查看: 2738|回复: 0
[LV工具模块] LabVIEW 2011 Advanced Signal Processing Toolkit Win32ENG LabVIEW2011高级信号处理工具包ASPT2011 32位Windows英语版
  • 签到天数: 3696 天
    连续签到: 23 天
    发表于 2020-7-12 18:41:37 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    ASPT工具包,在2009到2017年版本之间,有64位的测试版,但是NI官方一直到APST2018才正式发布64位版本。我方视觉论坛提供了ASPT2009-APST2017的64位版本下载。具体的可在本论坛搜索相应的版本。
    LabVIEW高级信号处理工具包是一组软件工具,可用于执行时频分析、时序分析和小波分析。
    LabVIEW高级信号处理工具包是LabVIEW的一个附加软件,提供有时频分析、时序分析和小波分析工具。该附加工具内含LabVIEW数字滤波器设计工具包,您可单独购买这一工具包。为了有效地提取信号隐藏的信息,应选择适当的分析工具。您可以将时频分析工具用于具有缓慢变化的光谱内容的进化信号,用于静止信号的时间序列分析工具,以及用于描述短时事件的进化信号和瞬态信号的小波分析工具。您还可以将分析代码部署到NI实时嵌入式硬件。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版和ZIP版内容一样,EXE为NI当年发行版,ZIP为NI后期重新压制版本。
    EXE版:
    ZIP版:
    EXE版:
    请注册登录视觉论坛会员,购买附件查看
    ZIP版:
    请注册登录视觉论坛会员,购买附件查看
    ASPT2011.txt (527 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2011 Advanced Signal Processing Toolkit Readme
    Version 11.0.0
    June 2011
    This file contains information to introduce you to the LabVIEW Advanced Signal Processing Toolkit. This file also provides you with help resources you can use while working with the Advanced Signal Processing Toolkit. The file contains the following information that you need to understand.
    New Features and Changes
    Activation Notice
    Uninstallation Instructions
    The LabVIEW 2011 Advanced Signal Processing Toolkit is the upgrade version of the LabVIEW 2010 Advanced Signal Processing Toolkit. The Advanced Signal Processing Toolkit provides VIs for time frequency analysis, time series analysis, and wavelet analysis.
    Use the Time Frequency Analysis VIs to transform a time domain signal to a linear or quadratic time-frequency domain representation. You can extract useful information from the time-frequency domain representation of a signal, or you can process a time-frequency domain representation and reconstruct a time domain signal.
    Use the Time Series Analysis VIs to perform preprocessing, statistical analysis, correlation analysis, spectrum estimation, and model estimation on a univariate or multivariate (vector) time series. You can extract useful information from the time series with different analysis methods for different applications.
    Use the Wavelet Analysis VIs to perform transforms and inverse transforms between a signal and the wavelet coefficients of the signal. You can use the Feature Extraction VIs to perform denoising, detrending, probability density function estimation, peak detection, edge detection, and ridge detection on a 1D or 2D signal.
    • The LabVIEW 2011 Advanced Signal Processing Toolkit supports VxWorks. To use Advanced Signal Processing Toolkit in VxWorks, you first must install Advanced Signal Processing Toolkit on an NI real-time target that supports VxWorks.
    Refer to the LabVIEW Help for more information about using these VIs.
    The computer you are using must meet the following minimum system requirements to run the Advanced Signal Processing Toolkit:
    • 200 MB free disk space
    • LabVIEW 2011 Full or Professional Development System (32-bit)
    You can run the Advanced Signal Processing Toolkit on the following operating systems:
    • Windows XP Service Pack 2 or later
    Note: The Advanced Signal Processing Toolkit does not support Windows NT/Me/2000/98/95 or the Windows Server non-R2 editions.
    Note: National Instruments is committed to maintaining compatibility with Microsoft Windows technology changes. However, NI has become aware of a number of issues of potential significance regarding Microsoft Windows 7. To learn how Windows 7 affects your use of NI products, visit ni.com/info and enter the Info Code windows7.
    You can install all of your LabVIEW products—including the Advanced Signal Processing Toolkit—using the LabVIEW 2011 Platform DVDs. You can find installation instructions for the Advanced Signal Processing Toolkit along with activation instructions in the following locations:
    • LabVIEW 2011 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2011 Platform DVDs, refer to the National Instruments Web site.
    Note: If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.Activation Notice
    To activate the Advanced Signal Processing Toolkit, use the serial number you received with the software kit. You can find your serial number on the product packing slip or on the shipping label. The serial number activates the LabVIEW Advanced Signal Processing Toolkit and the LabVIEW Digital Filter Design Toolkit.
    Your purchase of the Advanced Signal Processing Toolkit enables you to use the LabWindows™/CVI™ Advanced Signal Processing Toolkit. To request the installation media for the LabWindows/CVI Advanced Signal Processing Toolkit, contact NI.
    Complete the following steps to uninstall the Advanced Signal Processing Toolkit.
    • Open the Add or Remove Programs dialog box from the Control Panel.
    • Select National Instruments Software and click the Change button.
    • Under NI Products, select NI LabVIEW 2011 Advanced Signal Processing Toolkit and click the Remove button.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from the pull-down menu in LabVIEW, for information about using the Advanced Signal Processing Toolkit.
    You can access the examples for the Time Frequency Analysis Tools, the Time Series Analysis Tools, and the Wavelet Analysis Tools by selecting Help»Find Examples to display the NI Example Finder and then navigating to the Toolkits and Modules»Time Frequency Analysis, Toolkits and Modules»Time Series Analysis, and Toolkits and Modules»Wavelet Analysis folders, respectively. You also can click the Find Examples link in the Examples section of the Getting Started window to display the NI Example Finder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for the Time Frequency Analysis Tools, the Time Series Analysis Tools, and the Wavelet Analysis Tools in the labview\examples\time frequency analysis, labview\examples\time series analysis, and labview\examples\wavelet analysis folders, respectively.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the Advanced Signal Processing Toolkit.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2011 Advanced Signal Processing Toolkit. If you have a bug ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the Advanced Signal Processing Toolkit.
    Bug IDFixed Issue
    279599ASPT Voice Enhancement Example VI's Intensity Charts do not display continuously
    Important Information
    © 2011 National Instruments Corporation. All rights reserved.
    CVI, National Instruments, NI, ni.com, and LabVIEW are trademarks of National Instruments Corporation. Refer to the Trademark Information at ni.com/trademarks for other National Instruments trademarks.
    GMT+8, 2025-10-29 12:18
