bit/XP x641
    • 200 MB free disk space
    • LabVIEW 2010 Full or Professional Development System (64-bit)
    1NI driver support for Windows XP x64 is limited.
    You can install the Advanced Signal Processing Toolkit (64-bit) by downloading and running the NI LabVIEW 2010 (64-bit) Advanced Signal Processing Toolkit Installer from ni.com/labs.
    Activation Notice
    The Advanced Signal Processing Toolkit (64-bit) relies on licensing activation. You must activate a valid NI LabVIEW 2010 (32-bit) Advanced Signal Processing Toolkit license in order to activate your copy of the Advanced Signal Processing Toolkit (64-bit) after the 30 day evaluation period expires.
    Refer to the LabVIEW Release Notes, which are available in your LabVIEW software kit, for more information about licensing in LabVIEW.
    Complete the following steps to uninstall the Advanced Signal Processing Toolkit (64-bit).
    • Open the Add or Remove Programs dialog box from the Control Panel.
    • Select National Instruments Software and click the Change button.
    • Under NI Products, select NI LabVIEW 2010 (64-bit) Advanced Signal Processing Toolkit and click the Remove button.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from the pull-down menu in LabVIEW, for information about using the Advanced Signal Processing Toolkit (64-bit).
    You can access the examples for the Time Frequency Analysis Tools, the Time Series Analysis Tools, and the Wavelet Analysis Tools by selecting Help»Find Examples to display the NI Example Finder and then navigating to the Toolkits and Modules»Time Frequency Analysis, Toolkits and Modules»Time Series Analysis, and Toolkits and Modules»Wavelet Analysis folders, respectively. You also can click the Find Examples link in the Examples section of the Getting Started window to display the NI Example Finder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for the Time Frequency Analysis Tools, the Time Series Analysis Tools, and the Wavelet Analysis Tools in the labview\examples\time frequency analysis, labview\examples\time series analysis, and labview\examples\wavelet analysis folders, respectively.
    Known IssuesWindows 7 Issues
    National Instruments is committed to maintaining compatibility with Microsoft Windows technology changes. However, NI has become aware of a number of issues of potential significance regarding Microsoft Windows 7. To learn how Windows 7 affects your use of NI products, visit ni.com/info and enter the info code windows7.
    Example VIs Issues
    You cannot run the following Example VIs in the Advanced Signal Processing Toolkit (64-bit):
    • Online Pitch Shifting.vi
    • Voice Enhancement.vi
    • Group Delay.vi
    • Online Spectrogram Monitoring (Sound Card).vi
    • Beam Crack Detection.vi
    • Modal Analysis of a Plate.vi
    • Bispectrum Analysis.vi
    Important Information
    © 2011 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-4-29 15:48
