查看: 3004|回复: 0
[NI驱动程序] NI-VISA16.0 Windows Driver美国国家仪器虚拟仪器软件架构VISA16.0 Windows版驱动下载
    8 小时前
  • 签到天数: 3547 天
    连续签到: 17 天
    发表于 2020-3-3 21:20:27 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    注意,NI-VISA从VISA14.0版开始,使用年代名称来命名,即14代表的是2014年,不再延续之前的5.X之类的名称。而在VISA5.4.1及之前的版本,则是使用数字版本来命名的,5并不是代表着2005年之类的。
    NI-VISA16.0完整版和运行时:
    链接:请注册视觉论坛会员登录后购买附件下载查看
    提取码:请购买附件下载查看
    NI-VISA16.0完整版和运行时:
    请购买附件下载查看
    VISA16.0W.txt (961 Bytes, 下载次数: 2, 售价: 10 元)
    NI-VISA 16.0 for Windows Readme
    May 2016
    This file contains important information about NI-VISA, including supported platforms, new features, and information about bugs fixes and known issues for NI-VISA 16.0.
    Note: The Measurement Studio VisaNS .NET class library is being deprecated and superseded by an IVI-compliant NI-VISA .NET API. Refer to the New Features and Improvements section for more information.
    Installing and Uninstalling NI-VISA
    NI-VISA is the NI implementation of the Virtual Instrument Software Architecture (VISA), a standard for configuring, programming, and troubleshooting instrumentation systems comprising GPIB, VXI, PXI, Serial, Ethernet, and/or USB interfaces.
    NI-VISA for Windows supports the following platforms:
    • Windows Server 2008 R2 (64-bit version only)1
    • Windows Server 2012 R2 (64-bit)1
    • Windows 10 x86, x64
    • Windows 8.1 x86, x64
    • Windows 7 SP1 x86, x64
    • NI Real-Time VxWorks
    • NI Real-Time Phar Lap ETS
    • NI Linux® Real-Time
    • LabVIEW Touch Panel Module 2013/2012
    While this distribution targets all of these platforms, you can run setup.exe only on the Windows variants.
    1 NI-VISA does not support the Windows Server non-R2 editions.
    The following table lists the application software versions, including service packs, supported by NI-VISA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    NI Application SoftwareVersions Supported by NI-VISA
    LabVIEW2016, 2015, 2014, 2013
    LabWindows/CVI2015, 2013, 2012
    Measurement Studio2013
    Microsoft Visual Studio Support for the IVI-Compliant NI-VISA .NET Class Library
    If you are using the IVI-compliant NI-VISA .NET API, the .NET 4.0 Framework (minimum) is required. You can use the NI-VISA .NET Class Library with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET 4.0 Framework or later. You can use the NI-VISA .NET Class Library in 32-bit or 64-bit applications.
    NI-VISA example projects are available in your Users/Public/Documents/National Instruments/NI-VISA/Examples directory.
    Microsoft Visual Studio Support for the VisaNS .NET Class Library
    The following table lists the programming languages and Microsoft Visual Studio versions supported by this version of the VisaNS .NET Class Library. Earlier versions of NI-VISA support other application software and language versions. For more information on Visual Studio compatibility with earlier versions of VISA, refer to ni.com/info and enter the info code NETlegacydrivers. To find and download an earlier version of a driver, refer to ni.com/downloads.
    Programming LanguageVisual Studio Versions Supported by VisaNS
    .NET Framework 4.0 Languages
    (Visual C# and Visual Basic .NET)
    2010
    .NET Framework 4.5 Languages
    2012
    .NET Framework 4.5.1 Languages
    2013
    Before you install NI-VISA 16.0, NI recommends that you uninstall any versions of VISA prior to NI-VISA 2.0.1.
    After uninstalling NI-VISA, some DLLs and executables may remain in the NI-VISA directories. To complete the uninstall process, you must restart your machine.
    Note: The uninstaller application does not notify you when rebooting is necessary. If you plan to reinstall NI-VISA, you always should reboot the machine after running the uninstaller.
    Agilent/HP Controller Support
    NI-VISA now works with Agilent/HP GPIB and VXI controller cards. To use this feature, go into MAX, select Tools»NI-VISA»VISA Options, choose the Passports tab, and enable the NiVisaTulip.dll Passport. NI-VISA automatically finds and accesses any GPIB or VXI devices. However, NI-VISA does not configure the Agilent/HP hardware; you still must do that with the Agilent/HP I/O Config utility.
    If you have both NI and Agilent/HP controllers in the same system, you must configure the cards at different system addresses, such as GPIB0 and GPIB1. If both vendors try to use the same interface address, NI-VISA reports an error from viFindRsrc or VISA Find Resources.
    WHQL Signing USB Hardware
    To WHQL (Windows Hardware Quality Labs) sign your USB hardware using the NI-VISA driver for Windows XP/2000, as part of this process you need a PDB (Program Database) file for the underlying driver (NiViUsbK.sys).
    NiViUsbK.pdb is provided for this purpose. It is in \WinNT\NIvisa\USB.
    Creating and Digitally Signing Catalog Files
    (Windows 8.1) If you generate an INF file using the NI-VISA Driver Wizard, you must create and digitally sign a Windows Catalog (.cat) file before you can install the INF file on a Windows 8.1 machine. For more information about digitally signing a .cat file for Windows 8.1, visit ni.com/info and enter the Info Code INFWin8.
    For more information about creating and signing catalog files, Microsoft has a Kernel-Mode Code Signing Walkthrough whitepaper that describes the details of this process. The generated catalog file should reference only the INF file.
    You can access the software and documentation known issues list online. For a list of known issues with NI-VISA 16.0, visit ni.com/info and enter the Info Code NIVISA160KnownIssues.
    For a list of bug fixes for NI-VISA, visit ni.com/info and enter the Info Code NIVISAFixList.
    New Features and ImprovementsNI-VISA 15.5
    Updated documentation for NI-VISA .NET API, available in your Users/Public/Documents/National Instruments/NI-VISA/Documentation directory.
    Improved performance of viInXX and viOutXX functions.
    NI-VISA 15.0
    Added support for the industry standard API for VISA .NET as specified by the IVI Foundation in VPP 4.3.6. NI recommends this API for developing new .NET applications using NI-VISA. Support for the legacy VisaNS API will be removed in a future release. For more information about upgrading from VisaNS to the new VISA .NET API, visit ni.com/info and enter the Info Code VISANETUpgrade.
    NI-VISA 14.0
    Added support for NI Linux Real-Time x64.
    Added support for viMapTrigger and viAssertTrigger on PXI resources to use PXI-9 compliant trigger managers if available.
    Added support for viGpibControlREN on TCPIP resources that use the VXI-11 protocol.
    NI-VISA 5.4
    Added support for NI Linux Real-Time.
    NI-VISA 5.3
    Improved performance of viRead for a HiSLIP resource.
    NI-VISA 5.2
    Added support for IVI VISA Plug-in specification. NI-VISA 5.2 can enumerate and communicate with third-party PCI/PXI devices with specification-compliant plug-ins that are installed on the system.
    Improved performance of viWrite for a HiSLIP resource.
    NI-VISA 5.1
    Added support for HiSLIP.
    Added support for USB resources on PharLap-based LabVIEW RT targets.
    Updated the VISA Interactive Control stand-alone application. Refer to the NI-VISA Help for more information on the updates to VISAIC.
    NI-VISA 5.0.3
    Added support for .NET Framework 4.0
    NI-VISA 5.0.1
    Added support for IPxi interface in VISA-COM layer.
    NI-VISA 5.0
    Added the ability to launch Instrument Driver Finder from MAX.
    Added a page in the Driver Development Wizard to auto-detect USB devices and auto-populate device info.
    Added the ability to custom install VISA passports on Real-Time targets.
    Added support for 64-bit formatted I/O.
    Added the ability to configure IEEE 1588-2008 clocks on networks.
    NI-VISA 4.6.2
    Added support for Windows 7 (32-bit version), Windows 7 x64 Edition (64-bit version), Windows Server 2003 R2 (32-bit version only), and Windows Server 2008 R2 (64-bit version only).
    NI-VISA 4.5.1
    Added support for 64-bit user mode in .NET 3.5 Framework. You can now create 64-bit applications with .NET Framework 3.5. For additional information, refer to Working with 64-bit .NET Support for NI-VISA in the NI-VISA .NET Framework 3.5 Help. This help file is installed by default at Start»All Programs»National Instruments»VISA»Documentation»NI-VISA .NET Framework 3.5 Help.
    NI-VISA 4.5
    Added a page in MAX to allow viewing and changing the Conflict Resolution Manager settings.
    NI-VISA 4.4
    Added support for using NI-VISA with 64-bit applications on Windows Vista x64 Edition. VXI, GPIB-VXI, and FireWire resources are not currently supported for 64-bit applications.
    Added automatic detection of LXI (TCP/IP) devices that support the mDNS and DNS-SD technologies.
    Added support for USB and TCP/IP resources on VxWorks-based LabVIEW RT targets.
    NI-VISA 4.3
    When using the MAX Copy Configuration API, you can now specify "ni-visa" as the product. All documented modes are supported.
    NI-VISA 4.2
    The default installation directory has changed from "C:\VXIPNP" to "C:\Program Files\IVI Foundation\VISA". Upgrades over previous versions of NI-VISA use the previous installation directory.
    The default path to the configuration file visaconf.ini has changed to "C:\Documents and Settings\All Users\Application Data\National Instruments\NIvisa" on Windows XP/2000 and to "C:\ProgramData\National Instruments\NIvisa" on Windows Vista.
    Added support for Windows Mobile 5.0 on x86 processors.
    NI-VISA 4.1
    The NI-VISA Driver Wizard generates new INF files that work on Vista. If you want to run your VISA based drivers on Vista that previously required an INF file, you will need to regenerate a new INF file using the new Driver Wizard.
    On Pocket PC 2003/Windows Mobile 5.0 devices, the NI-VISA configuration file visaconf.ini was installed as read-only. This caused problems with serial port detection. Now it is writable.
    In MAX, the IP address of TCPIP INSTR and SOCKET resources was not shown when the resource was configuring using a hostname. This IP address is now shown.
    NI-VISA Server now warns if it is launched and there are no permissions set to allow clients to connect.
    The NI-VISA Driver Wizard now has an option for PXI Express devices that provide a way to read the slot number using a sequence of register-level accesses.
    The enabled/disabled state of Passports is preserved across upgrades of NI-VISA.
    NI-VISA 4.0
    Added support for 64-bit data transfers in register-based operations, to support the VISA 4.0 specification.
    NI-VISA Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI-VISA drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-VISA that ship after July 1, 2016 will not install or run on Windows 7 RTM (with no service pack), Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    LabWindows™/CVI™cvi_lifecycle
    © 1995–2016 National Instruments. All rights reserved.
    374899E-01
    GMT+8, 2025-5-22 16:31
