查看: 2779|回复: 1
[转载] LabVIEW 2020 Readme for Windows
    13 小时前
  • 签到天数: 3594 天
    连续签到: 2 天
    发表于 2020-4-20 18:07:29 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    March 2020
    This file contains important information about LabVIEW 2020 for Windows, including system requirements, installation instructions, known issues, and a partial list of bugs fixed for LabVIEW 2020.
    LabVIEW 2020 (64-bit)
    Patch Details
    LabVIEW Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    End-of-Life Products
    LabVIEW 2020 has the following requirements:
    Operating SystemWindows 10 (version 1909)/8.1 Update 12/7 SP13
    Windows Server 2016
    Windows Server 2012 R22
    Windows Server 2008 R2 SP13
    Windows Server 2016
    1 LabVIEW and LabVIEW Run-Time Engine require processors of the Pentium 4M/G1 generation or later, which are capable of executing SSE2 instructions.
    2 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    3 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    Note
    • You cannot access LabVIEW using a Guest account on Windows.
    • In 2016 LabVIEW dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. LabVIEW 2020 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use LabVIEW 2020 to an unsupported OS. Additionally, after installing LabVIEW 2020, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio™ on an unsupported OS. For more information about the changes to our OS support for 2016, visit ni.com/r/OSSupport2016.
    • Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/r/PAESupport.
    • Refer to LabVIEW Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    NI installs software using NI Package Manager. If you do not already have NI software installed, LabVIEW installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • When prompted, enter the serial number to activate LabVIEW. Your serial number can be found at ni.com/myproducts. If you are managing your license with a volume license server, you should receive your volume license file by email.
    Refer to the LabVIEW Upgrade Notes for information about protecting existing VIs and projects before installing a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2020.
    Changes to selection rules for named Bundle and Unbundle nodes inside malleable VIs
    The rules for how LabVIEW selects cluster elements when you use a Bundle By Name function, Unbundle By Name function, or Unbundle / Bundle Elements Border Node have improved. The improvements may cause existing code to behave differently than you expect when you use these nodes inside a malleable VI. Visit ni.com/r/eakjbu for more information about how these changes impact existing code.
    Use the LabVIEW Platform media to install modules and toolkits supported by LabVIEW 2020 (32-bit) and LabVIEW 2020 (64-bit). When run on Windows (64-bit), LabVIEW (64-bit) provides access to more memory than a 32-bit operating system or a 32-bit application can provide. LabVIEW (64-bit) is available in English only.
    Refer to the NI website for information about drivers compatible with LabVIEW 2020 (64-bit). For GPIB devices, you must use at least NI-488.2 2.6 for Windows. Refer to the specific hardware documentation for more information about compatibility with LabVIEW (64-bit).
    LabVIEW 2020 (64-bit) supports a limited number of modules and toolkits. The following table compares the modules and toolkits supported by LabVIEW (32-bit) and LabVIEW (64-bit).
    OK
    OK
    OK
    OK1
    Database Connectivity Toolkit
    OK
    OK
    OK
    OK
    OK
    Digital Filter Design Toolkit
    OK
    OK
    FPGA Module
    OK
    OK
    MathScript Module
    OK
    OK2
    Real-Time Module
    OK
    OK
    OK
    Sound and Vibration Toolkit
    OK
    OK
    Unit Test Framework Toolkit
    OK
    OK
    VI Analyzer Toolkit
    OK
    OK
    Vision Development Module
    OK
    OK
    You can access the software and documentation known issues list online. Visit LabVIEW 2020 Known Issues for an up-to-date list of known issues.
    The following items are the IDs and titles of a subset of issues fixed in LabVIEW 2020. This is not an exhaustive list of issues fixed in the current version of LabVIEW. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    917628LabVIEW Runtime Engine encounters Worker Thread Limit when using web services on Linux RT-based cRIO.
    931175EXE including 'Std Deviation and Variance' VI is unloadable.
    984819Incorrect behavior when using a Boolean control from the System palette.
    984834LabVIEW Application Builder fails to build a Source Distribution on Windows when using some specific vi.lib VIs that contain non-Windows components.
    984861When making multiple calls to Python function in a For Loop, the Python execution treats the passed data as a list, rather than a NumPy array.
    985551Hovering over an override method in the Project Explorer does not show parent class description if the VI has empty description.
    985552Special characters (\r, \n, etc.) are not correctly converted to JSON when using LabVIEW Web services.
    985554Calling a Channel Write VI by reference in a loop results in a compiler error.
    Patch Details
    Visit LabVIEW 2020 Patch Details for detailed information about all patches available for LabVIEW 2020 and issues fixed in each patch.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2020.
    LabVIEW will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    The LabVIEW Robotics Module, LabVIEW SoftMotion Module, and SignalExpress have reached the end of their product life cycle.
    The following table contains the end-of-life (EOL) milestones for these products. You can access support for these products through the last order date at ni.com/support. After the last order date, NI continues to offer technical support through the end-of-support date via online discussion forums only at forums.ni.com.
    Last Release
    Last Order Date
    End of Support Date
    LabVIEW Robotics Module2019June 30, 2020June 2023
    LabVIEW SoftMotion Module2018June 30, 2020June 2021
    SignalExpress2015July 31, 2020July 2024
    © 2004–2020 National Instruments. All rights reserved.
    374715N-01
    LabVIEW 2020下载:
    将于2020年5月发布最新版的LabVIEW2020及相关更新的工具包模块等,敬请期待。
    4 天前
  • 签到天数: 240 天
    [LV.8]800PFS
    发表于 2020-5-26 08:48:29 | 显示全部楼层 来自:河北省石家庄市 电信
    不知道 最近两三年的高端版本的labview 的硬件签名该如何绕过去
    GMT+8, 2025-7-15 23:35
