查看: 2933|回复: 0
[NI驱动程序] NI-VISA3.2Linux 美国国家仪器虚拟仪器软件架构VISA3.2 Linux版下载
    8 小时前
  • 签到天数: 3599 天
    连续签到: 7 天
    发表于 2020-3-3 11:39:32 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-VISA3.2:
    链接:请注册视觉论坛会员登录后购买附件下载查看
    提取码:请购买附件下载查看
    NI-VISA3.2:
    请购买附件下载查看
    VISA3.2L.txt (613 Bytes, 下载次数: 0, 售价: 10 元)
    National Instruments NI-VISA(TM) Software for Linux x86. Version 3.2.
    Copyright(c) 1995, 2004 National Instruments Corporation. All rights reserved.
    NATIONAL INSTRUMENTS HOLDS MULTIPLE COPYRIGHTS, TRADEMARKS, AND PATENTS
    FOR THIS PRODUCT.  BY DOWNLOADING AND/OR INSTALLING THIS PRODUCT, YOU AGREE
    TO THE TERMS OF THE license.txt FILE THAT RESIDES IN THE SAME DIRECTORY AS
    THIS readme.txt FILE ON THE CD AND/OR WEB SITE.  FOR PATENTS COVERING
    NATIONAL INSTRUMENTS PRODUCTS, REFER TO THE patents.txt FILE ON THE ROOT
    DIRECTORY OF YOUR CD (IF APPLICABLE) AND/OR www.ni.com/patents.
    CONTENTS OF THIS FILE
    Installation From the Internet
    LabWindows(TM)/CVI Run-Time Engine
    VISA Support for Multiple GPIB-VXI Controllers
    VISA Probes for LabVIEW 7.x
    USB Issues on Linux
    NI-VISA 2.5 Improvements and Bug Fixes
    NI-VISA 2.6 Improvements and Bug Fixes
    NI-VISA 3.0 Improvements and Bug Fixes
    NI-VISA 3.1 Improvements and Bug Fixes
    NI-VISA 3.2 Improvements and Bug Fixes
    Credits
    INSTALLATION FROM THE INTERNET
    You should be logged in as 'root' to perform this installation.
    1) Download the installation script file "INSTALL" and the compressed tar
       file "NICVISA_.TZ" from the ftp site into a temporary directory.
    2) Type ./INSTALL to execute the install script, and follow the instructions
       as prompted.
    3) Add the following environment variables to your shell setup file as shown
       in the following example for csh. The following commands assume that
       you installed NI-VISA into /usr/local/vxipnp:
       setenv VXIPNPPATH       /usr/local/vxipnp
       setenv LD_LIBRARY_PATH  /usr/local/vxipnp/linux/bin
    Note:  If your setup file already contains the LD_LIBRARY_PATH environment
           variable, you need to append /usr/local/vxipnp/linux/bin to the end of
           the statement. The required commands may vary from those shown in the
           previous section if you are not using csh.
    LABWINDOWS/CVI RUN-TIME ENGINE
    The INSTALL script now automatically installs the LabWindows/CVI Run-Time
    Engine when necessary. The NI-VISA interactive utility, VISAIC, requires the
    LabWindows/CVI Run-Time Engine 5.0.1 or later to be installed. When you
    install this utility, the INSTALL script also installs the LabWindows/CVI
    Run-Time Engine if it is not already present.
    VISA SUPPORT FOR MULTIPLE GPIB-VXI CONTROLLERS
    NI-VISA supports multiple GPIB-VXI controllers in a single system. Because the
    National Instruments GPIB-VXI controller ships with a primary address of 1,
    NI-VISA automatically searches for any GPIB-VXI controllers at that address.
    If you have changed the primary address (for example, if you added a second
    GPIB-VXI controller to your system, and set the address of the second
    controller to 9), or if you have a GPIB-VXI controller from another vendor,
    then you need to use the VISA configuration utility so NI-VISA can find it.
    This app's path is /linux/NIvisa/visaconf.  While in the Resource
    Editor, click the 'Add' button to add a new resource.  Specify a valid
    resource name for the new controller, such as GPIB-VXI2::0::INSTR.  You will
    then be prompted for the GPIB board number and the GPIB-VXI's primary and
    secondary addresses.  For most users, the only number that will change
    (from the default selections) is the primary address (for the above example,
    you would change it to 9).  Click 'OK' to add this new resource, and then
    select the File>>Save menu option to save this to the NI-VISA database.
    If you are using a GPIB-VXI command module from another vendor, you also need
    to obtain and install that vendor's VISA GPIB-VXI component.
    If you have a GPIB device at primary address 1 and that device does not
    recognize "*IDN?", you should disable the GPIB-VXI auto-detect feature in
    visaconf on the Settings tab.
    VISA PROBES FOR LABVIEW 7.x
    The VISA probes for LabVIEW 7.x greatly extend the amount of relevant
    information displayed when using LabVIEW probes on VISA refnums. They are used
    automatically by LabVIEW in place of the generic probe when they are
    installed.
    To install them, download them from "ftp.ni.com/support/visa/labview/probes/"
    and copy them into "/vi.lib/_probes/default/VISA/" where
    is the installation directory of LabVIEW.
    USB ISSUES ON LINUX
    NI-VISA relies on a Linux kernel feature for its USB support. This feature
    is called "usbfs", and on older Linux kernels was referred to as "usbdevfs".
    For NI-VISA to support USB devices, this feature must be present and
    mounted (like a virtual filesystem). This is supported in most major Linux
    distributions such as Red Hat, SuSE, and Mandrake. You may use the "mount"
    command to display what filesystems are currently mounted to see if your
    system currently supports this feature.
    Also, the VISA user must have write accress to the file that represents
    the USB device, which is typically somewhere in a subdirectory within
    "/proc/bus/usb". If this is not the case, the USB device is not
    accessible by VISA (it will not be found using viFindRsrc and viOpen will
    fail). The default configuration on most systems is that the 'root' user
    has write access; however, no other user has this access.
    There are a number of options that you can take to provide a non-root
    user access to a USB device.
    1) Use the hotplug package. This package is installed by default on most
    distributions including Red Hat, SuSE, and Mandrake. The hotplug package
    allows the user to run scripts for a specific USB device based on
    characteristics such as Vendor ID (VID) and Product ID (PID). If the
    hotplug package exists, the NI-VISA Installer by default will install
    scripts to give all users write access to all USB TMC devices and a
    framework for USB RAW devices. To add write permissions for a specific
    USB RAW device, simply run the included script:
    "/linux/NIvisa/USB/AddUsbRawPermissions.sh".
    For more information on the hotplug package, please visit:
    http://linux-hotplug.sourceforge.net
    2) "usbfs" (formerly known as "usbdevfs") may be mounted with the option
    "devmode=0666". This gives all users read and write access to all USB
    devices.
    3) The 'root' user may add write permissions to the file that represents
    the USB device which is typically somehere in a subdirectory within
    "/proc/bus/usb". Unfortunately, these permissions will be lost if the
    device is unplugged and then plugged back in. Because of this, this
    approach is not recommended.
    NI-VISA 2.5 IMPROVEMENTS AND BUG FIXES
    GPIB and Serial performance have been improved over Version 2.01.
    If you are using the GPIB-ENET controller, the previous version of NI-VISA
    would take a minute or more to time out if a GPIB-ENET controller were not
    connected or powered on. The timeout is now much shorter.
    This version of NI-VISA incorporates general bug fixes and improvements for
    GPIB-VXI. The NI-VISA code instrument will now load properly in configurations
    where it previously failed.
    If a GPIB-VXI chassis is reset while an application has VISA loaded, the
    GPIB-VXI would previously become accessible only as GPIB but not GPIB-VXI.
    This release of NI-VISA will now properly re-detect the GPIB-VXI.
    Fixed bug with the GPIB-VXI and hardware triggers.
    formatted I/O, especially with very large buffers and with the following
    modifiers: "%b", ",", "#", "!ob", "!ol", and "%[".
    The documentation for viPrintf and viFlush better describes when formatted
    I/O buffers are sent. The documentation for viScanf better describes the ","
    and "#" modifiers.
    Fixed bug with the Serial End Last Bit mode for reads and writes.
    NI-VISA 2.6 IMPROVEMENTS AND BUG FIXES
    Fixed bug with enabling the exception event on GPIB-VXI.
    viScanf %f modifier will now properly scan numbers bigger than 2^31-1.
    viGpibPassControl now returns an error if the primary and/or secondary address
    is invalid.
    In VXI, mapping a trigger line already mapped produced VI_ERROR_LINE_IN_USE
    (0xBFFF0042), instead of VI_SUCCESS_TRIG_MAPPED (0x3FFF007E).  This now
    returns the expected status code.
    In VXI and GPIB-VXI, using viMoveInXX and viMoveOutXX with a negative
    value for the length parameter would occasionally cause the system to reboot.
    This now returns the error code VI_ERROR_INV_LENGTH (0xBFFF0083) instead.
    viReadToFile now writes the correct data to the file.
    For TCP/IP SOCKET and INSTR resources, the openTimeout specified in viOpen
    is now used as the network timeout during the connection sequence.  The
    default openTimeout, if not specified, is 2 seconds (2000 milliseconds).
    For TCP/IP INSTR resources, trying to do a viRead or viReadAsync on a buffer
    with a size larger than a few kilobytes, would either return an error or
    occasionally crash.  This has been fixed.
    viFindRsrc would previously reject certain valid expressions and accept
    certain invalid expressions, usually involving spaces.  This has been fixed.
    The NI-VISA driver would not initialize properly on libc version 5.4.44.
    If an application called fork, the NI-VISA driver didn't initialize
    properly in the child process.  Exiting either the child or parent process
    caused the other's VISA calls to stop working.
    In Serial, we now support baud rates higher than 38400.  Specifically,
    the values 57600, 115200, 230400, and 460800 are now valid as long as the
    system driver allows them.
    In Serial, if data arrives at the same time as viTerminate is called or a
    timeout occurs, the data now gets read.  If this satisfies the read request,
    then the read operation returns a successful status.
    Enabling VI_EVENT_SERVICE_REQ for VI_HNDLR with a GPIB-ENET controller
    would cause an application to hang if an SRQ event arrived while I/O was
    in progress.  This has been fixed.
    Multiple VISA processes using GPIB could not perform I/O simultaneously
    even if the I/O was to different controller cards.  This has been fixed.
    Multiple I/O requests to the same GPIB controller will still be handled
    sequentially due to the nature of GPIB.
    Calling viOpen with access mode 1 (exclusive lock) did not work as expected
    on GPIB interface sessions.  This has been fixed.
    NI-VISA 3.0 IMPROVEMENTS AND BUG FIXES
    When you open a VISA session to GPIB0::INTFC and immediately query the
    attribute VI_ATTR_GPIB_SRQ_STATE, it previously returned the value
    VI_STATE_UNASSERTED.  It now returns VI_STATE_UNKNOWN because the SRQ line
    cannot be monitored if the interface is not yet CIC.  The correct state is
    returned after calling viGpibSendIFC.
    For a TCPIP INSTR resource, calling viTerminate did not work correctly.
    For a TCPIP INSTR resource, calling viRead or viWrite with a large buffer
    occasionally would return an error without transmitting the entire buffer.
    For a TCPIP INSTR resource, opening and closing sessions to multiple host
    addresses would cause NI-VISA to crash.
    For a TCPIP INSTR resource, calling viLock with a timeout longer than the
    I/O timeout for that session could cause NI-VISA to return VI_ERROR_TMO.
    For a TCPIP SOCKET resource, viReadAsync was not implemented.  Now it is.
    For a Serial INSTR resource, viOpen will now open a port if the process
    that had been using that port exited ungracefully (such as with Ctrl-C).
    The previous behavior had been that viOpen would return VI_ERROR_RSRC_BUSY.
    For a Serial INSTR resource, if you enabled RTS/CTS flow control and then
    manually tried to set the state of the RTS line, some operating systems
    would generate VI_ERROR_NSUP_ATTR while others would return VI_SUCCESS but
    not actually modify the state of the line.  Neither of these behaviours was
    correct.  Now NI-VISA will return VI_ERROR_INV_SETUP in this case on all
    operating systems.
    For a Serial INSTR resource, NI-VISA now supports the baud rates 50, 75,
    134, 200, 1800, and 576000.  This list is now identical to the OS list.
    For a Serial INSTR resource, if a binding existed to a valid file/device
    but that file/device was not really a serial port, then NI-VISA would
    not close the handle.  Repeated calls to viFindRsrc or viOpen would cause
    the process to eventually run out of file handles.  This has been fixed.
    If you had a GPIB device at primary address 1 that generated a response to
    *IDN? that was longer than 100 characters, viFindRsrc would occasionally
    viFindRsrc would crash on a complex expression with multiple "|" symbols.
    viScanf %# modifier will now output the number of characters put into the
    buffer excluding the terminating null character.  This applies to the %#s,
    %#t, %#T, and %#[] modifiers. NI-VISA treats the maximum array size
    (specified on input) as the total buffer size including the terminating null
    character.
    Once viScanf returned VI_ERROR_TMO, it would no longer work properly on
    that session.
    Calling viFindRsrc repeatedly when logged in as root would eventually run
    out of file descriptors.  This has been fixed.
    The attributes VI_ATTR_MANF_NAME and VI_ATTR_MODEL_NAME are now correctly
    implemented for GPIB-VXI regardless of whether NI-VXI is installed.
    The maximum simultaneous number of GPIB-VXI controllers supported by
    NI-VISA has changed from 10 to 32.
    When calling viWaitOnEvent repeatedly with a timeout of 0 (immediate), some
    interfaces and event types would still consume excessive CPU time.  Now doing
    this will yield the CPU regardless of the interface or event type.
    viFindRsrc would return VI_ERROR_INV_EXPR if the expression exceeded 255
    characters.  Now it will accept resource expressions of any length.
    Calling viFindRsrc would always assert REN on each GPIB board after finding
    devices.  Now viFindRsrc will re-assert REN on each board only if there is
    at least 1 open VISA INSTR session on that board.
    For a TCPIP SOCKET resource, using viRead with termchar enabled was much
    slower than reading the exact number of bytes.  The performance of using
    termchar with viRead is now much better than it was.
    NI-VISA 3.1 IMPROVEMENTS AND BUG FIXES
    Reading data from a Serial port was slow.  The performance has improved.
    Using the Serial Break VI from LabVIEW did not work with remote NI-VISA.
    For a Serial INSTR resource, if a parity or framing error occurred, NI-VISA
    would not return the correct error condition.  This has been fixed.
    The hostname "localhost" or the IP address "127.0.0.1" did not work properly
    with remote NI-VISA.  Only the DHCP name or network IP address would work.
    Calling viEnableEvent on a remote VISA session would leak memory in the
    server.  This has been fixed.
    The remote NI-VISA server did not properly validate a hostname with an
    underscore.  This has been fixed.
    Calling viOpen on a remote NI-VISA resource did not honor the openTimeout
    parameter.  This has been fixed.
    Calling viClose on an ethernet resource would leak a socket handle.  This
    has been fixed.
    The global attributes on a GPIB INTFC resource were not properly shared
    across sessions.  This has been fixed.
    Using the system call "fork" on a process with VISA loaded would sometimes
    cause the forked process to hang.  This has been fixed.
    NI-VISA 3.2 IMPROVEMENTS AND BUG FIXES
    Added complete support for USB (both RAW and INSTR).
    Added a new UNINSTALL script for Linux.  This UNINSTALL script is installed
    in the /usr/local/vxipnp/linux/NIvisa directory.
    Calling viPrintf on a remote VISA session would return VI_ERROR_IO instead
    of VI_ERROR_RSRC_LOCKED when the remote resource was locked.  This is fixed.
    The VISA Interactive Control utility (NIvisaic) now displays an error message
    box when viFindRsrc returns an error.
    CREDITS
    This product includes components that use the socket++ library.  The library
    is Copyright(C) 1992-1995 Greg Lavender (University of Texas) and
    Gnanasekaran Swaminathan (University of Virginia).  All rights reserved.
    KNOWN ISSUES
    If your application crashes or terminates abnormally, NI-VISA cannot always
    clean up properly.  In order to run another VISA application, you should
    first run the application /linux/NIvisa/viclean.  This deletes
    any remaining shared memory segments and system semaphores.
    If you upgrade from NI-VISA 2.5 using the Red Hat Package Manager directly,
    the uninstall script for the old NI-VISA will remove the symbolic links for
    libvisa.so, libcvi.so, NIvisaic, and visaconf from /usr/lib and /usr/bin.
    To get around this problem, either use the new INSTALL script or uninstall
    the previous 'nivisa' and 'nicvirte' packages before installing those
    included in this distribution.
    If you are experiencing problems using the TCPIP SOCKET, TCPIP INSTR, remote
    NI-VISA server, or client in Red Hat Linux version 7.3, you might have
    encountered known issues with TCPIP in kernel version 2.4.18-3.  Please
    upgrade to kernel version 2.4.18-5 or later.  The .rpm file for this update
    may be found at:
    ftp://speakeasy.rpmfind.net/linux/redhat/updates/7.3/en/os
    The GPIB INSTR and GPIB INTFC resources depend on the presence of an NI-488
    driver installed on the system.  For PCI-GPIB and AT-GPIB/TNT products on
    Linux, currently only a Beta version of NI-488 is available.  For GPIB
    ethernet products on Linux, NI-VISA requires NI-488.2 for Linux version 2.2
    or higher.
    For USB resources, there are issues using interrupt-in endpoints. These
    issues vary depending on the version of the Linux kernel and the USB
    controller hardware that is on the system. On 2.4.x kernels, only one
    packet may be requested at a time. Hence, if the value for the attribute
    VI_ATTR_USB_MAX_INTR_SIZE exceeds the maximum packet size of the current
    interrupt-in endpoint, interrupts will not be received. Also, depending
    on the chipset of the USB controller hardware, it is possible for a
    kernel panic (system crash) to occur while attempting an interrupt-in
    transfer. These issues have been fixed in 2.6.x kernels. However, in some
    2.6.x kernels, interrupt-in transfers will not work on EHCI (USB 2.0)
    controllers with USB 2.0 devices.
    GMT+8, 2025-7-20 18:18
