查看: 3286|回复: 0
[NI驱动程序] NI-Motion 8.2 Full Win32Eng NI运动驱动程序8.2完整版 适用LabVIEW8.5~LabVIEW2010
    8 小时前
  • 签到天数: 3730 天
    连续签到: 57 天
    发表于 2020-6-24 10:58:17 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-Motion为NI运动器件的驱动程序,开发软件为NI SoftMotion,及Motion Assistant。
    NI-Motion 8.2
    发布日期
    10-8-2
    受支持的操作系统
    Windows XP 32-bit
    Windows 7
    Windows 7 64-bit
    Windows 7 32-bit
    Windows Server 2003 R2 32-bit
    Windows Server 2008 R2 64-bit
    Windows Vista
    Windows Vista 64-bit
    Windows Vista 32-bit
    Windows XP
    语言
    英文
    校验和
    (MD5)
    0175afa41ec8c29e4cdeff5572073d6e
    百度网盘下载(限速,请开会员或使用破解限速工具):
    链接: 请注册视觉论坛用户,登录后购买附件下载查看 提取码: 请注册登录视觉论坛会员,购买附件查看
    请注册登录视觉论坛会员,购买附件查看
    Motion8.2.txt (273 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Motion™ 8.2 Readme
    This document contains installation and programming considerations for using NI-Motion with NI 73xx motion controllers, a list of changes in this version of NI-Motion, and information about NI-Motion known issues.
    Contents
    General Information
    Installation and Configuration Instructions
    NI-Motion 8.2 Changes and Enhancements
    NI-Motion 8.2 General Considerations
    NI-Motion 8.2 Known Issues
    Previous NI-Motion Changes and Enhancements
    General Information
    NI-Motion 8.2 is the motion control software you use to communicate with all National Instruments NI 73xx motion controllers using LabVIEW, C, LabWindows™/CVI™, or Microsoft Visual Basic 6.0 development platforms. Refer to KnowledgeBase article 39DA8HMU, Does the NI-Motion Driver Support Visual Studio .NET?, at ni.com/kb for information about Visual Studio .NET 2003 and Visual Studio 2005 or later support.
    NI-Motion 8.2 is compatible with the following National Instruments software:
    • LabVIEW 8.5 or later.
    • LabVIEW 8.5 or later Real-Time Module.
    • LabWindows/CVI 7.0 or later.
    • NI Motion Assistant 2.3 or later graphical prototyping software.
    Compatibility with Earlier Versions of NI-Motion
    If you have developed motion control systems using a previous version of NI-Motion, you must recompile your code before it will work correctly with NI-Motion 8.2.
    In addition, any applications you build in NI-Motion 8.2 will not work correctly in earlier versions of NI-Motion. Similarly, configuration settings you build and save in Measurement & Automation Explorer (MAX) with NI-Motion 8.2 will not work with applications you build in earlier versions of NI-Motion.
    LabVIEW Real-Time Users
    To use NI-Motion 8.2 with a real-time target, you must update the NI-Motion driver software on the real-time target system using MAX. Driver versions on the host and target system must be the same for proper operation. Refer to the Measurement & Automation Explorer Remote Systems Help by selecting Help»Help Topics»Remote Systems in MAX for information about installing software on the remote system.
    Back to Top
    The following sections include important information about installing NI-Motion 8.2, instructions for downloading and installing NI-Motion 8.2 from the Web or from the CD, and information about NI-Motion firmware.
    You can run the NI-Motion 8.2 installer on the following operating systems:
    • Windows XP (32-bit)
    NI-Motion runs as a 32-bit application on all operating systems.
    NI-Motion does not support Windows 2000/NT/Me/98/95, Windows XP x64, or the Windows Server non-R2 editions.If you are any of these operating systems, do not install NI-Motion 8.2.
    Tip  For optimal performance, update your operating system to the latest service pack and apply all security patches.
    Downloading NI-Motion 8.2 from the Web
    Complete the following steps to install this update:
    • Download the NIMotion820.exe file, and then run it.
      Note  (Windows 7 and Vista)  Users may see access and security messages during installation. Accept the prompts to complete the installation.
    • When the installer completes, a dialog box appears that asks if you want to restart, shut down, or restart later. Select Restart.
    • Download the updated firmware to your controller(s):
      Note  You must update the firmware on your NI 73xx controllers before you can use them with NI-Motion 8.2.
      • Launch MAX.
      • Expand Devices and Interfaces.
      • Select the appropriate motion controller.
      • Click the Firmware tab.
      • Click the Update Firmware button at the top of the window to update all the firmware files on your device.
    Installing from the CD
    • Insert the NI-Motion 8.2 installation CD in the CD-ROM drive.
    • If you have autorun enabled, autorun.exe runs automatically. Otherwise, double-click autorun.exe.
      Note  (Windows Vista)  Users may see access and security messages during installation. Accept the prompts to complete the installation.
      • Launch MAX.
    Changing Firmware Files to an Earlier Version of NI-Motion
    For optimal performance, ensure that the firmware on your controller matches the driver version you install. Complete the following steps to replace the firmware on your controller if you need to use an earlier version of the NI-Motion software and firmware:
    • Launch MAX.
    • Right-click one of the firmware files in the Firmware Name column and select Download All Files to download the firmware files on the computer onto the controller.
    Back to Top
    NI-Motion 8.2 Changes and EnhancementsLabVIEW 2010 Support
    NI-Motion 8.2 is fully supported on LabVIEW 2010.
    Back to Top
    NI-Motion 8.2 General ConsiderationsInhibit Output Behavior
    The default behavior of the inhibit output changed after NI-Motion 7.0. Previously, the inhibit output would be driven to the active state when the output was disabled. NI-Motion 7.0 and higher drives the inhibit output to the inactive state when the output is disabled. The behavior of the inhibit output when it is enabled did not change.
    Importing Portable Configuration Files
    Importing motion controller settings from older portable configuration files may take a few minutes due to the settings upgrade process. This is expected behavior.
    Creating C Projects with Microsoft Visual Studio .NET 2003 and Visual Studio 2005 or later
    Visual Studio .NET 2003 and Visual Studio 2005 and later do not allow C++ precompiled header files to be used with C source files. Disable precompiled headers when running NI-Motion C examples.
    Firmware Versions in NI-Motion 8.2
    The following table lists the expected firmware files that ship with NI-Motion 8.2.
    Firmware
    Sector
    Version Number
    NI 7330NI 7340NI 7350NI PCI-7390
    683317.40.30037.40.30037.40.30037.40.3003
    DSP7.32.30037.32.30037.32.30037.32.3003
    FPGA17.00.30017.00.30017.10.30017.00.3014
    FPGA27.00.30017.00.3001
    Upgrading from NI-Motion 5.0.1
    When you upgrade NI-Motion 5.0.1 to NI-Motion 8.2, your controller does not use the initialization settings you configured and saved in MAX prior to installing NI-Motion 8.2. To use your old initialization settings, you must change back to the old settings using the Change Current Settings feature in the Initialization Settings wizard in MAX. Refer to Measurement & Automation Explorer Help for Motion for information about changing device settings.
    Tip  Click Help»Help Topics»NI-Motion»NI-Motion Configuration Help to launch Measurement & Automation Explorer Help for Motion.
    Back to Top
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in NI-Motion 8.2.
    Back to Top
    Refer to KnowledgeBase article 47CC30FL, NI-Motion Readmes, at ni.com/kb for access to previous NI-Motion readme files, starting with NI-Motion 7.0.
    Back to Top
    Important Information
    © 2010 National Instruments Corporation. All rights reserved.
    CVI, LabVIEW, National Instruments, NI, ni.com, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the Trademark Information at ni.com/trademarks for other National Instruments trademarks. The mark LabWindows is used under a license from Microsoft Corporation. Other product and company names listed are trademarks or trade names of their respective companies.
    GMT+8, 2025-12-2 16:56
