查看: 3423|回复: 0
[LV工具模块] LabVIEW 2011SP1 NI SoftMotion Module Win32 NI运动控制模块2011SP1 适用LV2011SP1
    昨天 21:26
  • 签到天数: 3790 天
    连续签到: 41 天
    发表于 2020-6-16 16:24:53 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2011SP1 SoftMotion模块
    LabVIEW SoftMotion模块可帮助您将运动控制与I/O和视觉应用程序进行集成。
    LabVIEW SoftMotion模块是LabVIEW编程环境的一个附加软件。您可在LabVIEW项目中配置、测试和调整LabVIEW SoftMotion轴。您可以将这些轴绑定到各种NI和第三方硬件配置。该模块具有用于自定义运动应用设计的高级功能,包括轨迹生成和多轴功能,如齿轮和坐标空间。
    百度网盘下载地址(百度限速,请耐心等待。或使用破解工具或开超级会员提速):
    链接: 请注册视觉论坛用户,登录后购买附件下载查看 提取码: 请注册登录视觉论坛会员,购买附件查看
    NI官方下载地址(可能失效或无法下载完成):
    请注册登录视觉论坛会员,购买附件查看
    SMM2011SP1.txt (292 Bytes, 下载次数: 3, 售价: 10 圆)
    LabVIEW 2011 SP1 NI SoftMotion™ Module Readme
    January 2012
    This document contains information to introduce you to the LabVIEW NI SoftMotion Module including installation information, a list of changes in this version of NI SoftMotion, and information about known issues for this version of NI SoftMotion.
    Contents
    Licensing
    New Features and Changes
       Bug Fix List
    General Information
    The LabVIEW NI SoftMotion Module allows you to use the LabVIEW project to configure and test your motion axis settings, tune your servo motors, program deterministic motion profiles, create custom motion applications, and simulate your designs created in SolidWorks.
    For more information about function block programming and using function blocks with the NI SoftMotion Module refer to Motion Profile Development using the Function Block API at zone.ni.com.
    Note: Refer to the NI SoftMotion Selection Guide at zone.ni.com for a description of the different NI SoftMotion Module packages available.
    You can run the LabVIEW 2011 SP1 NI SoftMotion Module installer on the following operating systems:
    • Windows XP (32-bit)
    The LabVIEW NI SoftMotion Module runs as a 32-bit application on all operating systems.
    The LabVIEW NI SoftMotion Module does not support Windows 2000/NT/Me/98/95, Windows XP x64, or the Windows Server non-R2 editions.
    To run the LabVIEW NI SoftMotion Module, National Instruments recommends that your system meet the following requirements in addition to the minimum requirements for the LabVIEW Development System for Windows:
    • 2 GB of memory if using NI SoftMotion for SolidWorks
    • 250 MB of free disk space
    • Pentium 4 processor or equivalent (866 MHz minimum)
    The NI SoftMotion Module is compatible with the following National Instruments software.
    • LabVIEW 2011 SP1 Base, Full, or Professional Development System (32-bit)
    • LabVIEW 2011 SP1 Real-Time Module
    • LabVIEW 2011 SP1 FPGA Module
    • NI-RIO 4.1.0 or later
    • NI-Industrial Communications for EtherCAT® 2.3 or later
    Note  To use NI SoftMotion for SolidWorks you must have SolidWorks 2009 SP2.1 or later (32-bit or 64-bit).
    Installation InstructionsInstalling from the LabVIEW 2011 SP1 Platform DVDs
    You can install all of your LabVIEW products—including the LabVIEW 2011 SP1 NI SoftMotion Module—using the LabVIEW 2011 Platform DVDs. You can find installation instructions for the LabVIEW 2011 SP1 NI SoftMotion Module along with activation instructions in the following locations:
    • LabVIEW 2011 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2011 Platform DVDs, refer to the National Instruments Web site at ni.com.
    Downloading the LabVIEW 2011 SP1 NI SoftMotion Module from the Web
    Complete the following steps to download and install the LabVIEW 2011 SP1 NI SoftMotion Module:
    • Download the LabVIEWNISoftMotionModule2011sp1.exe file from ni.com/updates, and then run it.
      Note  (Windows 7/Vista)  Users may see access and security messages during installation. Accept the prompts to complete the installation.
    • When the installer completes, a dialog box appears that asks if you want to restart, shut down, or restart later. Select Restart.
    LabVIEW NI SoftMotion Module Updates and Notifications
    National Instruments releases critical software updates after product release using the NI Update Service. Visit ni.com/info and enter updates to view a list of all currently available updates.
    National Instruments provides notification of certain critical issues at install time. Visit ni.com/info and enter notifications to view a list of current product notifications.
    Licensing
    The LabVIEW NI SoftMotion Module relies on licensing activation. You must activate a valid LabVIEW NI SoftMotion Module license before you can run the LabVIEW NI SoftMotion Module. To activate the LabVIEW NI SoftMotion Module, use the serial number you received as part of your installation package.
    Refer to the Activation Instructions for National Instruments Software for more information about licensing activation.
    New Features and ChangesNew and Changed in the LabVIEW 2011 SP1 NI SoftMotion Module
    NI SoftMotion Express VI Examples
    Example programs are now available for the NI SoftMotion Express VIs. Refer to Finding Example VIs in the LabVIEW Help for information about how to access the examples.
    Anti-Windup Improvements in the PI Current Loop VI
    The NI SoftMotion PI Current Loop FPGA Motor Control VI contains improved anti-windup logic using an integral contribution (Ic) term in place of the integral limit (Ilim) term. The Ic term coerces the setpoint to prevent excessive overshoot in the case of output saturation.
    Position Compare and Position Capture Express VI Behavior Change
    The Position Compare and Position Capture Express VIs have been modified to add an additional input, return when active?. This input is TRUE by default and causes the Express VI to return as soon as the method is active. To retain the previous behavior, change the input to FALSE. This causes the Express VI to block until the compare or capture operation has occurred.
    Note  Previously dropped position compare and position capture VIs retain the previous behavior and do not contain the new input.
    New and Changed in the LabVIEW 2011 NI SoftMotion ModuleConfiguration API
    The new NI SoftMotion Module Configuration API adds the ability to programmatically set the same axis properties available in the Axis Configuration dialog box in your applications. Refer to Configuring NI SoftMotion Axes in the NI SoftMotion Module book of the LabVIEW Help, available by selecting Help»LabVIEW Help for more information.
    Tip  Refer to the example VIs in \examples\Motion\ConfigurationAPI for examples using the new Axis properties in an application.
    You can now create motion control applications that take advantage of the ease of use of Express VIs.
    Profile Generation
    Using the new Solve Profile method for straight-line, arc, and contour moves, you can generate a motion profile using specified constraints and obtain position, velocity, and other data without executing a move on an axis or coordinate resource. This data can be used for prototyping, debugging, or for generating position setpoints for the new Motor Control VIs.
    Motor Control VIs
    The NI SoftMotion FPGA palette adds new Motor Control VIs that allow for servo and stepper motor control, including VIs for spline interpolation, PID and cascaded position-velocity control loops, incremental encoder handling, and motion I/O operations such as position compare and position capture. The Motor Control VIs also include 3-phase servo VIs used for implementing field-oriented control commutation that can be used with the NI 9502 C Series brushless servo drive module. To use the NI 9502 with LabVIEW 2011 or later, you must install NI-RIO 4.0.0 with the CompactRIO Module Support 4.0.1 update, available at ni.com/drivers, which adds software support for the NI 9502 module in LabVIEW.
    Programmatic Table Creation
    The Create Motion Resource VI adds a Create Motion Resource Item instance that allows you to programmatically create a table resource for use in contour moves.
    Contour Points[][] Input
    The new Contour Express VI and Contour Points[][] property allow you to provide contour points for synchronous contour moves as an array of position points rather than providing them in a table.
    Wait Until Done VI
    The NI SoftMotion palette has a new Wait Until Done VI for synchronous operations. This VI implements an adaptive polling method and is recommended for use both with Express VI applications and with NI SoftMotion properties and methods in place of the Wait Until Done method.
    Communication Between RT Targets
    Using axes, coordinates, and tables on an RT target from another RT target is now supported. Refer to Motion Resources in the NI SoftMotion Module book of the LabVIEW Help, available by selecting Help»LabVIEW Help for more information.
    NI SoftMotion for SolidWorks Simulation Start/Stop Behavior
    Instead of starting and stopping SolidWorks simulations by switching the NI Scan Engine mode, there is now a shortcut menu option for each operation. Refer to Starting and Stopping a SolidWorks Simulation in LabVIEW in the NI SoftMotion Module book of the LabVIEW Help, available by selecting Help»LabVIEW Help for more information.
    Updated Function Block Palette Location
    The NI SoftMotion function blocks are now located under the Advanced subpalette.
    LabVIEW 2011 SP1 NI SoftMotion Module Bug Fix List
    You can access the software and documentation bug fix list online. Refer to the National Instruments Web site for an up-to-date list of bug fixes in the LabVIEW 2011 SP1 NI SoftMotion Module.
    General InformationLabVIEW Real-Time Users
    To use the updates and features included in the LabVIEW 2011 SP1 NI SoftMotion Module, you must install the LabVIEW 2011 SP1 NI SoftMotion Module software on the LabVIEW Real-Time target system using Measurement & Automation Explorer (MAX).
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from the pull-down menu in LabVIEW, for information about NI SoftMotion Module concepts, using NI SoftMotion, step-by-step instructions using the LabVIEW NI SoftMotion Module, and reference information about NI SoftMotion VIs and functions.
    LabVIEW examples for the NI SoftMotion Module are located in the labview\examples\Motion folder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    LabVIEW 2011 SP1 NI SoftMotion Module Known Issues
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW 2011 SP1 NI SoftMotion Module.
    Back to Top
    Important Information
    © 2012 National Instruments Corporation. All rights reserved.
    In regards to components that use Expat software, the following copyright notice applies. Copyright (c) 1998, 1999, 2000 Thai Open Source Software Center Ltd
    and Clark Cooper
    Copyright (c) 2001, 2002, 2003, 2004, 2005, 2006 Expat maintainers.
    Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions:
    The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
    THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
    LabVIEW, National Instruments, NI, ni.com, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks. EtherCAT® is a registered trademark of Beckhoff Automation GmbH. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    GMT+8, 2026-2-2 08:04
