查看: 2754|回复: 0
[NI驱动程序] NI-VISA2.5 Linux 美国国家仪器虚拟仪器软件架构VISA2.5Linux版下载
    8 小时前
  • 签到天数: 3599 天
    连续签到: 7 天
    发表于 2020-3-3 11:06:03 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-VISA2.5
    链接:请注册视觉论坛会员登录后购买附件下载查看
    提取码:请购买附件下载查看
    NI-VISA2.5
    请购买附件下载查看
    Install
    请购买附件下载查看
    VISA2.5Linux.txt (696 Bytes, 下载次数: 1, 售价: 10 元)
    NI-VISA(TM) Software for LINUX.  Version 2.5.
    Copyright (c) 1995-2000 National Instruments Corporation. All rights reserved.
    CONTENTS OF THIS FILE
    Installation From the Internet
    LabWindows(TM)/CVI Run-Time Engine
    Support for VISA 2.5 Features
    VISA Support for Multiple GPIB-VXI Controllers
    Using viPeekXX/viPokeXX Macros
    Improvements and Bug Fixes
    INSTALLATION FROM THE INTERNET
    You should be logged in as 'root' to perform this installation.
    1) Download the installation script file "INSTALL" and the compressed tar
       file "NICVISA_.TZ" from the ftp site into a temporary directory.
    2) Type ./INSTALL to execute the install script, and follow the instructions
       as prompted.
    3) Add the following environment variables to your shell setup file as shown
       in the following example for csh. The following commands assume that
       you installed NI-VISA into /usr/local/vxipnp:
       setenv VXIPNPPATH    /usr/local/vxipnp
       setenv LIBRARY_PATH  /usr/local/vxipnp/linux/bin
    Note:  If your setup file already contains the LIBRARY_PATH environment
           variable, you need to append /usr/local/vxipnp/linux/bin to the end of
           the statement. The required commands may vary from those shown in the
           previous section if you are not using csh.
    LABWINDOWS/CVI RUN-TIME ENGINE
    The Setup program now automatically installs the LabWindows/CVI Run-Time
    Engine when necessary. The NI-VISA interactive utility, VISAIC, requires the
    LabWindows/CVI Run-Time Engine 5.01 or later to be installed. When you
    install this utility, Setup also installs the LabWindows/CVI Run-Time Engine
    if it is not already present.
    SUPPORT FOR VISA 2.5 FEATURES
    The Adobe Acrobat manuals describe the new features of NI-VISA 2.5, but they
    are briefly listed here for your convenience.  They are installed in
    /linux/NIvisa/Manuals.
    The VXI and GPIB functionality in NI-VISA 2.5 has been greatly expanded.
    There is a new VXI BACKPLANE resource for each VXI or GPIB-VXI chassis.
    There is a new GPIB INTFC resource for each GPIB board; this provides
    equivalent functionality to the NI-488 board-level functions. The online
    help lists all operations, attributes, and events that each VISA resource
    class supports.
    The best way to explore the new features is to use the VISA Interactive Control
    to open sessions to the new resource types and look at the available operations,
    events, and attributes.
    VISA SUPPORT FOR MULTIPLE GPIB-VXI CONTROLLERS
    NI-VISA supports multiple GPIB-VXI controllers in a single system. Because the
    National Instruments GPIB-VXI controller ships with a primary address of 1,
    NI-VISA automatically searches for any GPIB-VXI controllers at that address.
    If you have changed the primary address (for example, if you added a
    second GPIB-VXI controller to your system, and set the address of the
    second controller to 9), or if you have a GPIB-VXI controller from another
    vendor, then you need to use the VISA configuration utility so NI-VISA
    can find it.  This application is located at /linux/NIvisa/visaconf.
    While in the Resource Editor, click the 'Add' button to add a new resource.
    Specify a valid resource name for the new controller, such as
    GPIB-VXI2::0::INSTR.  You will then be prompted for the GPIB board number and
    the GPIB-VXI's primary and secondary addresses.  For most users, the only
    number that will change (from the default selections) is the primary address
    (for the above example, you would change it to 9).  Click 'OK' to add this
    new resource, and then select the File|Save menu option to save this
    information to the NI-VISA database.
    If you are using a GPIB-VXI command module from another vendor, you also need
    to obtain and install that vendor's VISA GPIB-VXI component.
    USING viPeekXX/viPokeXX MACROS
    Users who want to use the viPeekXX/viPokeXX macros for platforms on which the
    macros are available must define a macro called NIVISA_PEEKPOKE before including
    "visa.h".  Please note that the macros are currently available only on the
    following platforms:
    - Win32 (All C compilers)
    - Solaris (LabWindows/CVI only)
    If you have used these macros with a version of NI-VISA prior to 2.0, your
    application will continue to run, but the peek/poke performance will decrease.
    You should relink with the libraries supplied with this installation to regain
    the prior peek/poke performance.
    IMPROVEMENTS AND BUG FIXES
    GPIB and Serial performance have been improved over Version 2.01.
    If you are using the GPIB-ENET controller, the previous version of NI-VISA
    would take a minute or more to time out if a GPIB-ENET controller were not
    connected or powered on. The timeout is now much shorter.
    This version of NI-VISA incorporates general bug fixes and improvements for
    GPIB-VXI. The NI-VISA code instrument will now load properly in configurations
    where it previously failed.
    If a GPIB-VXI chassis is reset while an application has VISA loaded, the
    GPIB-VXI would previously become accessible only as GPIB but not GPIB-VXI.
    This release of NI-VISA will now properly re-detect the GPIB-VXI.
    Fixed bug with the GPIB-VXI and hardware triggers.
    formatted I/O, especially with very large buffers and with the following
    modifiers: "%b", ",", "#", "!ob", "!ol", and "%[".
    The documentation for viPrintf and viFlush better describes when formatted
    I/O buffers are sent. The documentation for viScanf better describes the ","
    and "#" modifiers.
    Fixed bug with the Serial End Last Bit mode for reads and writes.
    IMPORTANT NOTES
    If your application crashes or terminates abnormally, NI-VISA cannot always
    clean up properly.  In order to run another VISA application, you should
    first run the application /linux/NIvisa/viclean.  This deletes
    any remaining shared memory segments and system semaphores.
    GMT+8, 2025-7-20 18:12
