查看: 7158|回复: 7
[LabVIEW] NI LabVIEW 2020 Pro Linux64Eng LV2020Linux系统专业版 64位英文版离线安装包下载
  • 签到天数: 3696 天
    连续签到: 23 天
    发表于 2020-5-20 16:22:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2020专业版(专业版可以生成应用程序,完整版不具体生成应用程序功能。Linux版仅支持64位系统,不支持32位的Linux。)
    发布日期:
    20-5-15
    SUSE
    Scientific Linux
    CentOS
    RedHat
    Linux
    语言:
    英文
    文件名: 2020LV-LinuxPro.iso
    文件大小: 1189191680 字节 (1.11 GB)
    修改日期: 2023-03-09 10:51
    MD5: 70bff401ca608203af3b94f8dffbe39f
    SHA1: 6ca53dcd2ce23a9d5ca42a3e6029b8d69cf9df56
    SHA256: 2cf4b1ef0bbf947741cb5c6f3d2dd8606cda077d7d1e9076391322e961542aa4
    CRC32: e9da3e5f
    请注册视觉论坛会员登录后购买附件下载查看
    LabVIEW2020 X64Linux Pro.txt (389 Bytes, 下载次数: 25, 售价: 100 圆)
    LabVIEW 2020 Readme for GNU/Linux
    March 2020
    This file contains important information about LabVIEW 2020 for Linux, including system requirements, installation instructions, known issues, and a partial list of bugs fixed.
    Supported Drivers
    LabVIEW 2020 for Linux has the following requirements:
    Linux
    openSUSE Leap 15.0
    openSUSE Leap 15.1
    Red Hat Enterprise Linux 7
    Red Hat Enterprise Linux 8
    CentOS 7
    CentOS 8
    Note
    • LabVIEW 2020 for Linux is available only in 64-bit.
    To install LabVIEW modules and toolkits, refer to the readme of each product for installation instructions. The VI Analyzer Toolkits installs with the LabVIEW Professional Development System for Linux.
    Refer to the LabVIEW Upgrade Notes for information about protecting existing VIs and projects before installing a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2020.
    Changes to selection rules for named Bundle and Unbundle nodes inside malleable VIs
    The rules for how LabVIEW selects cluster elements when you use a Bundle By Name function, Unbundle By Name function, or Unbundle / Bundle Elements Border Node have improved. The improvements may cause existing code to behave differently than you expect when you use these nodes inside a malleable VI. Visit ni.com/r/eakjbu for more information about how these changes impact existing code.
    Complete the following steps to install a patch on computers with LabVIEW 2020. Replace f# with the specific patch you are installing.
    • Close all NI software.
    • Download LV2020_f#LPatch.tgz into a folder. For example, download the file to ~/Desktop/Patch/LV2020_f#LPatch.tgz.
    • Unpack LV2020_f#LPatch.tgz. For example, cd ~/Desktop/Patch and tar -xzf LV2020_f#LPatch.tgz.
    • Run the installation script as root. For example, type su and enter the password. Then run ./INSTALL.
    • After the installation script reports that Patch installation completed, verify that the patch installed correctly. Select Help»About LabVIEW and look for 20.0.0f# on the right portion of the window.
    Visit LabVIEW 2020 Patch Details for detailed information about all patches available for LabVIEW 2020 and issues fixed in each patch.
    LabVIEW 2020 for Linux supports the following modules and toolkits.
    • MathScript Module2
    • VI Analyzer Toolkit3
    • Application Builder3
    Supported Drivers
    Refer to the NI website for information about drivers compatible with LabVIEW for Linux. To use hardware with LabVIEW 2020, install the latest version of the driver for the device. Refer to the readme of each driver for more information about system requirements and installation instructions.
    You can access the software and documentation known issues list online. Visit LabVIEW 2020 Known Issues for an up-to-date list of known issues.
    The following items are the IDs and titles of a subset of issues fixed in LabVIEW 2020. This is not an exhaustive list of issues fixed in the current version of LabVIEW. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    917628LabVIEW Runtime Engine encounters Worker Thread Limit when using web services on Linux RT-based cRIO.
    931175EXE including 'Std Deviation and Variance' VI is unloadable.
    984819Incorrect behavior when using a Boolean control from the System palette.
    984834LabVIEW Application Builder fails to build a Source Distribution on Windows when using some specific vi.lib VIs that contain non-Windows components.
    984861When making multiple calls to Python function in a For Loop, the Python execution treats the passed data as a list, rather than a NumPy array.
    985551Hovering over an override method in the Project Explorer does not show parent class description if the VI has empty description.
    985552Special characters (\r, \n, etc.) are not correctly converted to JSON when using LabVIEW Web services.
    985554Calling a Channel Write VI by reference in a loop results in a compiler error.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2020.
    © 2004–2020 National Instruments. All rights reserved.
    374718N-01
  • 签到天数: 241 天
    [LV.8]800PFS
    发表于 2020-8-18 17:55:23 | 显示全部楼层 来自:河北省石家庄市裕华区 联通
  • 签到天数: 241 天
    [LV.8]800PFS
    发表于 2020-10-17 21:42:15 | 显示全部楼层 来自:河北省石家庄市 电信
    发表于 2021-5-28 10:39:27 | 显示全部楼层 来自:江苏省苏州市 电信
  • 签到天数: 3696 天
    连续签到: 23 天
     楼主| 发表于 2021-5-28 11:12:27 | 显示全部楼层 来自:广东省东莞市 电信
    不了解。没有使用过。可以参考:
    在Linux和macOS的系统上安装LabVIEW后未要求激活码_LabVIEW_图像处理|编程|机器视觉|教程_机器视觉论坛VISIONBBS_视觉之家VISIONHOME_机器视觉光源_光源控制器_工业相机_工业镜头_机器视觉方案系统_LabVIEW图像处理教程_石鑫华视觉网_东莞市华动智能科技有限公司
    http://visionbbs.com/thread-25198-1-1.html
  • 签到天数: 3696 天
    连续签到: 23 天
     楼主| 发表于 2021-5-28 11:12:35 | 显示全部楼层 来自:广东省东莞市 电信
    kingking 发表于 2021-5-28 10:39
    这个是破解版本?
    不了解。没有使用过。可以参考:
    发表于 2021-5-28 11:28:50 | 显示全部楼层 来自:江苏省苏州市 电信
    石鑫华视觉 发表于 2021-5-28 11:12
    不了解。没有使用过。可以参考:
    在Linux和macOS的系统上安装LabVIEW后未要求激活码_LabVIEW_图像处理| ...
    有没有Linux破解方式?
  • 签到天数: 3696 天
    连续签到: 23 天
     楼主| 发表于 2021-5-28 12:08:04 | 显示全部楼层 来自:广东省东莞市 电信
    GMT+8, 2025-10-29 12:31
