查看: 2599|回复: 0
[Patch补丁] NI LabVIEW 7.1.1f2 Update for Windows LV7.1.1f2升级补丁32位
    14 小时前
  • 签到天数: 3629 天
    连续签到: 3 天
    发表于 2020-4-4 17:17:11 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LV 7.1.1 F2
    百度网盘和官方下载地址:
    LV7.1.1f2update.txt (186 Bytes, 下载次数: 0, 售价: 5 圆)
    YOU NEED TO HAVE LabVIEW 7.1.1 INSTALLED!
    The fixes are provided as a zip file.  Back up the original files before replacing
    them with the fixes.  The fixes only affect the development environment, there is
    no need to update the Run-Time Engine.
    LV711f2.zip is for the LabVIEW development system and should be unzipped to the
    ..\National Instrumenst\LabVIEW 7.1 folder.  It contians three files:
    labview.exe
    resource\labview.rsc
    resource\DNCompInfo.dll
    NOTE: If LabVIEW 7.1 installation is repaired after applying the patch, then the
    patch needs to be reapplied.
             Summary of Updates
    1. LabVIEW crashes when browsing for a .NET Assembly if .NET 2.0 is installed
    If .NET 2.0 is installed, then LabVIEW may crash when the Select .NET Constructor
    dialog is displayed, for example after dropping a new constructor node.  In some cases
    the dialog appears, but the Assembly list is empty.
    2. .NET Primary Interop Assembly name shown instead of ActiveX servername
    If an ActiveX server has a .NET Primary Interop Assembly to allow it be used in .NET,
    then when browsing for an ActiveX server, the information about the Primary Interop
    Assembly is shown instead of the ActiveX server information.
    GMT+8, 2025-8-20 23:38
