查看: 2771|回复: 0
[NI驱动程序] NI-VISA15.5 MacOS X Driver美国国家仪器虚拟仪器软件架构VISA15.5 苹果版驱动下载
    3 天前
  • 签到天数: 3529 天
    连续签到: 17 天
    发表于 2020-3-3 21:16:05 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    注意,NI-VISA从VISA14.0版开始,使用年代名称来命名,即14代表的是2014年,不再延续之前的5.X之类的名称。而在VISA5.4.1及之前的版本,则是使用数字版本来命名的,5并不是代表着2005年之类的。
    NI-VISA15.5完整版和运行时:
    链接:请注册视觉论坛会员登录后购买附件下载查看
    提取码:请购买附件下载查看
    NI-VISA15.5完整版和运行时:
    请购买附件下载查看
    VISA15.5M.txt (957 Bytes, 下载次数: 0, 售价: 10 元)
    NI-VISA 15.5 for Mac OS X Readme
    February 2016
    Contents
    Using NI-VISA 15.5
    Supported Platforms
    Installed Files and Paths
    Known Issues and Bug Fixes
    New Features and Improvements
    Using NI-VISA 15.5Supported Platforms
    NI-VISA 15.5 for Macintosh supports the following platforms:
    • Mac OS X 10.10.x
    • Mac OS X 10.11.x
    NI-VISA for Macintosh supports LabVIEW 2015/2014/2013/2012
    There are three main locations where NI-VISA installs files.
    • The local /Library/Frameworks folder contains the VISA.framework folder. This folder contains all needed headers and supporting Passport libraries that NI-VISA uses.
    • In the local /Applications/National Instruments folder, there is an NI-VISA folder. This folder includes the NI-VISA Help, as well as several groups of C examples using NI-VISA. This NI-VISA folder also includes a graphical utility called NI-VISA Configuration to configure VISA options and the VISA Interactive Control (VISAIC).
    • Finally, the /Library/Preferences folder contains an NIvisa folder with .ini files. These files are used for NI-VISA settings and status codes.
    For a list of Known Issues of NI-VISA 15.5, visit ni.com/info and enter the Info Code NIVISA155KnownIssues.
    For a list of Bug Fixes for NI-VISA, visit ni.com/info and enter the Info Code NIVISAFixList.
    New Features and ImprovementsNI-VISA 15.0
    Added support for NI MAX.
    NI-VISA 14.0
    Added support for 64-bit versions of LabVIEW.
    Added support for the System Configuration API.
    Added support for viGpibControlREN on TCPIP resources that use the VXI-11 protocol.
    NI-VISA 5.3
    Improved performance of viRead for a HiSLIP resource.
    NI-VISA 5.2
    Improved performance of viWrite for a HiSLIP resource.
    NI-VISA 5.1.2
    Added support for 64-bit kernel for Mac OS X.
    Added Mac OS X 10.7 support.
    NI-VISA 5.1
    Added support for HiSLIP.
    Added the VISA Interactive Control (VISAIC) stand-alone application. Refer to the NI-VISA Help for more information on the updates to VISAIC.
    NI-VISA 5.0
    Added Mac OS X 10.6 support.
    Added support for 64-bit formatted I/O.
    Dropped GPIB-VXI support.
    NI-VISA 4.5
    Added automatic detection of LXI (TCP/IP) devices that support the mDNS and DNS-SD technologies.
    NI-VISA 4.0.1
    Added support for the PXI/PCI Passport on the x86 architecture.
    Added native support for the NI-VISA Configuration Utility on the x86 architecture.
    NI-VISA 4.0
    Added support for Mac OS X on the x86 architecture, aka Mactel.
    Added support for 64-bit data transfers in register-based operations, to support the VISA 4.0 specification.
    Added support for DTR/DSR flow control. The Agilent 34401A requires DTR/DSR flow control when used via Serial. Note that not all Serial port drivers on the Mac support DTR/DSR. We have tested the Agilent 34401A with NI-VISA 4.0 using the Keyspan USA-19HS and verified that it works properly.
    © 1995–2016 National Instruments. All rights reserved.
    Third-Party Legal Notices
    You can find third-party legal notices in the /Library/Application Support/National Instruments/Legal Information directory.
    375354B-01
    GMT+8, 2025-5-3 09:52
