查看: 3005|回复: 0
[NI驱动程序] NI-Motion 7.5 Full Win32Eng NI运动驱动程序7.5完整版 适用LabVIEW7.1
    8 小时前
  • 签到天数: 3730 天
    连续签到: 57 天
    发表于 2020-6-23 15:30:33 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-Motion为NI运动器件的驱动程序,开发软件为NI SoftMotion,及Motion Assistant。
    NI-Motion 7.5
    发布日期
    07-4-1
    受支持的操作系统
    Windows 2000
    Windows Vista 64-bit
    Windows Vista
    Windows XP
    语言
    英文
    校验和
    (MD5)
    8eb942df92f024c90a0f8b859777a3ed
    百度网盘下载(限速,请开会员或使用破解限速工具):
    链接: 请注册视觉论坛用户,登录后购买附件下载查看 提取码: 请注册登录视觉论坛会员,购买附件查看
    请注册登录视觉论坛会员,购买附件查看
    Motion7.5.txt (271 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Motion™ 7.5 Readme
    NI-Motion 7.5 is the motion control software you use to communicate with all National Instruments motion controllers using LabVIEW, C, LabWindows™/CVI™, or Visual Basic 6.0 development platforms. Refer to KnowledgeBase article 39DA8HMU, Does the NI-Motion Driver Support Visual Studio .NET?, at ni.com/kb for information about Visual Studio .NET 2003 and Visual Studio 2005 support.
    The NI-Motion VI Library 7.5 is compatible with LabVIEW 7.1 or later.
    Compatibility with Earlier Versions of NI-Motion
    If you have developed motion control systems using a previous version of NI-Motion, you must recompile your code before it will work correctly with NI-Motion 7.5.
    In addition, any applications you build in NI-Motion 7.5 will not work correctly in earlier versions of NI-Motion. Similarly, configuration settings you build and save in Measurement & Automation Explorer (MAX) with NI-Motion 7.5 will not work with applications you build in earlier versions of NI-Motion.
    LabVIEW Real-Time Users
    Note:  To use NI-Motion 7.5 with a real-time target, you must reinstall the NI-Motion driver software on the real-time target system using MAX. Driver versions on the host and target system must be the same for proper operation. Refer to the Measurement & Automation Explorer Remote Systems Help by selecting Help»Help Topics»Remote Systems in MAX for information about installing software on the remote system.
    NI-Motion 7.5 is compatible with the LabVIEW Real-Time Module version 7.1.1 or later.
    Installation and Configuration Instructions
    The following sections include important information about installing NI-Motion 7.5, instructions for downloading and installing NI-Motion 7.5 from the Web or from the CD, and information about NI-Motion firmware.
    Note  NI-Motion 7.5 is supported on Microsoft Windows Vista/XP/2000. If you are using Windows Me/98/NT, do not upgrade to NI-Motion version 7.5. Continue using NI-Motion version 6.1.x.
    Tip  For optimal performance, update your operating system to the latest service pack and apply all security patches. This is especially important on Windows 2000 systems. Refer to KnowledgeBase article 45O8JNHR at ni.com/kb for more information.
    Downloading NI-Motion 7.5 from the Web
    Installing from the CD
    Changing Firmware Files to an Earlier Version of NI-Motion
    NI-Motion 7.5 Changes and Enhancements
    NI-Motion 7.5 General Considerations
    NI-Motion 7.5 Known Issues
    Previous NI-Motion Changes and Enhancements
    Important Information
    © 2007 National Instruments Corporation. All rights reserved.
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your CD, or ni.com/patents.
    GMT+8, 2025-12-2 16:58
