查看: 2617|回复: 0
[NI驱动程序] NI-VISA5.4.1MAC OS X Driver美国国家仪器虚拟仪器软件架构VISA5.4.1苹果版驱动下载
    3 天前
  • 签到天数: 3529 天
    连续签到: 17 天
    发表于 2020-3-3 17:31:09 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-VISA5.4.1完整版和运行时:
    链接:请注册视觉论坛会员登录后购买附件下载查看
    提取码:请购买附件下载查看
    请购买附件下载查看
    VISA5.4.1M.txt (791 Bytes, 下载次数: 0, 售价: 10 元)
    NI-VISA 5.4.1 for Mac OS X Readme
    February 2014
    Contents
    Using NI-VISA 5.4.1
    Supported Platforms
    Installed Files and Paths
    Known Issues and Bug Fixes
    New Features and Improvements
    Important Information
    Using NI-VISA 5.4.1Supported Platforms
    NI-VISA 5.4.1 for Macintosh supports the following platforms:
    • Mac OS X 10.7.x x86 and x86-641
    • Mac OS X 10.8.x 1
    1 64-bit VISA applications are supported for a limited set of instrumentation buses. The supported buses are ENET-Serial, USB, and TCPIP. Logging VISA operations in NI I/O Trace from 64-bit VISA applications is not supported.
    NI-VISA for Macintosh supports LabVIEW 2009 or later.
    There are three main locations where NI-VISA installs files.
    • The local /Library/Frameworks folder contains the VISA.framework folder. This folder contains all needed headers and supporting Passport libraries that NI-VISA uses.
    • In the local /Applications/National Instruments folder, there is an NI-VISA folder. This folder includes the NI-VISA Help, as well as several groups of C examples using NI-VISA. This NI-VISA folder also includes a graphical utility called NI-VISA Configuration to configure VISA options and the VISA Interactive Control (VISAIC).
    • Finally, the /Library/Preferences folder contains an NIvisa folder with .ini files. These files are used for NI-VISA settings and status codes.
    For a list of Known Issues of NI-VISA 5.4.1, visit ni.com/info and enter the Info Code NIVISA54KnownIssues.
    For a list of Bug Fixes for NI-VISA, visit ni.com/info and enter the Info Code NIVISAFixList.
    New Features and ImprovementsNI-VISA 5.3
    Improved performance of viRead for a HiSLIP resource.
    NI-VISA 5.2
    Improved performance of viWrite for a HiSLIP resource.
    NI-VISA 5.1.2
    Added support for 64-bit kernel for Mac OS X.
    Added Mac OS X 10.7 support.
    NI-VISA 5.1
    Added support for HiSLIP.
    Added the VISA Interactive Control (VISAIC) stand-alone application. Refer to the NI-VISA Help for more information on the updates to VISAIC.
    NI-VISA 5.0
    Added Mac OS X 10.6 support.
    Added support for 64-bit formatted I/O.
    Dropped GPIB-VXI support.
    NI-VISA 4.5
    Added automatic detection of LXI (TCP/IP) devices that support the mDNS and DNS-SD technologies.
    NI-VISA 4.0.1
    Added support for the PXI/PCI Passport on the x86 architecture.
    Added native support for the NI-VISA Configuration Utility on the x86 architecture.
    NI-VISA 4.0
    Added support for Mac OS X on the x86 architecture, aka Mactel.
    Added support for 64-bit data transfers in register-based operations, to support the VISA 4.0 specification.
    Added support for DTR/DSR flow control. The Agilent 34401A requires DTR/DSR flow control when used via Serial. Note that not all Serial port drivers on the Mac support DTR/DSR. We have tested the Agilent 34401A with NI-VISA 4.0 using the Keyspan USA-19HS and verified that it works properly.
    © 2014 National Instruments. All rights reserved.
    Credits
    A. This product includes components that use the socket++ library. In regards to the socket++ library, the following notice applies:
    Copyright © 1992, 1993, 1994 Gnanasekaran Swaminathan (University of Virginia). Certain modifications have been made by Gregory Lavender (University of Texas) and National Instruments Corporation to the version of the socket++ library used in this product.
    B. This product includes components that use Xerces. In regards to the Xerces library, the following notice applies:
    This product includes software developed by the Apache Software Foundation (http://www.apache.org/) that is subject to the Apache License, Version 2.0 (the "Xerces License"), a copy of which may be found at: http://www.apache.org/licenses/LICENSE-2.0. Copyright © 1999–2005 The Apache Software Foundation. All rights reserved. Certain modifications have been made by National Instruments Corporation to the version of the Xerces library used in this product; such modifications are Copyright © 2008 National Instruments Corporation. The content of this notice is for informational purposes only and does not modify the Xerces License. See the Xerces License for the specific language governing permissions and limitations relating to the Xerces library.
    GMT+8, 2025-5-3 08:18
