查看: 3696|回复: 0
[LV工具模块] LabVIEW 2012SP1 Real-Time Module LV2012SP1实时模块RealTime2012SP1-Eng 32位Windows英文版下载
  • 签到天数: 3829 天
    连续签到: 22 天
    发表于 2020-7-1 18:18:22 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    自2011版实时模块起,NI提供了中文、日文、英语等三个语言版。本视觉论坛仅提供中文和英文版,日文版本本论坛不提供下载。
    使用LabVIEW Real-Time模块的三大理由:
    1. 将LabVIEW图形化编程扩展至独立的嵌入式系统
    2. 利用实时操作系统实现精确的定时和高可靠性
    3. 利用各类IP和实时硬件驱动
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    请注册登录视觉论坛会员,购买附件查看
    RT2012SP1E.txt (261 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2012 SP1 Real-Time Module Readme
    Version 12.0.1
    December 2012
    This file contains important information about the LabVIEW 2012 SP1 Real-Time Module.
    Supported Platforms
    Supported Platforms
    The Real-Time Module supports the following operating systems for application development:
    • Windows 8
    • Windows 7
    • Windows Vista
    • Windows XP Pro (Service Pack 2 or 3)
    Note:
    • The Real-Time Module is compatible with 32-bit LabVIEW only. Therefore, you must have 32-bit LabVIEW installed even if you use a 64-bit OS.
    • Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). Refer to the National Instruments website for information about how this might affect your use of Windows Server 2003 R2 and what actions you might have to take.
    • The Real-Time Module does not support the Windows Server non-R2 editions.
    The Real-Time Module installs the following real-time operating systems (RTOSes). Refer to the specific RT target hardware documentation for information about which RTOS your target uses.
    • NI ETS 13.1
    • VxWorks 6.3
    Note:   Each RTOS supports only a subset of LabVIEW features. Refer to the Real-Time Module»Unsupported LabVIEW Features book on the Contents tab of the LabVIEW Help for a list of unsupported LabVIEW features for each RTOS.
    You can install all of your LabVIEW products, including the LabVIEW Real-Time Module, using the LabVIEW Platform DVDs. You can find installation and activation instructions for the Real-Time Module in the following locations:
    • LabVIEW Real-Time Module Release and Upgrade Notes, which are available in your LabVIEW Real-Time Module software kit or online at ni.com/manuals.
    • LabVIEW 2012 Installation Guide, which is available in your LabVIEW software kit.
    • LabVIEW 2012 Service Pack 1 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments website.
    Note:  If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
    Installing and Using Japanese and Simplified Chinese Languages on an RT Target
    After you install the Real-Time Module on your development computer, you can complete the following steps to install and use Japanese and Simplified Chinese languages on an RT target.
    • Use the LabVIEW Real-Time Software Wizard in NI Measurement & Automation Explorer to install the Language Support for Japanese or Language Support for Simplified Chinese software component on the RT target. Refer to the NI Measurement & Automation Explorer Help for information about the LabVIEW Real-Time Software Wizard.
    • Open the System Settings tab and select Japanese or Simplified Chinese as the Locale.
    Note:  You cannot use Japanese or Simplified Chinese characters in directory names or file names on the RT target.
    Refer to the National Instruments website for an up-to-date list of known issues in the LabVIEW 2012 SP1 Real-Time Module.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2012 SP1 Real-Time Module.
    376884Project load with SCC configured is significantly slower in LabVIEW 2012 than LabVIEW 2011
    374695Cluster sent through Shared Variable on an RT target comes back with incorrect values.
    364292After filling then deleting from RT hard disk, MAX & LabVIEW report 0 free bytes
    363091HTTP Get with file path specified always always fails with error (on VxWorks)
    329455On a Hypervisor system, RT and Windows clocks cannot be synchronized
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2012 Real-Time Module.
    348124CF cards bigger then 256 MB are no longer working with cFP 2120 (Pharlap) controllers and LabVIEW RT 2010 and 2011
    344974Writing Binary data to IDE drives on 31x0 can lead to write failure in driver, error 6 in LabVIEW
    315170Unable to run packed library VIs interactively if rtDownloadPackedLibraries is enabled and if there are classes in the dependency
    312070StartupDLLs INI token limited to 512 characters and gets truncated on install of all components
    311844RT desktop PC utility format menu items are misleading
    305921Redeploying Dynamic Dispatch Vis in Child Classes Cause Failure to Redeploy
    304302[Waveform] 32bit LabVIEW 2010 on Windows 64bit: Read from Waveform returns wrong values
    297201Time Critical priority VI shouldn't compile if it contains a Timed Loop
    286334"Set Scan Engine Mode.vi" takes much longer time running on the target than on the host.
    232720Bad time stamp when using Scan From String VI on RT target with null default
    177926Scan from string.vi and Format Date/Time String.vi give incorrect results if run on a cFP-22x0
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the LabVIEW 2012 SP1 Real-Time Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Examples for the LabVIEW Real-Time Module are located in the labview\examples\Real-Time directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    Note  Unlike previous versions of Microsoft Windows, MAX does not appear as a desktop shortcut. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    Important Information
    © 1999–2012 National Instruments. All rights reserved.
    GMT+8, 2026-3-18 09:41
