查看: 3037|回复: 0
[NI驱动程序] NI-VISA2.0.1 Win32ENG 美国国家仪器虚拟仪器软件架构VISA2.0.1Windows版下载
    8 小时前
  • 签到天数: 3599 天
    连续签到: 7 天
    发表于 2020-3-2 23:15:16 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-VISA2.0.1完整版:
    链接:请注册视觉论坛会员登录后购买附件下载查看
    提取码:请购买附件下载查看
    NI-VISA4.2完整版:
    请购买附件下载查看
    VISA2.0.1Win.txt (651 Bytes, 下载次数: 0, 售价: 10 元)
    There are three files in this directory:
    00readme.txt -- file containing update information and errata
    ReadmeFirst.pdf -- Adobe Acrobat file containing Read Me First Manual
    visa201.exe -- Self-extracting archive containing the VISA 2.01 driver and manuals
    NI-VISA(TM) Software for Windows NT/98/95 Version 2.01
    Copyright (c) 1995-1999 National Instruments Corporation. All rights reserved.
    We appreciate communicating with the people who use our products. We are
    also very interested in hearing about the applications you develop using our
    products. To make it easy for you to communicate with us, our manuals have a
    "Customer Communication" appendix that contains comment and configuration
    forms for you to complete. Completing these forms before contacting National
    Instruments makes it easier for us to help you.
    The "Where Do I Start?" section of the "Read Me First" document contains
    step-by-step instructions for setting up your system.
    WHAT HAPPENED TO MY PXI DEVICES?
    See the section below entitled "Using NI-VISA 2.01 with PXI" for important
    information on PXI-specific changes new in NI-VISA 2.01.
    CONTENTS OF THIS FILE
    LabWindows(TM)/CVI Run-Time Engine
    Uninstalling NI-VISA Software
    Support for VISA 2.01 Features
    VISA Support for Multiple GPIB-VXI Controllers
    Using viPeekXX/viPokeXX Macros
    Improvements and Bug Fixes in This Version
    LABWINDOWS/CVI RUN-TIME ENGINE
    The Setup program now automatically installs the LabWindows/CVI Run-Time
    Engine when necessary. The NI-VISA interactive utility, VISAIC, requires the
    LabWindows/CVI Run-Time Engine 5.01 or later to be installed. When you
    install this utility, Setup also installs the LabWindows/CVI Run-Time Engine
    if it is not already present.
    UNINSTALLING NI-VISA SOFTWARE
    After uninstalling NI-VISA, some DLLs and executables may be left in the
    NI-VISA directories. To complete the uninstall process, you must restart
    your machine. Note: the uninstaller application will not notify you when
    rebooting is necessary. If you're planning to re-install NI-VISA, you should
    always reboot the machine after running the uninstaller.
    SUPPORT FOR VISA 2.01 FEATURES
    The online help describes the new features of VISA 2.01, but they are
    briefly listed here for your convenience.
    You can now use full regular expressions in viFindRsrc, and also limit the
    returned descriptors to a qualifying list of matching attributes.  See the
    online help for more info.
    There are new attributes for Serial that allow XON/XOFF character setting, a
    new value that allows DTR/DSR flow control, and a new value that allows the
    termchar to be added to each buffer written out the serial port.  For GPIB,
    you can query the state of the REN line.
    There is a new event for exception handling, using the standard VISA event
    mechanism for callbacks.  This allows you to use the C longjmp function
    and/or C++ exceptions from your handler, for easier error handling in your
    app.
    There are new operations specifically for GPIB (remote/local control) and
    VXI (miscellaneous Word Serial commands/queries).
    Finally, the formatted I/O operations have been extended to allow formatting
    to/from arbitrary buffers rather than directly to/from the device.  This
    allows you to perform the formatting and data transfer in 2 separate steps,
    being able to see the actual data buffer in between.
    VISA SUPPORT FOR MULTIPLE GPIB-VXI CONTROLLERS
    NI-VISA supports multiple GPIB-VXI controllers in a single system. Because
    the National Instruments GPIB-VXI controller ships with a primary address
    of 1, NI-VISA automatically searches for any GPIB-VXI controllers at that
    address.
    If you have changed the primary address (for example, if you added a second
    GPIB-VXI controller to your system, and set the address of the second
    controller to 9), or if you have a GPIB-VXI controller from another vendor,
    you need to add it using T&M Explorer so that NI-VISA can find it. Select
    the 'Add Device' menu option to add a new GPIB-VXI interface. Specify the
    controller's GPIB primary and secondary addresses, as well as the GPIB board
    to which it is connected.  Then specify a new GPIB-VXI interface number and
    its logical address (usually 0).
    If you are using a GPIB-VXI command module from another vendor, you also
    need to obtain and install that vendor's VISA GPIB-VXI component.
    USING viPeekXX/viPokeXX MACROS
    Users who want to use the viPeekXX/viPokeXX macros for platforms on which
    the macros are available must define a macro called NIVISA_PEEKPOKE before
    including "visa.h".  Please note that the macros are currently available
    only on the following platforms:
    - Win32 (All C compilers)
    - Win16 (Microsoft and Borland C compilers only)
    - Solaris (LabWindows/CVI only)
    If you have used these macros with a version of NI-VISA prior to 2.0, your
    application will continue to run, but the peek/poke performance will
    decrease. You should relink with the libraries supplied with this
    installation to regain the prior peek/poke performance.
    USING NI-VISA WITH PXI
    The Read Me First document contains detailed information describing the use
    of NI-VISA with the PXI interface.  BEGINNING WITH NI-VISA 2.01, PXI DEVICES
    MUST BE REGISTERED BEFORE NI-VISA CAN COMMUNICATE WITH THEM.  Before
    attempting to use NI-VISA with your PXI instrument, consult the Read Me
    First for information on how to configure VISA for use with your device.
    Information not included in the Read Me First document is listed below.
    Using the .INF Files Generated by the PXI Setup Wizard
    In order to configure a PXI device for use with NI-VISA, the PXI Setup
    Wizard is used to gather the information NI-VISA needs in order to
    communicate with the device.  This information is stored in the form of a
    Microsoft Windows Setup Information File (.inf file).  The PXI Setup Wizard
    generates two versions of this file: one for Windows 95/98, and one for
    Windows NT 4.  Before a PXI device will be visible to NI-VISA, the .inf
    files must be used to update the Windows  system registry.  The exact
    procedure for using a .inf file to update the registry is Windows version
    dependent:
    On Windows 95/98, copying the .inf file to the \inf directory and
    rebooting will perform the necessary system update to allow VISA to see the
    device.  Here, the .inf file is used by the OS's Plug&Play manager to
    associate the device with the NI-VISA driver.
    NOTE: In some instances it may be necessary to manually remove the device
    from the Windows Device Manager before rebooting the system.  Specifically,
    if a PXI device is installed and the system booted before the .inf file was
    placed in the \inf directory, Windows 95/98 will mark the device as
    "Unknown" and will not properly associate the VISA driver with it.
    On Windows NT 4, right-clicking on the .inf file and choosing "Install" will
    update the system registry such that VISA can use the device.  The "Install"
    option is equivalent to executing the following from the command line:
    rundll32.exe setupapi,InstallHinfSection DefaultInstall 132
    \prefix_nt4.inf
    In the command line above, "prefix" is the VXIpnp instrument driver prefix
    for your device. Also note that the full path to the .inf file must be
    specified in order for rundll32.exe to execute properly A reboot is required
    before the changes will take affect.
    Creating a PXI Instrument Driver Package with CVI
    National Instruments CVI provides a quick and convenient development
    environment for creating a VXIpnp compliant PXI instrument driver package.
    For a description on how to configure the CVI IDE to create a VXIpnp
    compliant instrument driver, refer to vxipnp.doc, located in \bin,
    ( is the base directory of your CVI installation).
    CVI is also capable of generating a Win32 installation package for your PXI
    instrument driver using the "Create Distribution Kit" option (located off
    the project "Build" menu).  The "Create Distribution Kit" menu lists several
    options for customizing an instrument driver installation.  For VISA-based
    PXI instrument drivers, the following additional steps are necessary for
    creating the distribution:
    1)  Generate the two .inf files for your instrument using the PXI Setup
    Wizard.  The PXI Setup Wizard is external to CVI (go to
    Start>>Programs>>VXIpnp>>PXI Driver Development Wizard).  The Wizard will
    generate file names of the form prefix_os, where "prefix" is the VXIpnp
    compliant instrument prefix for your driver, and the "os" is one of either
    "9x" (for Windows 95/98) or "nt4" (for Windows NT4).  Maintaining these
    exact file names is important when using CVI to generate a distribution kit.
    2)  From the "Create Distribution Kit" CVI window, choose "Add Group" to
    create a new file grouping for the PXI .inf files.  When asked for the name
    of the group, enter "PXI Setup Files".
    3)  A dialog box will prompt you for the files to be added to the "PXI Setup
    Files" group.  Add the .inf files generated by the PXI Setup Wizard by
    locating the .inf files, highlighting them, and choosing "Add".
    4)  Verify that the Group Destination for the "PXI Setup Files" group is the
    "Application Directory".  Also make sure that the Relative Path is not
    enabled.
    5)  Choose "Build" to create the distribution kit.
    CVI will generate an installation file (setup.exe) for your driver.  When
    this file is run on a target machine, the installation script will take care
    of the extra steps necessary to register the device with NI-VISA.
    IMPROVEMENTS AND BUG FIXES IN THIS VERSION
    Fixed various problems with advanced formatted I/O modifiers such as "%5lf",
    "%,5f", and "%100hb".
    Fixed conditions in viPrintf where it would not return an error if one
    occurred.
    Corrected a 4 Kbyte memory leak for every session using formatted I/O.
    Default termination character for VXI is now correctly set to '\n'.
    Improved asynchronous performance in NI-VISA by adding configuration option
    in T&M Explorer to specify minimum asynchronous transfer size.
    The previous version of NI-VISA had errors in the type library, causing
    problems in Visual Basic with viRead, viClose, viInstallHandler, and  the
    Online Help.
    NI Spy and T&M Explorer now operate properly for users without adminstrative
    privileges under Windows NT machines.
    Corrected a memory leak in NI Spy when using file logging.
    Corrected problems where NI Spy displayed incorrect data or crashed on
    certain 'Output' or 'Buffer' pages.
    Opening a Spy file while a property page is open no longer causes NI Spy to
    crash.
    Duplicate copies of NI Spy are no longer created when installating NI-VISA
    on top of NI-488.2 GPIB software.
    NI-VISA now properly handles GPIB-VXIs at primary addresses other than 1.
    Fixed a problem with recognizing register-based devices at certain VXI
    logical addresses in a GPIB-VXI system.
    When serial attributes were changed using viSetAttribute, RTS and DTR lines
    were not left in the expected state.
    viWrite over parallel ports is now fixed.
    After calling viDisableEvent in a GPIB system on Windows 95, making further
    GPIB calls might have incorrectly reported an error.
    The installer would update the PATH environment variable incorrectly on some
    Windows 95 systems.
    T&M Explorer now checks user input on baud rate selection for the serial
    port.
    Fixed a problem where PXI devices were only visible on PCI bus 0.
    Corrected a memory leak for sessions using PXI.
    When opening a session to a PXI instrument that did not exist, all
    subsequent viOpen() calls in that process would fail.
    GMT+8, 2025-7-20 18:37
