查看: 8198|回复: 3
[LabVIEW] NI LabVIEW 2020 Full Linux64English LV2020Linux系统完整版 64位英文版离线安装包下载
  • 签到天数: 3696 天
    连续签到: 23 天
    发表于 2020-5-20 16:08:51 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2020完整版
    发布日期:
    20-5-15
    SUSE
    Scientific Linux
    CentOS
    RedHat
    Linux
    语言:
    英文
    文件名: 2020LV-LinuxFull.iso
    文件大小: 1156636672 字节 (1.08 GB)
    修改日期: 2023-03-09 10:48
    MD5: e5b6eb214788149e14927e2e9e939c5f
    SHA1: dc7f9cade91251c5a8b7a2c66134c8d03227d67f
    SHA256: 878f4d9d4c31b07fd72152a07e50e172911ee5d0d5b87e42e1b0458e103b9a7b
    CRC32: 7ffa82e0
    请注册视觉论坛会员登录后购买附件下载查看
    LabVIEW2020 X64Linux Full.txt (390 Bytes, 下载次数: 13, 售价: 80 圆)
    LabVIEW 2020 Readme for GNU/Linux
    March 2020
    This file contains important information about LabVIEW 2020 for Linux, including system requirements, installation instructions, known issues, and a partial list of bugs fixed.
    Supported Drivers
    LabVIEW 2020 for Linux has the following requirements:
    Linux
    openSUSE Leap 15.0
    openSUSE Leap 15.1
    Red Hat Enterprise Linux 7
    Red Hat Enterprise Linux 8
    CentOS 7
    CentOS 8
    Note
    • LabVIEW 2020 for Linux is available only in 64-bit.
    To install LabVIEW modules and toolkits, refer to the readme of each product for installation instructions. The VI Analyzer Toolkits installs with the LabVIEW Professional Development System for Linux.
    Refer to the LabVIEW Upgrade Notes for information about protecting existing VIs and projects before installing a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2020.
    Changes to selection rules for named Bundle and Unbundle nodes inside malleable VIs
    The rules for how LabVIEW selects cluster elements when you use a Bundle By Name function, Unbundle By Name function, or Unbundle / Bundle Elements Border Node have improved. The improvements may cause existing code to behave differently than you expect when you use these nodes inside a malleable VI. Visit ni.com/r/eakjbu for more information about how these changes impact existing code.
    Complete the following steps to install a patch on computers with LabVIEW 2020. Replace f# with the specific patch you are installing.
    • Close all NI software.
    • Download LV2020_f#LPatch.tgz into a folder. For example, download the file to ~/Desktop/Patch/LV2020_f#LPatch.tgz.
    • Unpack LV2020_f#LPatch.tgz. For example, cd ~/Desktop/Patch and tar -xzf LV2020_f#LPatch.tgz.
    • Run the installation script as root. For example, type su and enter the password. Then run ./INSTALL.
    • After the installation script reports that Patch installation completed, verify that the patch installed correctly. Select Help»About LabVIEW and look for 20.0.0f# on the right portion of the window.
    Visit LabVIEW 2020 Patch Details for detailed information about all patches available for LabVIEW 2020 and issues fixed in each patch.
    LabVIEW 2020 for Linux supports the following modules and toolkits.
    • MathScript Module2
    • VI Analyzer Toolkit3
    • Application Builder3
    Supported Drivers
    Refer to the NI website for information about drivers compatible with LabVIEW for Linux. To use hardware with LabVIEW 2020, install the latest version of the driver for the device. Refer to the readme of each driver for more information about system requirements and installation instructions.
    You can access the software and documentation known issues list online. Visit LabVIEW 2020 Known Issues for an up-to-date list of known issues.
    The following items are the IDs and titles of a subset of issues fixed in LabVIEW 2020. This is not an exhaustive list of issues fixed in the current version of LabVIEW. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    917628LabVIEW Runtime Engine encounters Worker Thread Limit when using web services on Linux RT-based cRIO.
    931175EXE including 'Std Deviation and Variance' VI is unloadable.
    984819Incorrect behavior when using a Boolean control from the System palette.
    984834LabVIEW Application Builder fails to build a Source Distribution on Windows when using some specific vi.lib VIs that contain non-Windows components.
    984861When making multiple calls to Python function in a For Loop, the Python execution treats the passed data as a list, rather than a NumPy array.
    985551Hovering over an override method in the Project Explorer does not show parent class description if the VI has empty description.
    985552Special characters (\r, \n, etc.) are not correctly converted to JSON when using LabVIEW Web services.
    985554Calling a Channel Write VI by reference in a loop results in a compiler error.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2020.
    © 2004–2020 National Instruments. All rights reserved.
    374718N-01
    发表于 2021-9-27 14:23:45 | 显示全部楼层 来自:新加坡 阿里云
    发表于 2021-9-27 14:23:56 | 显示全部楼层 来自:新加坡 阿里云
    GMT+8, 2025-10-29 12:31
