查看: 2615|回复: 0
[NI驱动程序] NI-VISA5.4MAC OS X Driver美国国家仪器虚拟仪器软件架构VISA5.4苹果版驱动下载
    3 天前
  • 签到天数: 3529 天
    连续签到: 17 天
    发表于 2020-3-3 16:51:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-VISA5.4完整版和运行时:
    链接:请注册视觉论坛会员登录后购买附件下载查看
    提取码:请购买附件下载查看
    NI-VISA5.4完整版和运行时:
    请购买附件下载查看
    VISA5.4M.txt (762 Bytes, 下载次数: 0, 售价: 10 元)
    NI-VISA 5.4 for Mac OS X Readme
    June 2013
    Contents
    Using NI-VISA 5.4
    Supported Platforms
    Installed Files and Paths
    Known Issues and Bug Fixes
    New Features and Improvements
    Important Information
    Using NI-VISA 5.4Supported Platforms
    NI-VISA 5.4 for Macintosh supports the following platforms:
    • Mac OS X 10.7.x x86 and x86-641
    • Mac OS X 10.8.x 1
    1 64-bit VISA applications are supported for a limited set of instrumentation buses. The supported buses are ENET-Serial, USB, and TCPIP. Logging VISA operations in NI I/O Trace from 64-bit VISA applications is not supported.
    NI-VISA for Macintosh supports LabVIEW 2009 or later.
    There are three main locations where NI-VISA installs files.
    • The local VISA.framework folder. This folder contains all needed headers and supporting Passport libraries that NI-VISA uses.
    • In the local NI-VISA folder. This folder includes the NI-VISA Help, as well as several groups of C examples using NI-VISA. This NI-VISA folder also includes a graphical utility called NI-VISA Configuration to configure VISA options and the VISA Interactive Control (VISAIC).
    • Finally, the NIvisa folder with .ini files. These files are used for NI-VISA settings and status codes.
    For a list of Known Issues of NI-VISA 5.4, visit ni.com/info and enter the Info Code NIVISA54KnownIssues.
    For a list of Bug Fixes for NI-VISA, visit ni.com/info and enter the Info Code NIVISAFixList.
    New Features and ImprovementsNI-VISA 5.3
    Improved performance of viRead for a HiSLIP resource.
    NI-VISA 5.2
    Improved performance of viWrite for a HiSLIP resource.
    NI-VISA 5.1.2
    Added support for 64-bit kernel for Mac OS X.
    Added Mac OS X 10.7 support.
    NI-VISA 5.1
    Added support for HiSLIP.
    Added the VISA Interactive Control (VISAIC) stand-alone application. Refer to the NI-VISA Help for more information on the updates to VISAIC.
    NI-VISA 5.0
    Added Mac OS X 10.6 support.
    Added support for 64-bit formatted I/O.
    Dropped GPIB-VXI support.
    NI-VISA 4.5
    Added automatic detection of LXI (TCP/IP) devices that support the mDNS and DNS-SD technologies.
    NI-VISA 4.0.1
    Added support for the PXI/PCI Passport on the x86 architecture.
    Added native support for the NI-VISA Configuration Utility on the x86 architecture.
    NI-VISA 4.0
    Added support for Mac OS X on the x86 architecture, aka Mactel.
    Added support for 64-bit data transfers in register-based operations, to support the VISA 4.0 specification.
    Added support for DTR/DSR flow control. The Agilent 34401A requires DTR/DSR flow control when used via Serial. Note that not all Serial port drivers on the Mac support DTR/DSR. We have tested the Agilent 34401A with NI-VISA 4.0 using the Keyspan USA-19HS and verified that it works properly.
    © 2013 National Instruments. All rights reserved.
    GMT+8, 2025-5-3 09:54
