TA的每日心情 | 怒 1 小时前 |
签到天数: 3696 天 连续签到: 23 天 [LV.Master]2000FPS
发表于 2020-7-12 18:49:56
来自:广东省东莞市 联通
LabVIEW 2011 Advanced Signal Processing Toolkit Win64ENG LabVIEW2011高级信号处理工具包ASPT2011-64 64位Windows英语测试版
ASPT工具包,在2009到2017年版本之间,有64位的测试版,但是NI官方一直到APST2018才正式发布64位版本。我方视觉论坛提供了ASPT2009-APST2017的64位版本下载。具体的可在本论坛搜索相应的版本。
LabVIEW高级信号处理工具包是一组软件工具,可用于执行时频分析、时序分析和小波分析。
LabVIEW高级信号处理工具包是LabVIEW的一个附加软件,提供有时频分析、时序分析和小波分析工具。该附加工具内含LabVIEW数字滤波器设计工具包,您可单独购买这一工具包。为了有效地提取信号隐藏的信息,应选择适当的分析工具。您可以将时频分析工具用于具有缓慢变化的光谱内容的进化信号,用于静止信号的时间序列分析工具,以及用于描述短时事件的进化信号和瞬态信号的小波分析工具。您还可以将分析代码部署到NI实时嵌入式硬件。
百度网盘下载地址(限速,请开会员或使用破解限速工具):
请注册登录视觉论坛会员,购买附件查看
ASPT2011-64.txt
(227 Bytes, 下载次数: 0, 售价: 10 圆)
无Readme自述文件可查阅
Description:
The LabVIEW 2011 Advanced Signal Processing Toolkit (64-bit) provides VIs for time frequency analysis, time series analysis, and wavelet analysis. You can process larger data sets with the Advanced Signal Processing Toolkit (64-bit) than with the 32-bit version, if more memory is present. You must activate a valid NI LabVIEW 2011 (32-bit) Advanced Signal Processing Toolkit license in order to activate your copy of the Advanced Signal Processing Toolkit (64-bit) after the 30-day evaluation period expires.
New Features and Changes (The same as LabVIEW 2011 32bit Advanced Signal Processing Toolkit)
The LabVIEW 2011 Advanced Signal Processing Toolkit supports VxWorks. To use Advanced Signal Processing Toolkit in VxWorks, you first must install Advanced Signal Processing Toolkit on an NI real-time target that supports VxWorks.
Refer to the LabVIEW Help for more information about using these VIs.
Software Requirements:
The computer you are using must meet the following minimum system requirements to run the Advanced Signal Processing Toolkit (64-bit):
Windows 7 64-bit/Vista 64-bit/XP x641
200 MB free disk space
LabVIEW 2011 (SP1) Full or Professional Development System (64-bit)
1NI driver support for Windows XP x64 is limited. |
