查看: 3889|回复: 0
[NI驱动程序] NI-Motion 7.6 Full Win32Eng NI运动驱动程序7.6完整版 适用LabVIEW8.5
    8 小时前
  • 签到天数: 3730 天
    连续签到: 57 天
    发表于 2020-6-23 16:10:35 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-Motion为NI运动器件的驱动程序,开发软件为NI SoftMotion,及Motion Assistant。
    NI-Motion 7.6
    发布日期
    07-8-1
    受支持的操作系统
    Windows 2000
    Windows Vista 64-bit
    Windows Vista
    Windows XP
    语言
    英文
    校验和
    (MD5)
    7524b00024285c216bfa646f2ff65a6a
    百度网盘下载(限速,请开会员或使用破解限速工具):
    链接: 请注册视觉论坛用户,登录后购买附件下载查看 提取码: 请注册登录视觉论坛会员,购买附件查看
    请注册登录视觉论坛会员,购买附件查看
    Motion7.6.txt (271 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Motion™ 7.6 Readme
    This document contains installation and programming considerations, a list of changes in this version of NI-Motion, and a list of NI-Motion known issues.
    Contents
    General Information
    Installation and Configuration Instructions
    NI-Motion 7.6 Changes and Enhancements
    NI-Motion 7.6 General Considerations
    NI-Motion 7.6 Known Issues
    Previous NI-Motion Changes and Enhancements
    General Information
    NI-Motion 7.6 is the motion control software you use to communicate with all National Instruments motion controllers using LabVIEW, C, LabWindows™/CVI™, or Microsoft Visual Basic 6.0 development platforms. Refer to KnowledgeBase article 39DA8HMU, Does the NI-Motion Driver Support Visual Studio .NET?, at ni.com/kb for information about Visual Studio .NET 2003 and Visual Studio 2005 support.
    NI-Motion 7.6 is compatible with the following National Instruments software:
    • LabVIEW 7.1.1 or later.
    • LabVIEW 7.1.1 or later Real-Time Module.
    • Motion Assistant 2.2 or later graphical prototyping software.
    • NI SoftMotion Controller 2.2 or later.
      Note:  Do not update your NI-Motion software if you are using the NI SoftMotion Controller 2.1 or earlier unless you also update your NI SoftMotion Controller software to version 2.2.
    Compatibility with Earlier Versions of NI-Motion
    If you have developed motion control systems using a previous version of NI-Motion, you must recompile your code before it will work correctly with NI-Motion 7.6.
    In addition, any applications you build in NI-Motion 7.6 will not work correctly in earlier versions of NI-Motion. Similarly, configuration settings you build and save in Measurement & Automation Explorer (MAX) with NI-Motion 7.6 will not work with applications you build in earlier versions of NI-Motion.
    LabVIEW Real-Time Users
    To use NI-Motion 7.6 with a real-time target, you must reinstall the NI-Motion driver software on the real-time target system using MAX. Driver versions on the host and target system must be the same for proper operation. Refer to the Measurement & Automation Explorer Remote Systems Help by selecting Help»Help Topics»Remote Systems in MAX for information about installing software on the remote system.
    Back to Top
    The following sections include important information about installing NI-Motion 7.6, instructions for downloading and installing NI-Motion 7.6 from the Web or from the CD, and information about NI-Motion firmware.
    Note  NI-Motion 7.6 is supported on Microsoft Windows Vista/XP/2000. If you are using Windows Me/98/NT, do not upgrade to NI-Motion version 7.6. Continue using NI-Motion version 6.1.x.
    Tip  For optimal performance, update your operating system to the latest service pack and apply all security patches. This is especially important on Windows 2000 systems. Refer to KnowledgeBase article 45O8JNHR at ni.com/kb for more information.
    Downloading NI-Motion 7.6 from the Web
    Complete the following steps to install this update:
    • Download the NIMOTION760.exe file, and then run it.
      Note  (Windows Vista)  Users may see access and security messages during installation. Accept the prompts to complete the installation.
    • When the installer completes, a dialog box appears that asks if you want to restart, shut down, or restart later. Select Restart.
    • Download the updated firmware to your controller(s):
      Note  You must update the firmware on your NI 73xx controllers before you can use them with NI-Motion 7.6.
      • Launch MAX.
      • Expand Devices and Interfaces.
      • Select the appropriate motion controller.
      • Click the Firmware tab.
      • Click the Update Firmware button at the top of the window to update all the firmware files on your device.
    Installing from the CD
    • Insert the NI-Motion 7.6 installation CD in the CD-ROM drive.
    • If you have autorun enabled, autorun.exe runs automatically. Otherwise, double-click autorun.exe.
      • Launch MAX.
    Changing Firmware Files to an Earlier Version of NI-Motion
    For optimal performance, ensure that the firmware on your controller matches the driver version you install. Complete the following steps to replace the firmware on your controller if you need to use an earlier version of the NI-Motion software and firmware:
    • Launch MAX.
    • Right-click one of the firmware files in the Firmware Name column and select Download All Files to download the firmware files on the computer onto the controller.
    Back to Top
    NI-Motion 7.6 Changes and EnhancementsLabVIEW 8.5 Support
    NI-Motion 7.6 is fully supported on LabVIEW 8.5.
    Changed Installation Location for CVI Support Files
    • Examples are installed at \samples.
    • Function panels and libraries are installed at \bin.
    You may need to update existing CVI projects to reflect these changes.
    Improved Stepper Output Generation
    In previous versions of NI-Motion, the stepper output of a follower/slave gearing axis could be incorrectly generated, causing missing steps. This problem has been fixed in NI-Motion 7.6.
    Enabling or Disabling Encoder Associated with Disabled Axis
    NI-Motion 7.6 now allows an encoder to be controlled independently of the axis owning the encoder as long as the axis is disabled.
    Using Crossover Cables with Remote Devices
    In previous versions of NI-Motion, using a crossover cable with a remote target could cause the driver to be unable to communicate with a mapped device. This problem has been fixed in NI-Motion 7.6.
    Repairing the NI-Motion Installation from the CD on a 64-bit System
    It is now possible to repair the NI-Motion installation from the CD on a Microsoft Windows Vista 64-bit system.
    Updated Links in Help Documents
    In previous versions of NI-Motion, several reference links in the help documents did not open properly. This problem has been fixed in NI-Motion 7.6.
    Back to Top
    NI-Motion 7.6 General ConsiderationsImporting Portable Configuration Files
    Importing motion controller settings from older portable configuration files may take a few minutes due to the settings upgrade process. This is expected behavior.
    Creating C Projects with Microsoft Visual Studio .NET 2003 and Visual Studio 2005
    Visual Studio .NET 2003 and 2005 do not allow C++ precompiled header files to be used with C source files. Disable precompiled headers when running NI-Motion C examples.
    National Instruments Software Publisher Certificates
    When you run setup.exe to install the software from the CD, you are prompted to choose whether you want to always trust software from National Instruments. If you do not select this option, your installation may be interrupted by one or more Microsoft Windows security dialog boxes. However, if you run setup from the command line, you will not receive this prompt, and the installer will automatically install NI's Software Publisher Certificate to the Windows Trusted Publisher Store. If you do not want to make this change to your Windows Trusted Publisher Store, do not choose this installation method.
    Firmware Versions in NI-Motion 7.6
    The following table lists the expected firmware files that ship with NI-Motion 7.6.
    Firmware
    Sector
    Version Number
    NI 7330NI 7340NI 7350NI PCI-7390
    683317.40.30017.40.30017.40.30017.40.3001
    DSP7.30.30017.30.30017.30.30017.30.3001
    FPGA17.00.30017.00.30017.10.30017.00.3014
    FPGA27.00.30017.00.3001
    Upgrading from NI-Motion 5.0.1
    When you upgrade NI-Motion 5.0.1 to NI-Motion 7.6, your controller does not use the initialization settings you configured and saved in MAX prior to installing NI-Motion 7.6. To use your old initialization settings, you must change back to the old settings using the Change Current Settings feature in the Initialization Settings wizard in MAX. Refer to Measurement & Automation Explorer Help for Motion for information about changing device settings.
    Tip  Click Help»Help Topics»NI-Motion»NI-Motion Configuration Help to launch Measurement & Automation Explorer Help for Motion.
    Back to Top
    NI-Motion 7.6 Known IssuesLoading Target Positions in Velocity Mode
    Do not use the Load Target Position VI/function when your controller is in velocity mode. Loading a target position while operating in velocity mode may result in unexpected behavior.
    Using Position Buffers with Vector Spaces
    Switching buffer resources using Configure Buffer to perform two sequential contour moves does not work as expected with a vector space. When Configure Buffer is called two times in a row with different resources, the first contoured move is executed as expected but the second one is either not executed at all in cases where total points is the same as buffer size or it moves to some random position in cases where total points is greater than buffer size. To correct this problem, call Stop Motion between the first and second call to Configure Buffer.
    Updating from NI-Motion 7.2.1 using Portable Configuration Files
    When updating to NI-Motion 7.6 from NI-Motion 7.2.1, if you have previously imported settings for the NI 7344 controller using NI Portable Configuration files (.nce files), you must reimport the NI 7344 controller settings after you update to NI-Motion 7.6.
    Symptoms of this issue that appear after updating to NI-Motion 7.6 are receiving error -70038 (NIMC_internalSoftwareError) when you initialize the controller and the Control Loop Settings tab not appearing in MAX.
    Blend Factor Values for Two Vector Spaces (NI 73xx Controllers Only)
    Using a blend factor greater than 0 when performing arc moves on two vector spaces simultaneously may cause one vector space to stop prematurely. National Instruments recommends that you do not use a blend factor greater than 0 in this case.
    NIMC_* Functions in Microsoft Visual Basic
    The current version of NI-Motion supports the flex_* API functions but not the NIMC_* functions in Visual Basic 6.0.
    Back to Top
    Refer to KnowledgeBase article 47CC30FL, NI-Motion Readmes, at ni.com/kb for access to previous NI-Motion readme files, starting with NI-Motion 7.0.
    Back to Top
    Important Information
    © 2007 National Instruments Corporation. All rights reserved.
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your CD, or ni.com/patents.
    GMT+8, 2025-12-2 16:58
