查看: 2952|回复: 0
[NI软件产品] NI Motion Assistant 2.8 Win32Eng LV运动助手2.8版 适用LabVIEW2012
    昨天 07:44
  • 签到天数: 3537 天
    连续签到: 7 天
    发表于 2020-6-19 17:24:19 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI MotionAssistant280
    运动助手软件,NI官方网站提供的1.2版、2.1版、2.2版、2.3.1版均缺失无资源可提供。仅提供2.3以及2.5以后的版本,最新的版本为适用 LabVIEW2016的运动助手1600版本。
    NI Motion Assistant是一个独立的原型建模工具,可用于快速开发运动应用程序。 NI Motion Assistant无需编写代码即可通过图形化的方式实现对运动应用程序的构建、预览和测试。 对于有经验的运动控制用户,NI Motion Assistant提升了应用程序的开发速度,自动创建可用于生成独立应用程序或加入其它应用程序的LabVIEW代码、C代码或代码处方。 NI Motion Assistant软件还提供LabVIEW、C或Visual Basic范例程序,用于演示NI Motion Assistant应用程序编程接口(API)的功能。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    链接: 请注册视觉论坛用户,登录后购买附件下载查看 提取码: 请注册登录视觉论坛会员,购买附件查看
    请注册登录视觉论坛会员,购买附件查看 MA2.8.txt (256 Bytes, 下载次数: 0, 售价: 10 元)
    NI Motion Assistant™ Release Notes
    This document contains installation and programming considerations, system requirements, licensing information, a list of changes in this version of NI Motion Assistant, and a list of NI Motion Assistant known issues.
    Contents
    General Information
    Installation and Upgrade Information
    Hardware Support
    NI Motion Assistant 2.8 Changes and Enhancements
    NI Motion Assistant 2.8 General Considerations
    NI Motion Assistant 2.8 Known Issues
    Previous NI Motion Assistant Changes and Enhancements
    General Information
    National Instruments Motion Assistant is a stand-alone prototyping tool for quickly developing motion applications. NI Motion Assistant allows you to graphically construct and preview motion applications without writing any code. When you have completed a prototype in NI Motion Assistant, you can generate LabVIEW or C code for further application development using NI-Motion. You also can generate code recipes for coding the application in a text-based language, such as Microsoft Visual Basic.
    NI Motion Assistant includes the following features:
    • Simple and complex moves—NI Motion Assistant offers several move types that represent the most often used moves in motion control:
      • Reference moves include moves to find home, index, forward limit, reverse limit, and center.
      • Straight-line moves create simple point-to-point movement for basic motion applications.
      • Arc moves enable two-dimensional (circular), three-dimensional (spherical), and helical arc types.
      • Contouring moves allow any trajectory specified by a series of points.
      • CAD moves create a move profile based on an imported CAD file.
    • Graphical prototyping—NI Motion Assistant provides a fully graphical interface that allows you to prototype a motion application by creating a series of moves. The position, velocity, and acceleration of the moves are graphed and editable in two and three dimensions.
      NI Motion Assistant provides the full function set implementations for LabVIEW, LabWindows™/CVI™, C, and Visual Basic. The NI Motion Assistant software also provides example programs for LabVIEW, C, or Visual Basic to demonstrate the NI Motion Assistant application programming interface (API) functionality.
    • Code creation—When you are finished creating a prototype of your motion control application, you can use the NI Motion Assistant code creation feature to export LabVIEW or C code for completing the application with NI-Motion. You also can generate code recipes to follow for coding the application in a text language, such as Microsoft Visual Basic.
      NI Motion Assistant also creates placeholders in the LabVIEW code, C code, and code recipes for non-motion code, such as data or image acquisition, in any location you specify.
    Back to Top
    Note:  If you already have a registered version of NI Motion Assistant 1.3 or earlier, you can purchase an upgrade to NI Motion Assistant 2.8 using National Instruments part number 850553C-01. Registered NI Motion Assistant 2.x users can upgrade to NI Motion Assistant 2.8 for free.
    Installation
    You can run the NI Motion Assistant installer on the following operating systems:
    • Windows XP Service Pack 3 or later (32-bit)
    NI Motion Assistant runs as a 32-bit application on all operating systems.
    Notes:
    • NI Motion Assistant is compatible with 32-bit LabVIEW only. Therefore, you must have 32-bit LabVIEW installed even if you use a 64-bit OS.
    • Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the info code PAESupport.
    NI Motion Assistant does not support Windows 2000/NT/Me/98/95, Windows XP x64, or the Windows Server non-R2 editions. If you are using any of these operating systems, do not install NI Motion Assistant 2.8.
    Note  You must install the NI-Motion driver software before installing NI Motion Assistant. Visit ni.com/downloads for the latest NI-Motion software.
    Installing from the LabVIEW 2012 Platform DVDs
    You can install all of your LabVIEW products—including NI Motion Assistant—using the LabVIEW 2012 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW 2012 Platform DVDs, refer to the National Instruments Web site at ni.com.
    Note  You can purchase and install NI Motion Assistant separately. To install NI Motion Assistant, insert the NI Motion Assistant CD into the CD-ROM drive. The NI Motion Assistant installation screen launches automatically. Select the appropriate option depending on whether you want to install NI Motion Assistant, review the release notes, or exit the installation program.
    Visit ni.com/downloads for NI Motion Assistant updates.
    Licensing NI Motion Assistant
    At the end of the NI Motion Assistant installation process, a licensing wizard appears. Follow the onscreen instructions to activate the license for NI Motion Assistant.
    Refer to the Activating Your Software topic in the NI Motion Assistant Help for detailed information about activation.
    Note  You are required to activate the license for NI Motion Assistant even if you previously had a licensed version.
    Back to Top
    Hardware Support
    NI Motion Assistant is compatible with NI-Motion 8.0 and later. To create LabVIEW code from an NI Motion Assistant prototype, you must have LabVIEW 2009 or later installed. NI Motion Assistant requires that either the actual controller or the virtual representation of one of the following motion controllers be installed in the computer:
    • NI 7350 Series Controllers—All NI Motion Assistant features are available for this family of controllers.
    • NI 7340 Series Controllers—All NI Motion Assistant features are available for this family of controllers, excluding multiple and periodic position compare outputs.
    • NI 7330 Series Controllers—NI Motion Assistant reference, straight-line, and arc move features are available for this family of controllers, excluding multiple and periodic position compare outputs.
    • NI PCI-7390 Controllers—NI Motion Assistant reference, straight-line, and arc move features are available for this controller, excluding multiple and periodic position compare outputs.
    Using NI Motion Assistant without Hardware
    If you do not have one of the listed motion controllers, you can use a virtual motion controller in Measurement & Automation Explorer (MAX) to preview the functionality of NI Motion Assistant. Follow the instructions in the NI Motion Assistant Help to install a virtual motion controller. You must have NI-Motion 7.0 or later installed to use a virtual motion controller.
    Back to Top
    NI Motion Assistant 2.8 Changes and EnhancementsLabVIEW 2012 Support
    NI Motion Assistant 2.8 is fully supported on LabVIEW 2012.
    Back to Top
    NI Motion Assistant 2.8 General ConsiderationsUsing NI Motion Assistant with the LabVIEW Real-Time Module
    You cannot generate LabVIEW code from an NI Motion Assistant script for a real-time target. Refer to the LabVIEW Real-Time Module Considerations section of How do I create code from a motion script? in the NI Motion Assistant Help for detailed instructions about creating code for RT targets.
    CAD Moves
    CAD moves are processor and memory intensive operations. For this reason, National Instruments recommends a system with at least a 2 GHz Intel Pentium 4 processor or equivalent and 1 GB of RAM for optimal performance.
    Contoured Moves
    NI Motion Assistant uses a technique called smart contouring to smoothly move through the positions you specify. Refer to the Contoured Move glossary topic of the NI Motion Assistant Help for smart contouring guidelines you must follow to avoid unexpected behavior.
    Calculating Moves
    The controller starts from the current position of the axes and travels to the end of the first move. To ensure that the actual system and the position profile you specify match, you must always begin an NI Motion Assistant script with a Reference Move. Refer to Reference Move in the Motion Step Help book of the NI Motion Assistant Help for detailed instructions about adding and configuring a Reference Move Step.
    Updating Referenced Files in NI Motion Assistant Scripts
    If you make changes to a file referenced in an NI Motion Assistant script, such as buffered breakpoint positions, contour points, or CAD files, you must reload the file for these changes to take effect.
    Back to Top
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in NI Motion Assistant 2.8.
    Back to Top
    Previous Changes and Enhancements
    Refer to KnowledgeBase article 47EKNFFL, NI Motion Assistant Release Notes, at ni.com/kb for access to previous NI Motion Assistant release notes, starting with NI Motion Assistant 1.3.
    Back to Top
    Important Information
    © 2002–2012 National Instruments. All rights reserved.
    CVI, LabVIEW, National Instruments, NI, ni.com, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the Trademark Information at ni.com/trademarks for other National Instruments trademarks. Other product and company names listed are trademarks or trade names of their respective companies.
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your CD, or ni.com/patents.
    GMT+8, 2025-5-13 06:58
