查看: 4309|回复: 0
[LV工具模块] LabVIEW 2018 Electrical Power Toolkit Win32Eng LV2018电力工具包EPT2018电力套件模块
  • 签到天数: 3696 天
    连续签到: 23 天
    发表于 2020-7-9 11:27:53 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    文件大小: 212209032 字节 (202.38 MB)
    修改日期: 2018-05-17 01:08
    MD5: f60fdc630b4c9f5dc0976c5643c3598f(重复一致)
    SHA1: 3e6f190ebdb90ae2e9c8338e33747c2a876d21c0
    SHA256: c9993f396a2b35b0ab8c8b7ca9f514aed07789b3f8cb7c8703d487e5061a8ddb
    CRC32: 8aad80af
    LabVIEW电力工具包可帮助您开发应用程序来测量、分析、 监控和记录电力数据和现象。
    LabVIEW电力工具包是LabVIEW的一个附加软件,可帮助您自行开发单相或三相电力监控、计量或质量分析应用程序。LabVIEW电力工具包包含了功率测量和电能质量VI,可用于测量电力和质量参数以及在CompactRIO、CompactDAQ和PXI平台上执行谐波分析。该工具包还提供了同步相量测量VI以及保护VI(用于保护CompactRIO平台上的设备)。
    2016版本之前的电力模块叫Electrical Power Suite,简称EPS,2017之后的版本叫Electrical Power Toolkit,简称ETP。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    请注册登录视觉论坛会员,购买附件查看
    EPT2018.txt (276 Bytes, 下载次数: 14, 售价: 10 圆)
    LabVIEW 2018 Electrical Power Toolkit Readme
    March 2018
    This file contains important information about the LabVIEW 2018 Electrical Power Toolkit, including system requirements, installation instructions, and new features.
    The LabVIEW Electrical Power Toolkit provides VIs that you can use to create applications that measure, analyze, monitor, and record electrical power data and phenomena. Use the Power Measurement VIs to measure electrical power parameters and to perform harmonic analysis on the CompactRIO platform, the CompactDAQ system, and the NI PXI platform. Use the Power Quality VIs to perform power quality measurement on the CompactRIO platform, the CompactDAQ system, and the NI PXI platform. Use the Synchrophasor VIs to perform synchrophasor measurement and use the Protection VIs to implement protection devices on the CompactRIO platform.
    The Electrical Power Toolkit complies with the following standards:
    • IEC 61000-4-7:2009, Electromagnetic Compatibility (EMC) - Part 4-7: Testing and Measurement Techniques - General Guide on Harmonics and Interharmonics Measurements and Instrumentation, for Power Supply Systems and Equipment Connected Thereto
    • IEC 61000-4-15:2010, Electromagnetic Compatibility (EMC) - Part 4-15: Testing and Measurement Techniques - Flickermeter - Functional and Design Specifications
    • IEC 61000-4-30:2008, Electromagnetic Compatibility (EMC) - Part 4-30: Testing and Measurement Techniques - Power Quality Measurement Methods
    • IEEE Std C37.111-1999, IEEE Standard Common Format for Transient Data Exchange (COMTRADE) for Power Systems
    • IEEE Std C37.118.1-2011, IEEE Standard for Synchrophasor Measurements for Power Systems
    • IEEE Std C37.118.1a-2014, IEEE Standard for Synchrophasor Measurements for Power Systems - Amendment 1: Modification of Selected Performance Requirements
    • IEEE Std C37.118.2-2011, IEEE Standard for Synchrophasor Data Transfer for Power Systems
    • EN 50160:2007, Voltage Characteristics of Electricity Supplied by Public Distribution Networks
    • NEMA MG 1-2014, Motors and Generators
    In addition to the system requirements for the LabVIEW Development System, LabVIEW 2018 Electrical Power Toolkit has the following requirements:
    • LabVIEW 2018 Full or Professional Development System (32-bit)
    • LabVIEW 2018 FPGA Module
    • LabVIEW 2018 Real-Time Module
    • NI CompactRIO Device Drivers May 2018
    • NI-DAQmx 18.0 (required only if you use NI DAQ devices with the Electrical Power Toolkit)
    • At least 200 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2018.
    LabVIEW 2018 Electrical Power Toolkit supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R2 (64-bit)1
    • Windows Server 2008 R2 SP1 (64-bit)2
    Note  In 2016 LabVIEW Electrical Power Toolkit dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. LabVIEW 2018 Electrical Power Toolkit will not install or run on an unsupported OS. You cannot deploy or distribute applications that use LabVIEW 2018 Electrical Power Toolkit to an unsupported OS. Additionally, after installing LabVIEW 2018 Electrical Power Toolkit, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Double-click the setup.exe file in the root directory of the Electrical Power Toolkit installer and follow the instructions on the screen to install the Electrical Power Toolkit.
    LabVIEW 2018 Electrical Power Toolkit adds support for the following software:
    • LabVIEW 2018 (32-bit)
    • NI-DAQmx 18.0
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the Electrical Power Toolkit.
    Refer to the LabVIEW Help, accessible from Help»LabVIEW Help in LabVIEW, for information about the Electrical Power Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»Electrical Power folder to access the examples. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for the Electrical Power Toolkit in the labview\examples\Electrical Power directory.
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, NI Measurement & Automation Explorer (MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
    © 2011–2018 National Instruments. All rights reserved.
    374774F-01
    GMT+8, 2025-10-29 12:18
