查看: 3411|回复: 0
[NI驱动程序] NI-VISA5.4Windows 美国国家仪器虚拟仪器软件架构VISA5.4Windows版下载
  • 签到天数: 3584 天
    连续签到: 4 天
    发表于 2020-3-3 16:40:17 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-VISA5.4Windows Driver 美国国家仪器虚拟仪器软件架构VISA5.4Windows版驱动下载
    NI-VISA5.4完整版和运行时:
    链接:请注册视觉论坛会员登录后购买附件下载查看
    提取码:请购买附件下载查看
    NI-VISA5.4完整版和运行时:
    请购买附件下载查看
    VISA5.4W.txt (767 Bytes, 下载次数: 3, 售价: 10 元)
    NI-VISA 5.4 for Windows Readme
    June 2013
    Using NI-VISA 5.4
    Supported Platforms
    Installing and Uninstalling NI-VISA 5.4
    Agilent/HP Controller Support
    WHQL Signing USB Hardware
    Creating and Digitally Signing Catalog Files
    Known Issues and Bug Fixes
    New Features and Improvements
    Important Information
    Using NI-VISA 5.4Supported Platforms
    NI-VISA for Windows supports the following platforms:
    • Windows Server 2003 R2 (32-bit version only)1,2
    • Windows Server 2008 R2 (64-bit version only)1
    • Windows 8 x64 Edition (64-bit version)
    • Windows 8 (32-bit version)
    • Windows 7 x64 Edition (64-bit version)
    • Windows 7 (32-bit version)
    • Windows Vista x64 Edition (64-bit version)
    • Windows Vista (32-bit version)
    • Windows XP Service Pack 3
    • LabVIEW Real-Time (Phar Lap ETS and VxWorks) 2013/2012/2011/2010
    • NI Linux® Real-Time
    • LabWindows/CVI Real-Time (Phar Lap ETS) 2013/2012/2010/9.0
    • LabVIEW Mobile Module 2013/2012/2011/2010
    • LabVIEW Touch Panel Module 2013/2012/2011/2010
    While this distribution targets all these platforms, you can run setup.exe only on the Windows variants.
    1 NI-VISA does not support the Windows Server non-R2 editions.
    2 Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might need to take, visit ni.com/info and enter the info code PAESupport.
    NI-VISA for Windows supports the following development environments. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    NI Application SoftwareVersions Supported by NI-VISA
    LabVIEW2013/2012/2011/2010
    LabWindows/CVI2013/2012/2010/9.0
    Measurement Studio2013/2012/2010/2009
    Measurement Studio Examples
    The directories that the Measurement Studio examples install to depends on which component is installed, the version of Visual Studio or the .NET Framework the example supports, the version of Measurement Studio installed, and the operating system. For detailed information on examples for Measurement Studio, refer to Where to Find Examples in the NI Measurement Studio Help.
    The following table lists the programming languages and Microsoft Visual Studio versions supported by this version of NI-VISA. Earlier versions of NI-VISA support other application software and language versions. For more information on Visual Studio compatibility with earlier versions of VISA, refer to ni.com/info and enter the info code NETlegacydrivers. To find and download an earlier version of a driver, refer to ni.com/downloads.
    Programming LanguageVisual Studio Versions Support by NI-VISA
    Visual C++ MFC120082
    .NET Framework 3.5 Languages
    (Visual C# and Visual Basic .NET)
    2008
    .NET Framework 4.0 Languages
    20103
    .NET Framework 4.5 Languages
    20124
    1 NI-VISA includes limited support for Visual Studio C++ MFC. For more information, visit ni.com/info and enter the info code visamvs03.
    2 Requires Measurement Studio 8.6 — Measurement Studio 2009.
    3 With Windows XP, Service Pack 3 or later is required.
    4 Windows 8, Windows 7, Windows Vista SP2, or Windows Server 2008 R2 is required.
    If you are using the NI-VISA .NET Library, the .NET 3.5 Framework, .NET 4.0 Framework, or .NET 4.5 Framework is required.
    Support for 64-bit applications is available in NI-VISA 4.5.1 and later for Visual Studio 2008 support, NI-VISA 5.0.3 and later for Visual Studio 2010 support, and NI-VISA 5.4 and later for Visual Studio 2012 support.
    NI-VISA 5.4 does not support Windows 9x/NT/2000. To run your VISA application on Windows 95, you must install NI-VISA 2.6.1 or lower. To run your VISA application on Windows 98/Me, you must install NI-VISA 3.0.1 or lower. To run your VISA application on Windows NT, you must install NI-VISA 3.3.1 or lower. To run your VISA application on Windows 2000, you must install NI-VISA 4.6.2 or lower.
    Before you install NI-VISA 5.4, National Instruments recommends that you uninstall any versions of VISA prior to NI-VISA 2.0.1.
    After uninstalling NI-VISA, some DLLs and executables may remain in the NI-VISA directories. To complete the uninstall process, you must restart your machine.
    Note: The uninstaller application does not notify you when rebooting is necessary. If you plan to reinstall NI-VISA, you always should reboot the machine after running the uninstaller.
    You can programmatically install NI-VISA. You also can programmatically control which features of NI-VISA are enabled for installation, allowing you to install a subset of the NI-VISA feature list. Refer to the spec.ini file in the same directory as this readme for more information about installing NI-VISA programmatically and selecting which features to install.
    NI-VISA now works with Agilent/HP GPIB and VXI controller cards. To use this feature, go into MAX, select Tools»NI-VISA»VISA Options, choose the Passports tab, and enable the NiVisaTulip.dll Passport. NI-VISA automatically finds and accesses any GPIB or VXI devices. However, NI-VISA does not configure the Agilent/HP hardware; you still must do that with the Agilent/HP I/O Config utility.
    If you have both National Instruments and Agilent/HP controllers in the same system, you must configure the cards at different system addresses, such as GPIB0 and GPIB1. If both vendors try to use the same interface address, NI-VISA reports an error from viFindRsrc or VISA Find Resources.
    To WHQL (Windows Hardware Quality Labs) sign your USB hardware using the NI-VISA driver for Windows XP/2000, as part of this process you need a PDB (Program DataBase) file for the underlying driver (NiViUsbK.sys).
    NiViUsbK.pdb is provided for this purpose. It is in \WinNT\NIvisa\USB.
    On Windows Vista and Windows 7, if you generate an INF file using the NI-VISA Driver Wizard, the INF file installs correctly by itself. However, a warning dialog notifies you that Windows cannot verify the publisher of this driver software. To avoid this dialog, you must create and digitally sign a Windows Catalog (.cat) file.
    For more information about creating and signing catalog files, Microsoft has a Kernel-Mode Code Signing Walkthrough whitepaper that describes the details of this process. The generated catalog file should reference only the INF file.
    For a list of Known Issues of NI-VISA 5.4, visit ni.com/info and enter the Info Code NIVISA54KnownIssues.
    For a list of Bug Fixes for NI-VISA, visit ni.com/info and enter the Info Code NIVISAFixList.
    New Features and ImprovementsNI-VISA 5.4
    Added support for NI Linux® Real-Time
    NI-VISA 5.3
    Improved performance of viRead for a HiSLIP resource.
    NI-VISA 5.2
    Added support for IVI VISA Plug-in specification. NI-VISA 5.2 can enumerate and communicate with third-party PCI/PXI devices with specification-compliant plugins that are installed on the system.
    Improved performance of viWrite for a HiSLIP resource.
    NI-VISA 5.1
    Added support for HiSLIP.
    Added support for USB resources on PharLap-based LabVIEW RT targets.
    Updated the VISA Interactive Control stand-alone application. Refer to the NI-VISA Help for more information on the updates to VISAIC.
    NI-VISA 5.0.3
    Added support for .NET Framework 4.0
    NI-VISA 5.0.1
    Added support for IPxi interface in VISA-COM layer.
    NI-VISA 5.0
    Added the ability to launch Instrument Driver Finder from MAX.
    Added a page in the Driver Development Wizard to auto-detect USB devices and auto-populate device info.
    Added the ability to custom install VISA passports on Real-Time targets.
    Added support for 64-bit formatted I/O.
    Added the ability to configure IEEE 1588-2008 clocks on networks.
    NI-VISA 4.6.2
    Added support for Windows 7 (32-bit version), Windows 7 x64 Edition (64-bit version), Windows Server 2003 R2 (32-bit version only), and Windows Server 2008 R2 (64-bit version only).
    NI-VISA 4.5.1
    Added support for 64-bit user mode in .NET 3.5 Framework. You can now create 64-bit applications with .NET Framework 3.5. For additional information, refer to Working with 64-bit .NET Support for NI-VISA in the NI-VISA .NET Framework 3.5 Help. This help file is installed by default at Start»All Programs»National Instruments»VISA»Documentation»NI-VISA .NET Framework 3.5 Help.
    NI-VISA 4.5
    Added a page in MAX to allow viewing and changing the Conflict Resolution Manager settings.
    NI-VISA 4.4
    Added support for using NI-VISA with 64-bit applications on Windows Vista x64 Edition. VXI, GPIB-VXI, and FireWire resources are not currently supported for 64-bit applications.
    Added automatic detection of LXI (TCP/IP) devices that support the mDNS and DNS-SD technologies.
    Added support for USB and TCP/IP resources on VxWorks-based LabVIEW RT targets.
    NI-VISA 4.3
    When using the MAX Copy Configuration API, you can now specify "ni-visa" as the product. All documented modes are supported.
    NI-VISA 4.2
    The default installation directory has changed from "C:\VXIPNP" to "C:\Program Files\IVI Foundation\VISA". Upgrades over previous versions of NI-VISA use the previous installation directory.
    The default path to the configuration file visaconf.ini has changed to "C:\Documents and Settings\All Users\Application Data\National Instruments\NIvisa" on Windows XP/2000 and to "C:\ProgramData\National Instruments\NIvisa" on Windows Vista.
    Added support for Windows Mobile 5.0 on x86 processors.
    NI-VISA 4.1
    The NI-VISA Driver Wizard generates new INF files that work on Vista. If you want to run your VISA based drivers on Vista that previously required an INF file, you will need to regenerate a new INF file using the new Driver Wizard.
    On Pocket PC 2003/Windows Mobile 5.0 devices, the NI-VISA configuration file visaconf.ini was installed as read-only. This caused problems with serial port detection. Now it is writeable.
    In MAX, the IP address of TCPIP INSTR and SOCKET resources was not shown when the resource was configuring using a hostname. This IP address is now shown.
    NI-VISA Server now warns if it is launched and there are no permissions set to allow clients to connect.
    The NI-VISA Driver Wizard now has an option for PXI Express devices that provide a way to read the slot number using a sequence of register-level accesses.
    The enabled/disabled state of Passports is preserved across upgrades of NI-VISA.
    NI-VISA 4.0
    Added support for 64-bit data transfers in register-based operations, to support the VISA 4.0 specification.
    NI-VISA Updates and Notifications
    Using NI Launcher
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    NI-VISA Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI-VISA will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-VISA that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2013 National Instruments. All rights reserved.
    GMT+8, 2025-7-4 15:29
