查看: 3554|回复: 0
[NI驱动程序] NI-Motion 5.2.7 Update Win32Eng NI运动驱动程序5.2.7版升级工具 适用LabVIEW6.1
    8 小时前
  • 签到天数: 3730 天
    连续签到: 57 天
    发表于 2020-6-22 11:30:51 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-Motion为NI运动器件的驱动程序,开发软件为NI SoftMotion,及Motion Assistant。
    NI-Motion 5.2.7(仅为升级工具,请先安装5.2版)
    发布日期
    02-8-2
    受支持的操作系统
    Windows 2000
    Windows 95
    Windows 98
    Windows ME
    Windows NT
    Windows XP
    语言
    英文
    校验和
    (MD5)
    e0620cd881ff17fa00059f62ced7cbbf
    百度网盘下载(限速,请开会员或使用破解限速工具):
    链接: 请注册视觉论坛用户,登录后购买附件下载查看 提取码: 请注册登录视觉论坛会员,购买附件查看
    请注册登录视觉论坛会员,购买附件查看
    Motion5.2.7.txt (276 Bytes, 下载次数: 1, 售价: 5 圆)
    NI-Motion 5.2.7Copyright 2006 National Instruments Corporation.All Rights Reserved.You must have NI-Motion 5.2.x to install this update. It is not a full install by itself, and requires a previous version to install over. To install this update, download the NI-Motion 5.2.7.exe file, and then run it.Issues addressed in this patch:1. Rare Encoder Glitches2. Find Index Routine Moved Passed the Limit3. NI 7340 & NI 7330 supportIssues Addressed:=================Rare Encoder Glitches---------------------Under very rare circumstances, the encoder feedback returned erroneous results. The firmware has been updated to eliminate this encoder glitch.Find Index Routine Moved Passed the Limit-----------------------------------------Periodically, calling the Find Index routine while at a limit switch moved the motor beyond the limit.  This behavior has been corrected.NI 7340 & NI 7330 support-------------------------If it is not practical to upgrade your NI-Motion driver to version 6.1.2 or later you must install NI-Motion 5.2.7. This update contains only the changes required to use the updated devices with NI-Motion.  To minimize the impact of firmware changes on your application you may wish to stay with the same major firmware version.Updating Firmware:==================Complete the following steps to change the firmware on your device.1. Launch MAX.2. Expand Devices and Interfaces.3. Select the appropriate motion controller. 4. Click the Firmware tab. 5. Right-click the firmware name in the firmware configuration view and select Download All Files.
    GMT+8, 2025-12-2 16:56
