查看: 2851|回复: 0
[LV工具模块] LabVIEW 2011 Real-Time Module LV2011实时模块RealTime2011-Eng 32位Windows英文版下载
    前天 10:18
  • 签到天数: 3555 天
    连续签到: 7 天
    发表于 2020-7-1 17:33:29 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    自2011版实时模块起,NI提供了中文、日文、英语等三个语言版。本视觉论坛仅提供中文和英文版,日文版本本论坛不提供下载。
    使用LabVIEW Real-Time模块的三大理由:
    1. 将LabVIEW图形化编程扩展至独立的嵌入式系统
    2. 利用实时操作系统实现精确的定时和高可靠性
    3. 利用各类IP和实时硬件驱动
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    请注册登录视觉论坛会员,购买附件查看
    RT2011E.txt (256 Bytes, 下载次数: 0, 售价: 10 元)
    LabVIEW 2011 Real-Time Module Readme
    Version 11.0.0
    June 2011
    This file contains important information about the LabVIEW 2011 Real-Time Module.
    Supported Platforms
    Installation
    Notice Regarding Microsoft Silverlight Installation and Redistribution
    Supported Platforms
    The Real-Time Module supports the following operating systems for application development:
    • Windows 7
    • Windows Vista
    • Windows XP Pro (Service Pack 2 or 3)
    Note:
    • The Real-Time Module is compatible with 32-bit LabVIEW only. Therefore, you must have 32-bit LabVIEW installed even if you use a 64-bit OS.
    • Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). Refer to the National Instruments Web site for information about how this might affect your use of Windows Server 2003 R2 and what actions you might have to take.
    • The Real-Time Module does not support the Windows Server non-R2 editions.
    The Real-Time Module installs the following real-time operating systems (RTOSes). Refer to the specific RT target hardware documentation for information about which RTOS your target uses.
    • NI ETS 13.1
    • VxWorks 6.3
    Note:   Each RTOS supports only a subset of LabVIEW features. Refer to the Real-Time Module»Unsupported LabVIEW Features book on the Contents tab of the LabVIEW Help for a list of unsupported LabVIEW features for each RTOS.
    Installation
    You can install all of your LabVIEW products, including the LabVIEW Real-Time Module, using the LabVIEW 2011 Platform DVDs. You can find installation and activation instructions for the Real-Time Module in the following locations:
    • LabVIEW Real-Time Module Release and Upgrade Notes, which are available in your LabVIEW Real-Time Module software kit or online at ni.com/manuals.
    • LabVIEW 2011 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2011 Platform DVDs, refer to the National Instruments Web site.
    Note:  If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
    Installing and Using Japanese and Simplified Chinese Languages on an RT Target
    After you install the Real-Time Module on your development computer, you can complete the following steps to install and use Japanese and Simplified Chinese languages on an RT target.
    • Use the LabVIEW Real-Time Software Wizard in NI Measurement & Automation Explorer to install the Language Support for Japanese or Language Support for Simplified Chinese software component on the RT target. Refer to the NI Measurement & Automation Explorer Help for information about the LabVIEW Real-Time Software Wizard.
    • Open the System Settings tab and select Japanese or Simplified Chinese as the Locale.
    Note:  You cannot use Japanese or Simplified Chinese characters in directory names or file names on the RT target.
    Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW 2011 Real-Time Module.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2011 Real-Time Module.
    293334ETS PCI Config space functions may not properly deal with indices not divisible by 4.
    292386Domain Name option in DHCP/BOOTP Need to be parsed correctly
    292009Scan Engine built application with a timed loop doesn't exit on close
    291729RT Apply Network Settings (Static) doesn't handle empty string inputs correctly
    284950Deployment of built source distribution to RT target in LV 2010 causes error/crash
    280489"Delay of communication, slow down of code on cRIO when project disconnected."
    258696Deployment failure due to network protocol issues on cFP-2120 with large statechart
    255732Remote debugging RT Application for Timing source heirarchy broken on VxWorks
    255014"Probes are listed as ""Not Executed"" intermittently on real time target"
    252965[TDMS] TDMS write hangs on cRIO if three DMAs are used in parallel
    250741Cannot FTP into a cRIO in Safe Mode if it has been Locked
    250468Disconnecting from an RT Target Leaks Massive Amounts of Memory and May Crash RT upon Reconnecting
    248828Scan thread switching among cores causes timed loop to finish late.
    246770Cannot listen on same TCP port on two different NICs
    246281Leak opening and closing LV projects with RT Desktop targets in them -- one nimxsoffline.exe leaked per RT Desktop target
    240199Reconnecting network to a PharLap RT 2009 system while opening a DataSocket connection causes persistant error 56
    237822"LV2010 RT Format in Safe Mode causes ""Blue Screen Scheduler Assertion"" when no valid RT partitions are found on drive"
    235520Run Continously button glyph is not updated after disconnecting and reconnecting
    230877RTC plug-in cannot be loaded if NI RT Extensions for SMP (MultiCore Support) 9.0 is installed
    230504RTC plug-in causes the current system time to fly 3 times faster than the normal clock.
    209197"Deploying LVOOP VIs to an RT target (cRIO 9074) results in ""Waiting for Real-Time Target (M1P) to respond"" messages"
    204879Timed Structure waits for Timeout at the end of loop execution
    203211Deployment Error Due to Failed Loading of lvanlys.*
    193159LV project deploys configuration whenever Local Windows Host VI runs as soon as you add a module to your cRIO or ECAT chassis
    155193"Visa Error, CRIO error under MAX incorrect time"
    113266Cannot delete RTEXE on PharLap after application stops executing and VIs are unloaded - Makes field updates harder
    297476Ethernet Drivers may fill up customer hard drives if Multicast packets are received
    246179TCP Listen does not play nicely when using dynamic port assignment
    Using Microsoft Silverlight
    Important Information
    © 2011 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-6-2 16:37
