LabVIEW 2013 Advanced Signal Processing Toolkit Win32ENG LabVIEW2012高级信号处理工具包ASPT2013 32位Windows英语版
ASPT工具包,在2009到2017年版本之间,有64位的测试版,但是NI官方一直到APST2018才正式发布64位版本。我方视觉论坛提供了ASPT2009-APST2017的64位版本下载。具体的可在本论坛搜索相应的版本。
LabVIEW高级信号处理工具包是一组软件工具,可用于执行时频分析、时序分析和小波分析。
LabVIEW高级信号处理工具包是LabVIEW的一个附加软件,提供有时频分析、时序分析和小波分析工具。该附加工具内含LabVIEW数字滤波器设计工具包,您可单独购买这一工具包。为了有效地提取信号隐藏的信息,应选择适当的分析工具。您可以将时频分析工具用于具有缓慢变化的光谱内容的进化信号,用于静止信号的时间序列分析工具,以及用于描述短时事件的进化信号和瞬态信号的小波分析工具。您还可以将分析代码部署到NI实时嵌入式硬件。
百度网盘下载地址(限速,请开会员或使用破解限速工具):
EXE版和ZIP版内容一样,EXE为NI当年发行版,ZIP为NI后期重新压制版本。
EXE版:
ZIP版:
EXE版:
请注册登录视觉论坛会员,购买附件查看
ZIP版:
请注册登录视觉论坛会员,购买附件查看
ASPT2013.txt
(527 Bytes, 下载次数: 0, 售价: 10 圆)
LabVIEW 2013 Advanced Signal Processing Toolkit ReadmeVersion 13.0.0 June 2013 The LabVIEW 2013 Advanced Signal Processing Toolkit updates the Advanced Signal Processing Toolkit 2012 to support LabVIEW 2013. This release is a maintenance release. This file contains the following information about the Advanced Signal Processing Toolkit. Overview System Requirements Installation Instructions Activation Notice Known Issues Accessing the Help Finding Examples Automating the Installation of NI Products How to Use NI Software with Microsoft Windows 8 NI Software Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 OverviewThe Advanced Signal Processing Toolkit provides VIs for time frequency analysis, time series analysis, and wavelet analysis. Use the Time Frequency Analysis VIs to transform a time domain signal to a linear or quadratic time-frequency domain representation. You can extract useful information from the time-frequency domain representation of a signal, or you can process a time-frequency domain representation and reconstruct a time domain signal. Use the Time Series Analysis VIs to perform preprocessing, statistical analysis, correlation analysis, spectrum estimation, and model estimation on a univariate or multivariate (vector) time series. You can extract useful information from the time series with different analysis methods for different applications. Use the Wavelet Analysis VIs to perform transforms and inverse transforms between a signal and the wavelet coefficients of the signal. You can use the Feature Extraction VIs to perform denoising, detrending, probability density function estimation, peak detection, edge detection, and ridge detection on a 1D or 2D signal. System RequirementsIn addition to the system requirements for the LabVIEW Development System, the Advanced Signal Processing Toolkit has the following requirements: - LabVIEW 2013 Full or Professional Development System (32-bit)
- At least 200 MB of disk space
Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2013. Installation InstructionsYou can install all of your LabVIEW products—including the Advanced Signal Processing Toolkit—using the LabVIEW 2013 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements. To request additional LabVIEW Platform DVDs, refer to the National Instruments website. Note If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product. Advanced Signal Processing Toolkit Updates and NotificationsNational Instruments posts information about critical updates and security notifications on ni.com. Visit ni.com/info and enter Info Code updates to access this information. Activation NoticeTo activate the Advanced Signal Processing Toolkit, use the serial number you received with the software kit. You can find your serial number on the product packing slip or on the shipping label. The serial number activates the LabVIEW Advanced Signal Processing Toolkit and the LabVIEW Digital Filter Design Toolkit. Your purchase of the Advanced Signal Processing Toolkit enables you to use the LabWindows™/CVI™ Advanced Signal Processing Toolkit. To request the installation media for the LabWindows/CVI Advanced Signal Processing Toolkit, contact NI. Known IssuesYou can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Advanced Signal Processing Toolkit. Accessing the HelpRefer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Advanced Signal Processing Toolkit. Finding ExamplesSelect Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»Time Frequency Analysis, Toolkits and Modules»Time Series Analysis, and Toolkits and Modules»Wavelet Analysis folders to access the examples. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create. You also can find the example for the Time Frequency Analysis Tools, the Time Series Analysis Tools, and the Wavelet Analysis Tools in the labview\examples\time frequency analysis, labview\examples\time series analysis, and labview\examples\wavelet analysis directories, respectively. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. However, starting with the August 2012 releases (products using NI Installers version 3.1 or later), you may need to perform additional steps before or during a silent installation of NI software. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information, refer to the following KnowledgeBase articles: - For more information on silent installations of individual NI products, refer to KB 4CJDP38M, Automating the Installation of a Single Installer.
- For more information on silent installations of suited NI products, such as NI Developer Suite, refer to KB 4GGGDQH0, Automating the Installation of a Suited Installer.
How to Use NI Software with Microsoft Windows 8When you install National Instruments software on Microsoft Windows 8, you will notice a few additional tiles on the Start screen, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (MAX), and the new NI Launcher. Using NI LauncherNI Launcher helps you find and launch installed NI products. It provides you with a method of finding NI products similar to the Start menu in previous versions of Microsoft Windows. To use NI Launcher, click the NI Launcher tile on the Start screen. NI Launcher launches the desktop and opens a menu containing a list of NI products. Click any NI product to launch it. | Note MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8. You can launch MAX either from the Start screen or from within NI Launcher. | Pinning Frequently Used ApplicationsFor convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary: | Current Application | Icon Location | Pin to Action | | Windows 8 Desktop | Desktop Taskbar | Right-click application and select Pin to Taskbar | | Windows 8 Desktop | Start screen | Right-click application and select Pin to Start | | Windows 8 Start screen | Desktop Taskbar | Right-click application and select Pin to taskbar from the menu bar on the bottom of the screen | Finding All ProgramsIf you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files by right-clicking anywhere on the Start screen and selecting All apps. A list of all installed software and related files appears, in alphabetical order by creator or type. For more information about NI support for Windows 8, visit ni.com/windows8. NI LabVIEW Advanced Signal Processing Toolkit Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016National Instruments LabVIEW Advanced Signal Processing Toolkit will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of the Advanced Signal Processing Toolkit that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes: | Product | Info Code | | NI LabVIEW | lifecycle | | NI LabWindows™/CVI™ | cvi_lifecycle | | NI Measurement Studio | mstudiolifecycle | | NI TestStand | tslcp | | NI DIAdem | ddlcp | | NI SignalExpress | selcp | | NI VeriStand | nivslifecycle |
Important InformationCopyright © 2005–2013 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. National Instruments respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on National Instruments trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents
For patents covering the National Instruments products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patents. |
