查看: 3647|回复: 0
[NI驱动程序] NI-Motion 16.0 Full Win32Eng NI运动控制设备驱动软件2016完整版 适用LabVIEW2013~LabVIEW2016
    昨天 08:56
  • 签到天数: 3596 天
    连续签到: 4 天
    发表于 2020-6-24 11:48:08 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-Motion为NI运动控制设备的驱动软件Motion Control Driver Software,开发软件为NI SoftMotion,及Motion Assistant。
    NI-Motion 16.0
    发布日期
    16-8-1
    受支持的操作系统
    Windows 7
    Windows 10
    Windows 8.1
    Windows 8
    语言
    英文
    校验和
    (MD5)
    0132b8c4dc067941b292fc8fcc6cbf1e
    百度网盘下载(限速,请开会员或使用破解限速工具):
    链接: 请注册视觉论坛用户,登录后购买附件下载查看 提取码: 请注册登录视觉论坛会员,购买附件查看
    请注册登录视觉论坛会员,购买附件查看
    Motion16.0.txt (250 Bytes, 下载次数: 1, 售价: 10 元)
    NI-Motion™ 16.0 Readme
    This document contains installation and programming considerations for using NI-Motion with NI 73xx motion controllers, a list of changes in this version of NI-Motion, and information about NI-Motion known issues.
    Contents
    General Information
    Installation and Configuration Instructions
    NI-Motion 16.0 Changes and Enhancements
    NI-Motion 16.0 General Considerations
    NI-Motion 16.0 Known Issues
    Previous NI-Motion Changes and Enhancements
    General Information
    NI-Motion 16.0 is the motion control software you use to communicate with all National Instruments NI 73xx motion controllers using LabVIEW, C, LabWindows™/CVI™, or Microsoft Visual Basic 6.0 development platforms. Refer to KnowledgeBase article 39DA8HMU, Does the NI-Motion Driver Support Visual Studio .NET?, at ni.com/kb for information about Visual Studio .NET 2003 and Visual Studio 2005 or later support.
    NI-Motion 16.0 is compatible with the following National Instruments software:
    • LabVIEW 2013 or later.
    • LabVIEW 2013 or later Real-Time Module.
    • LabWindows/CVI 2010 or later.
    • NI Motion Assistant 2.8 or later graphical prototyping software.
    Compatibility with Earlier Versions of NI-Motion
    If you have developed motion control systems using a previous version of NI-Motion, you must recompile your code before it will work correctly with NI-Motion 16.0.
    In addition, any applications you build in NI-Motion 16.0 will not work correctly in earlier versions of NI-Motion. Similarly, configuration settings you build and save in Measurement & Automation Explorer (MAX) with NI-Motion 16.0 will not work with applications you build in earlier versions of NI-Motion.
    LabVIEW Real-Time Users
    To use NI-Motion 16.0 with a real-time target, you must update the NI-Motion driver software on the real-time target system using MAX. Driver versions on the host and target system must be the same for proper operation. Refer to the Measurement & Automation Explorer Remote Systems Help by selecting Help»Help Topics»Remote Systems in MAX for information about installing software on the remote system.
    Back to Top
    The following sections include important information about installing NI-Motion 16.0, instructions for downloading and installing NI-Motion 16.0 from the Web or from the CD, and information about NI-Motion firmware.
    You can run the NI-Motion 16.0 installer on the following operating systems:
    • Windows 10/8.1/8/7
    NI-Motion runs as a 32-bit application on all operating systems.
    Note
    • NI-Motion is compatible with 32-bit LabVIEW only. Therefore, you must have 32-bit LabVIEW installed even if you use a 64-bit OS.
    • NI-Motion does not support Windows Vista/XP/2000/NT/Me/98/95, or the Windows Server non-R2 editions. If you are any of these operating systems, do not install NI-Motion 16.0.
    Tip  For optimal performance, update your operating system to the latest service pack and apply all security patches.
    Downloading NI-Motion 16.0 from the Web
    Complete the following steps to install this update:
    • Download the NIMotion160.exe file, and then run it.
      Note  (Windows 10/8.1/8/7)  Users may see access and security messages during installation. Accept the prompts to complete the installation.
    • When the installer completes, a dialog box appears that asks if you want to restart, shut down, or restart later. Select Restart.
    • Download the updated firmware to your controller(s):
      Note  You must update the firmware on your NI 73xx controllers before you can use them with NI-Motion 16.0.
      • Launch MAX.
      • Expand Devices and Interfaces.
      • Select the appropriate motion controller.
      • Click the Firmware tab.
      • Click the Update Firmware button at the top of the window to update all the firmware files on your device.
    Installing from the CD
    • Insert the NI-Motion 16.0 installation CD in the CD-ROM drive.
    • If you have autorun enabled, autorun.exe runs automatically. Otherwise, double-click autorun.exe.
      • Launch MAX.
    Changing Firmware Files to an Earlier Version of NI-Motion
    For optimal performance, ensure that the firmware on your controller matches the driver version you install. Complete the following steps to replace the firmware on your controller if you need to use an earlier version of the NI-Motion software and firmware:
    • Launch MAX.
    • Right-click one of the firmware files in the Firmware Name column and select Download All Files to download the firmware files on the computer onto the controller.
    Back to Top
    NI-Motion 16.0 Changes and EnhancementsLabVIEW 2016 Support
    NI-Motion 16.0 is fully supported on LabVIEW 2016.
    Back to Top
    NI-Motion 16.0 General ConsiderationsImporting Portable Configuration Files
    Importing motion controller settings from older portable configuration files may take a few minutes due to the settings upgrade process. This is expected behavior.
    Creating C Projects with Microsoft Visual Studio .NET 2003 and Visual Studio 2005 or later
    Visual Studio .NET 2003 and Visual Studio 2005 and later do not allow C++ precompiled header files to be used with C source files. Disable precompiled headers when running NI-Motion C examples.
    Firmware Versions in NI-Motion 16.0
    The following table lists the expected firmware files that ship with NI-Motion 16.0.
    Firmware
    Sector
    Version Number
    NI 7330NI 7340NI 7350NI PCI-7390
    683317.40.30037.40.30037.40.30037.40.3003
    DSP7.32.30037.32.30037.32.30037.32.3003
    FPGA17.00.30017.00.30017.10.30017.00.3014
    FPGA27.00.30017.00.3001
    Back to Top
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in NI-Motion 16.0.
    Issues That May Affect NI-Motion
    An issue that may arise when running 32-bit applications in 64-bit versions of Windows could adversely affect NI-Motion. Refer to KnowledgeBase article 6EMFLQUB, Why Does National Instruments Software List Microsoft Hotfix 2588507 as a System Requirement?, at ni.com/kb for more information.
    Back to Top
    Refer to KnowledgeBase article 47CC30FL, NI-Motion Readmes, at ni.com/kb for access to previous NI-Motion readme files, starting with NI-Motion 7.0.
    Back to Top
    Back to Top
    Using NI Launcher
    Note  Unlike previous versions of Microsoft Windows, MAX does not appear as a desktop shortcut. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    Back to Top
    NI-Motion Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI-Motion will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-Motion that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Back to Top
    Important Information
    © 2003–2016 National Instruments. All rights reserved.
    Members of the National Instruments Alliance Partner Program are business entities independent from National Instruments and have no agency, partnership, or joint-venture relationship with National Instruments.
    376348A-01
    GMT+8, 2025-7-18 05:56
