查看: 6103|回复: 3
[LV工具模块] LabVIEW 2020 Advanced Signal Processing Toolkit Win32ENG LabVIEW2020高级信号处理工具包ASPT2020 32位Windows英语版
    12 小时前
  • 签到天数: 3843 天
    连续签到: 36 天
    发表于 2020-7-12 20:52:44 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    ASPT工具包,在2009到2017年版本之间,有64位的测试版,但是NI官方一直到APST2018才正式发布64位版本。我方视觉论坛提供了ASPT2009-APST2017的64位版本下载。具体的可在本论坛搜索相应的版本。
    LabVIEW高级信号处理工具包是一组软件工具,可用于执行时频分析、时序分析和小波分析。
    LabVIEW高级信号处理工具包是LabVIEW的一个附加软件,提供有时频分析、时序分析和小波分析工具。该附加工具内含LabVIEW数字滤波器设计工具包,您可单独购买这一工具包。为了有效地提取信号隐藏的信息,应选择适当的分析工具。您可以将时频分析工具用于具有缓慢变化的光谱内容的进化信号,用于静止信号的时间序列分析工具,以及用于描述短时事件的进化信号和瞬态信号的小波分析工具。您还可以将分析代码部署到NI实时嵌入式硬件。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    请注册登录视觉论坛会员,购买附件查看
    ASPT2020.txt (319 Bytes, 下载次数: 18, 售价: 10 圆)
    LabVIEW 2020 Advanced Signal Processing Toolkit Readme
    March 2020
    This file contains important information about the LabVIEW Advanced Signal Processing Toolkit, including system requirements, installation instructions, and known issues.
    LabVIEW Advanced Signal Processing Toolkit (64-bit)
    Activation Notice
    Advanced Signal Processing Toolkit Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    The Advanced Signal Processing Toolkit provides VIs for time frequency analysis, time series analysis, wavelet analysis, and system identification.
    Use the Time Frequency Analysis VIs to transform a time domain signal to a linear or quadratic time-frequency domain representation. You can extract useful information from the time-frequency domain representation of a signal, or you can process a time-frequency domain representation and reconstruct a time domain signal.
    Use the Time Series Analysis VIs to perform preprocessing, statistical analysis, correlation analysis, spectrum estimation, and model estimation on a univariate or multivariate (vector) time series. You can extract useful information from the time series with different analysis methods for different applications.
    Use the Wavelet Analysis VIs to perform transforms and inverse transforms between a signal and the wavelet coefficients of the signal. You can use the Feature Extraction VIs to perform denoising, detrending, probability density function estimation, peak detection, edge detection, and ridge detection on a 1D or 2D signal.
    Use the System Identification VIs to preprocess raw data from a dynamic system and develop a model that reflects the behavior of that system. You can analyze the response of a dynamic system to a certain stimulus.
    The Advanced Signal Processing Toolkit also provides the System Identification Assistant. Use the System Identification Assistant to identify the characteristics of a system through signal processing and mathematics. Refer to the System Identification Assistant Readme for important information about the System Identification Assistant, including system requirements, installation instructions, and known issues.
    In addition to the system requirements for the LabVIEW Development System, the Advanced Signal Processing Toolkit has the following requirements:
    • LabVIEW 2020 Full or Professional Development System
    • At least 600 MB of disk space
    • (System Identification Assistant) SignalExpress
    The Advanced Signal Processing Toolkit supports the following operating systems:
    • Windows 10 (version 1909)/8.1 Update 11/7 SP12
    Note
    • Refer to Advanced Signal Processing Toolkit Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    • In 2016 the Advanced Signal Processing Toolkit dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW Advanced Signal Processing Toolkit will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW Advanced Signal Processing Toolkit to an unsupported OS. Additionally, after installing the LabVIEW Advanced Signal Processing Toolkit, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    • Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/r/PAESupport.
    The Advanced Signal Processing Toolkit (64-bit) provides access to more memory than the Advanced Signal Processing Toolkit (32-bit) can provide. The Advanced Signal Processing Toolkit (64-bit) does not support the System Identification Assistant.
    NI installs the Advanced Signal Processing Toolkit using NI Package Manager. If you do not already have NI software installed, the Advanced Signal Processing Toolkit installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    You can also install LabVIEW and the Advanced Signal Processing Toolkit using the LabVIEW Platform media. To request additional LabVIEW Platform media, refer to the NI website.
    Notes  If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
    Installation Instructions for the System Identification Assistant
    To install the System Identification Assistant, you must install SignalExpress before you install the Advanced Signal Processing Toolkit. Refer to the System Identification Assistant Readme for additional installation instructions for the System Identification Assistant.
    Activation Notice
    Log in to your NI User Account to activate your NI products. If you are managing your license with a volume license server, you should receive your volume license file by email. The license that activates the LabVIEW Advanced Signal Processing Toolkit also activates the LabVIEW System Identification Assistant and the LabVIEW Digital Filter Design Toolkit.
    Your purchase of the Advanced Signal Processing Toolkit enables you to use the LabWindows™/CVI™ Advanced Signal Processing Toolkit. To request the installation media for the LabWindows/CVI Advanced Signal Processing Toolkit, contact NI.
    You can access the software and documentation known issues list online. Visit ni.com/r/lv2020toolkitski for an up-to-date list of known issues in LabVIEW Advanced Signal Processing Toolkit.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Advanced Signal Processing Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. The following table lists the examples for the Advanced Signal Processing Toolkit and the directory which contains the examples.
    Examples
    Directory
    Time Frequency Analysislabview\examples\Time Frequency Analysis
    Time Series Analysislabview\examples\Time Series Analysis
    Wavelet Analysislabview\examples\Wavelet Analysis
    System Identificationlabview\examples\System Identification
    You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The Advanced Signal Processing Toolkit will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2005–2020 National Instruments. All rights reserved.
    375335G-01
  • 签到天数: 5 天
    连续签到: 3 天
    发表于 2022-11-14 14:23:05 | 显示全部楼层 来自:辽宁省大连市 联通
    12 小时前
  • 签到天数: 3843 天
    连续签到: 36 天
     楼主| 发表于 2022-11-14 15:54:26 | 显示全部楼层 来自:广东省东莞市 电信
    daai 发表于 2022-11-14 14:23
    LabVIEW 2020 Advanced Signal Processing Toolkit 哪里能下载?
    购买主题txt附件,查看下载地址
    GMT+8, 2026-4-1 12:56
