查看: 4692|回复: 0
[LabVIEW] NI LabVIEW 2020 Pro MAC64Eng LV2020苹果系统专业版 64位英文版离线安装包下载
  • 签到天数: 3696 天
    连续签到: 23 天
    发表于 2020-5-20 16:15:41 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2020专业版(专业版可以生成应用程序,完整版不具备生成应用程序功能)
    发布日期:
    20-5-15
    Mac OS
    语言:
    英文
    文件名: 2020LV-MacPro.iso
    文件大小: 1254604800 字节 (1.17 GB)
    修改日期: 2023-03-09 10:52
    MD5: 75c8f8d2571eb492df5981b775c96ab9
    SHA1: cf965820fb925d882f53de22dd6c25ed9e950816
    SHA256: c91a0b08cc317badd99793b08c766a372072bd14529d70cb0daf6df11d523b45
    CRC32: 57221be6
    请注册视觉论坛会员登录后购买附件下载查看
    LabVIEW2020 X64MAC Pro.txt (387 Bytes, 下载次数: 12, 售价: 100 圆)
    LabVIEW 2020 Readme for macOS
    March 2020
    This file contains important information about LabVIEW 2020 for macOS, including system requirements, installation instructions, known issues, and a partial list of bugs fixed. LabVIEW 2020 for macOS is available only in 64-bit.
    Supported Drivers
    LabVIEW 2020 for macOS has the following requirements:
    macOS
    RAM256 MB2 GB
    Operating SystemmacOS 10.14 or 10.15macOS 10.14 or 10.15
    Note
    • LabVIEW 2020 for macOS is available only in 64-bit.
    Note  If you download the installation image from ni.com, you may run into a macOS warning when you double-click the installer to run. Instead, right-click the installer and select Open. When you see the warning message, click Open to run the installer and proceed with the installation.
    Refer to the LabVIEW Upgrade Notes for information about protecting existing VIs and projects before installing a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2020.
    Changes to selection rules for named Bundle and Unbundle nodes inside malleable VIs
    The rules for how LabVIEW selects cluster elements when you use a Bundle By Name function, Unbundle By Name function, or Unbundle / Bundle Elements Border Node have improved. The improvements may cause existing code to behave differently than you expect when you use these nodes inside a malleable VI. Visit ni.com/r/eakjbu for more information about how these changes impact existing code.
    Complete the following steps to install a patch on computers with LabVIEW 2020. Replace f# with the specific patch you are installing.
    • Close all NI software.
    • Mount LabVIEW2020f#.dmg and run LabVIEW 2020 f# Patch.
    • Verify that the patch installs correctly. Select Help»About LabVIEW and look for 20.0.0f# on the right portion of the window.
    Visit LabVIEW 2020 Patch Details for detailed information about all patches available for LabVIEW 2020 and issues fixed in each patch.
    LabVIEW 2020 for macOS supports the following modules and toolkits.
    • MathScript Module2
    • VI Analyzer Toolkit3
    • Application Builder3
    Supported Drivers
    LabVIEW 2020 for macOS supports the following drivers. To use hardware with LabVIEW 2020, install the latest version of the driver for the device.
    • NI-488.2
    • NI-DAQmx Base
    • NI-VISA
    Refer to the readme of each driver for more information about system requirements and installation instructions.
    You can access the software and documentation known issues list online. Visit LabVIEW 2020 Known Issues for an up-to-date list of known issues.
    The following items are the IDs and titles of a subset of issues fixed in LabVIEW 2020. This is not an exhaustive list of issues fixed in the current version of LabVIEW. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    917628LabVIEW Runtime Engine encounters Worker Thread Limit when using web services on Linux RT-based cRIO.
    931175EXE including 'Std Deviation and Variance' VI is unloadable.
    984819Incorrect behavior when using a Boolean control from the System palette.
    984834LabVIEW Application Builder fails to build a Source Distribution on Windows when using some specific vi.lib VIs that contain non-Windows components.
    984861When making multiple calls to Python function in a For Loop, the Python execution treats the passed data as a list, rather than a NumPy array.
    985551Hovering over an override method in the Project Explorer does not show parent class description if the VI has empty description.
    985552Special characters (\r, \n, etc.) are not correctly converted to JSON when using LabVIEW Web services.
    985554Calling a Channel Write VI by reference in a loop results in a compiler error.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2020.
    © 2004–2020 National Instruments. All rights reserved.
    374717N-01
    GMT+8, 2025-10-29 12:28
