查看: 4735|回复: 0
[LV工具模块] LabVIEW 2020 Electrical Power Toolkit LV2020电力工具包EPT2020电力套件模块
  • 签到天数: 3696 天
    连续签到: 23 天
    发表于 2020-7-9 11:35:11 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2020 Electrical Power Toolkit Win32Eng LV2020电力工具包EPT2020电力套件模块
    文件大小: 381720576 字节 (364.04 MB)
    修改日期: 2020-07-03 02:00
    MD5: e174548d8a4ef9a6e463a64010109abc
    SHA1: 1cbddddbeddb11adcc1d871fce331b4533f1f8c0
    SHA256: 5082d1400d7ec168c0731d4b7bf97928fe3c31e3a4919319c0f791efca9c35ab
    CRC32: 3482efad
    LabVIEW电力工具包可帮助您开发应用程序来测量、分析、 监控和记录电力数据和现象。
    LabVIEW电力工具包是LabVIEW的一个附加软件,可帮助您自行开发单相或三相电力监控、计量或质量分析应用程序。LabVIEW电力工具包包含了功率测量和电能质量VI,可用于测量电力和质量参数以及在CompactRIO、CompactDAQ和PXI平台上执行谐波分析。该工具包还提供了同步相量测量VI以及保护VI(用于保护CompactRIO平台上的设备)。
    2016版本之前的电力模块叫Electrical Power Suite,简称EPS,2017之后的版本叫Electrical Power Toolkit,简称ETP。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    请注册登录视觉论坛会员,购买附件查看
    EPT2020.txt (343 Bytes, 下载次数: 5, 售价: 10 圆)
    LabVIEW 2020 Electrical Power Toolkit Readme
    May 2020
    This file contains important information about the LabVIEW 2020 Electrical Power Toolkit, including system requirements, installation instructions, and new features.
    Electrical Power Toolkit Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    The Electrical Power Toolkit provides VIs that you can use to create applications that measure, analyze, monitor, and record electrical power data and phenomena. Use the Power Measurement VIs to measure electrical power parameters and to perform harmonic analysis on the CompactRIO platform, the CompactDAQ system, and the NI PXI platform. Use the Power Quality VIs to perform power quality measurement on the CompactRIO platform, the CompactDAQ system, and the NI PXI platform. Use the Synchrophasor VIs to perform synchrophasor measurement and use the Protection VIs to implement protection devices on the CompactRIO platform. Use the EV Power Test VIs to perform three-phase power measurement and battery power measurement on electric and hybrid electric vehicle components.
    The Electrical Power Toolkit complies with the following standards:
    • IEC 61000-4-7:2009, Electromagnetic Compatibility (EMC) - Part 4-7: Testing and Measurement Techniques - General Guide on Harmonics and Interharmonics Measurements and Instrumentation, for Power Supply Systems and Equipment Connected Thereto
    • IEC 61000-4-15:2010, Electromagnetic Compatibility (EMC) - Part 4-15: Testing and Measurement Techniques - Flickermeter - Functional and Design Specifications
    • IEC 61000-4-30:2008, Electromagnetic Compatibility (EMC) - Part 4-30: Testing and Measurement Techniques - Power Quality Measurement Methods
    • IEEE Std C37.111-1999, IEEE Standard Common Format for Transient Data Exchange (COMTRADE) for Power Systems
    • IEEE Std 1459-2010, IEEE Standard Definitions for the Measurement of Electric Power Quantities Under Sinusoidal, Nonsinusoidal, Balanced, or Unbalanced Conditions
    • IEEE Std C37.118.1-2011, IEEE Standard for Synchrophasor Measurements for Power Systems
    • IEEE Std C37.118.1a-2014, IEEE Standard for Synchrophasor Measurements for Power Systems - Amendment 1: Modification of Selected Performance Requirements
    • IEEE Std C37.118.2-2011, IEEE Standard for Synchrophasor Data Transfer for Power Systems
    • EN 50160:2007, Voltage Characteristics of Electricity Supplied by Public Distribution Networks
    • NEMA MG 1-2014, Motors and Generators
    In addition to the system requirements for the LabVIEW Development System, the LabVIEW 2020 Electrical Power Toolkit has the following requirements:
    • LabVIEW 2020 Full or Professional Development System (32-bit)
    • LabVIEW 2020 FPGA Module
    • LabVIEW 2020 Real-Time Module
    • NI CompactRIO Device Drivers May 2020
    • NI-DAQmx 20.0 (required only if you use NI DAQ devices with the Electrical Power Toolkit)
    • At least 200 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2020.
    The LabVIEW 2020 Electrical Power Toolkit supports the following operating systems:
    • Windows 10 (version 1809)/8.1 Update 11/7 SP12
    Note  Refer to Electrical Power Toolkit Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    Note  In 2016 the LabVIEW Electrical Power Toolkit dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2020 Electrical Power Toolkit will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2020 Electrical Power Toolkit to an unsupported OS. Additionally, after installing the LabVIEW 2020 Electrical Power Toolkit, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI installs the Electrical Power Toolkit using NI Package Manager. If you do not already have NI software installed, the Electrical Power Toolkit installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate the Electrical Power Toolkit. For more information on the Electrical Power Toolkit activation, refer to National Instruments Software Activation.
    The LabVIEW 2020 Electrical Power Toolkit adds the following new features:
    • Improved speed and memory performance for three-phase power measurements
    • Harmonic Analysis with and without electrical angle reference
    • High-speed data transport using a circular buffer to decouple acquisition and analysis
    • Triggering VIs to process signals per electrical cycle(s)
    • New support for the following software:
      • LabVIEW 2020 (32-bit)
      • NI-DAQmx 20.0
    You can access the software and documentation known issues list online. Visit LabVIEW 2020 Toolkits Known Issues for an up-to-date list of known issues in the Electrical Power Toolkit.
    Refer to the LabVIEW Help, accessible from Help»LabVIEW Help in LabVIEW, for information about the Electrical Power Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»Electrical Power folder to access the examples. You also can find the examples for the Electrical Power Toolkit in the labview\examples\Electrical Power directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The Electrical Power Toolkit will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2011–2020 National Instruments. All rights reserved.
    374774H-01
    GMT+8, 2025-10-29 12:19
