查看: 2831|回复: 0
[LV工具模块] LabVIEW 2014 Electrical Power Suite LV2014电力套件EPS2014电力工具包
  • 签到天数: 3696 天
    连续签到: 23 天
    发表于 2020-7-9 11:14:35 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2014 Electrical Power Suite Win32Eng LV2014电力套件EPS2014电力工具包
    文件大小: 103128352 字节 (98.35 MB)
    修改日期: 2014-08-19 21:03
    MD5: fa8049ca523e34f025816aae3f374941(官方正确)
    SHA1: 12f9c98e5c80efb9b58fa16cef8063d15e932f82
    SHA256: ef2dcc933108f887c3e9d58fd553548d440aa5d951eda4101be66d2f35271fdc
    CRC32: 3c419e05
    LabVIEW电力工具包可帮助您开发应用程序来测量、分析、 监控和记录电力数据和现象。
    LabVIEW电力工具包是LabVIEW的一个附加软件,可帮助您自行开发单相或三相电力监控、计量或质量分析应用程序。LabVIEW电力工具包包含了功率测量和电能质量VI,可用于测量电力和质量参数以及在CompactRIO、CompactDAQ和PXI平台上执行谐波分析。该工具包还提供了同步相量测量VI以及保护VI(用于保护CompactRIO平台上的设备)。
    2016版本之前的电力模块叫Electrical Power Suite,简称EPS,2017之后的版本叫Electrical Power Toolkit,简称ETP。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    下载地址1:
    请注册登录视觉论坛会员,购买附件查看
    下载地址2:
    请注册登录视觉论坛会员,购买附件查看
    EPS2014.txt (379 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2014 Electrical Power Suite Readme
    Version 14.0.0
    June 2014
    This file contains important information about the LabVIEW 2014 Electrical Power Suite, including system requirements, installation instructions, and new features and changes.
    New Features and Changes
    The LabVIEW Electrical Power Suite provides VIs that you can use to create applications that measure, analyze, monitor, and record electrical power data and phenomena. Use the Power Measurement VIs to measure electrical power parameters and to perform harmonic analysis on the NI CompactRIO platform, the NI CompactDAQ system, and the PXI platform. Use the Power Quality VIs to perform power quality measurement on the NI CompactRIO platform, the NI CompactDAQ system, and the PXI platform. Use the Synchrophasor VIs to perform synchrophasor measurement and use the Protection VIs to implement protection devices on the NI CompactRIO platform.
    The Electrical Power Suite complies with the following standards:
    • IEC 61000-4-7:2009, Electromagnetic Compatibility (EMC) - Part 4-7: Testing and Measurement Techniques - General Guide on Harmonics and Interharmonics Measurements and Instrumentation, for Power Supply Systems and Equipment Connected Thereto
    • IEC 61000-4-15:2010, Electromagnetic Compatibility (EMC) - Part 4-15: Testing and Measurement Techniques - Flickermeter - Functional and Design Specifications
    • IEC 61000-4-30:2008, Electromagnetic Compatibility (EMC) - Part 4-30: Testing and Measurement Techniques - Power Quality Measurement Methods
    • IEEE Std C37.111-1999, IEEE Standard Common Format for Transient Data Exchange (COMTRADE) for Power Systems
    • IEEE Std C37.118.1-2011, IEEE Standard for Synchrophasor Measurements for Power Systems
    • IEEE Std C37.118.1a-2014, IEEE Standard for Synchrophasor Measurements for Power Systems
      Amendment 1: Modification of Selected Performance Requirements
    • IEEE Std C37.118.2-2011, IEEE Standard for Synchrophasor Data Transfer for Power Systems
    • EN 50160:2007, Voltage Characteristics of Electricity Supplied by Public Distribution Networks
    In addition to the system requirements for the LabVIEW Development System, the Electrical Power Suite 2014 has the following requirements:
    • LabVIEW 2014 Full or Professional Development System (32-bit)
    • LabVIEW 2014 FPGA Module
    • LabVIEW 2014 Real-Time Module
    • NI-RIO 14.0
    • NI-DAQmx 14.0 (required only if you use National Instruments DAQ devices with the Electrical Power Suite)
    • At least 200 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2014.
    Double-click the setup.exe file in the root directory of the Electrical Power Suite installer and follow the instructions on the screen to install the Electrical Power Suite.
    The Electrical Power Suite 2014 includes the following new features and changes:
    • Advanced VIs—Use the Advanced VIs located on the Power Measurement palette to perform electrical power measurement using integral-cycle voltage and current signals and to perform harmonic analysis using resampled integral-cycle voltage and current signals. The VIs on the Basic Measurement palette in previous versions moved to the Power Measurement palette in the Electrical Power Suite 2014.
    • Synchrophasor VIs that Support IEEE Std C37.118.1-2011, IEEE Std C37.118.1a-2014, and IEEE Std C37.118.2-2011—Use the VIs located on the Synchrophasor palettes, both on the RT target and on the FPGA target, to perform synchrophasor measurement and to build and parse the four formats of synchrophasor message frames: data frame, configuration frame, header frame, and command frame. The VIs for measuring synchrophasors are in compliance with IEEE Std C37.118.1-2011 and IEEE Std C37.118.1a-2014. The C37.118 Frame VIs build and parse synchrophasor message frames for real-time communication of synchrophasor measurement data between phasor measurement units (PMUs) and phasor data concentrators (PDCs) as defined in IEEE Std C37.118.2-2011. The following VIs in the Electrical Power Suite 2014 replaced VIs in previous versions:
      VIs in 2014 VersionVIs in Previous Versions
      Initialize System (Std 2011) VIInitialize System VI
      Phasor Measurement (Std 2011) VIPhasor Measurement VI
      Build Data Frame (Std 2011) VIBuild Data Frame VI
      FPGA Phasor Measurement for M Class VI
      FPGA Phasor Measurement for P Class VI
      FPGA Phasor Measurement VI
    • SAR Modules for Power Quality Measurements Examples—Use the Power Quality Applications (cRIO) (SAR).lvproj example to learn how to perform power quality measurement on a CompactRIO system using successive approximation register (SAR) modules.
    • NI 9242 and NI 9244 with Electrical Power Examples—The following Electrical Power examples use the NI 9242 or the NI 9244 to demonstrate how to implement electrical power applications on a CompactRIO system:
      • The Power Quality Measurements examples use the NI 9244 with the Power Quality VIs to perform power quality measurement. The Power Quality Applications.lvproj example in previous versions changed to the Power Quality Applications (cRIO) (Delta-Sigma).lvproj example in the Electrical Power Suite 2014.
      • The Protection examples use the NI 9242 with the Protection VIs to implement protection devices.
      • The Synchrophasor Measurements examples use the NI 9242 with the Synchrophasor VIs to perform synchrophasor measurement.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Electrical Power Suite.
    Refer to the LabVIEW Help, accessible from Help»LabVIEW Help in LabVIEW, for information about the Electrical Power Suite.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»Electrical Power folder to access the examples. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for the Electrical Power Suite in the labview\examples\Electrical Power directory.
    Using NI Launcher
    Finding All Programs
    NI LabVIEW Electrical Power Suite Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Electrical Power Suite will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of the Electrical Power Suite that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2011–2014 National Instruments. All rights reserved.
    GMT+8, 2025-10-29 12:22
