查看: 4187|回复: 0
[LV工具模块] LabVIEW 2015 Electrical Power Suite LV2015电力套件EPS2015电力工具包
  • 签到天数: 3696 天
    连续签到: 23 天
    发表于 2020-7-9 11:17:41 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2015 Electrical Power Suite Win32Eng LV2015电力套件EPS2015电力工具包
    文件大小: 110502176 字节 (105.38 MB)
    修改日期: 2015-08-01 04:22
    MD5: f2076cb589af69df9bc23e0675368b50(重复一致)
    SHA1: 00abd99bab6271b0e44823214434d3d561aa3603
    SHA256: 2a16a0fef065f24f9d48858ea9a0e38198afeb56460962fe15d65280e6f7fe44
    CRC32: 2c77c3ad
    LabVIEW电力工具包可帮助您开发应用程序来测量、分析、 监控和记录电力数据和现象。
    LabVIEW电力工具包是LabVIEW的一个附加软件,可帮助您自行开发单相或三相电力监控、计量或质量分析应用程序。LabVIEW电力工具包包含了功率测量和电能质量VI,可用于测量电力和质量参数以及在CompactRIO、CompactDAQ和PXI平台上执行谐波分析。该工具包还提供了同步相量测量VI以及保护VI(用于保护CompactRIO平台上的设备)。
    2016版本之前的电力模块叫Electrical Power Suite,简称EPS,2017之后的版本叫Electrical Power Toolkit,简称ETP。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    请注册登录视觉论坛会员,购买附件查看
    EPS2015.txt (274 Bytes, 下载次数: 9, 售价: 10 圆)
    LabVIEW 2015 Electrical Power Suite Readme
    June 2015
    This file contains important information about the LabVIEW 2015 Electrical Power Suite, including system requirements, installation instructions, and new features and changes.
    New Features and Changes
    The LabVIEW Electrical Power Suite provides VIs that you can use to create applications that measure, analyze, monitor, and record electrical power data and phenomena. Use the Power Measurement VIs to measure electrical power parameters and to perform harmonic analysis on the CompactRIO platform, the CompactDAQ system, and the NI PXI platform. Use the Power Quality VIs to perform power quality measurement on the CompactRIO platform, the CompactDAQ system, and the NI PXI platform. Use the Synchrophasor VIs to perform synchrophasor measurement and use the Protection VIs to implement protection devices on the CompactRIO platform.
    The Electrical Power Suite complies with the following standards:
    • IEC 61000-4-7:2009, Electromagnetic Compatibility (EMC) - Part 4-7: Testing and Measurement Techniques - General Guide on Harmonics and Interharmonics Measurements and Instrumentation, for Power Supply Systems and Equipment Connected Thereto
    • IEC 61000-4-15:2010, Electromagnetic Compatibility (EMC) - Part 4-15: Testing and Measurement Techniques - Flickermeter - Functional and Design Specifications
    • IEC 61000-4-30:2008, Electromagnetic Compatibility (EMC) - Part 4-30: Testing and Measurement Techniques - Power Quality Measurement Methods
    • IEEE Std C37.111-1999, IEEE Standard Common Format for Transient Data Exchange (COMTRADE) for Power Systems
    • IEEE Std C37.118.1-2011, IEEE Standard for Synchrophasor Measurements for Power Systems
    • IEEE Std C37.118.1a-2014, IEEE Standard for Synchrophasor Measurements for Power Systems
      Amendment 1: Modification of Selected Performance Requirements
    • IEEE Std C37.118.2-2011, IEEE Standard for Synchrophasor Data Transfer for Power Systems
    • EN 50160:2007, Voltage Characteristics of Electricity Supplied by Public Distribution Networks
    • NEMA MG 1-2014, Motors and Generators
    In addition to the system requirements for the LabVIEW Development System, the Electrical Power Suite 2015 has the following requirements:
    • LabVIEW 2015 Full or Professional Development System (32-bit)
    • LabVIEW 2015 FPGA Module
    • LabVIEW 2015 Real-Time Module
    • NI-RIO 15.0
    • NI-DAQmx 15.0 (required only if you use National Instruments DAQ devices with the Electrical Power Suite)
    • At least 200 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2015.
    Double-click the setup.exe file in the root directory of the Electrical Power Suite installer and follow the instructions on the screen to install the Electrical Power Suite.
    The Electrical Power Suite 2015 includes the following new features and changes:
    • Motor VIs—Use the VIs located on the Motor palette to conduct condition monitoring on AC induction motors, such as estimating motor speed, torque, load, and efficiency, calculating the motor spectra and rotor bar sideband harmonics, detecting broken rotor bars, and measuring the NEMA unbalance status and the derating rate.
    • Power Quality VIs that Support Measuring the Single-Bus Multiple-Line and Multiple-Bus Systems—Use the VIs located on the Power Quality palette to measure the power quality of single-bus multiple-line or multiple-bus systems.
    • Motor Measurement Example—Use the Motor Monitoring.lvproj example to learn how to monitor AC induction motors.
    • Power Quality Measurement Example—Use the Multiple Line Power Quality Applications (cRIO) (Delta-Sigma).lvproj example to learn how to measure the power quality in single-bus multiple-line or multiple-bus systems using applications on the CompactRIO targets.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Electrical Power Suite.
    Refer to the LabVIEW Help, accessible from Help»LabVIEW Help in LabVIEW, for information about the Electrical Power Suite.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»Electrical Power folder to access the examples. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for the Electrical Power Suite in the labview\examples\Electrical Power directory.
    Using NI Launcher
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and select All apps (Windows 8.0) or click the down arrow on the bottom left of the screen (Windows 8.1).
    NI LabVIEW Electrical Power Suite Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Electrical Power Suite will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of the Electrical Power Suite that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    LabWindows™/CVI™cvi_lifecycle
    © 2011–2015 National Instruments. All rights reserved.
    374774B-01
    GMT+8, 2025-10-29 12:17
