查看: 4241|回复: 0
[NI驱动程序] NI-488.2Driver18.5.0f1 Windows/Real-Time Full and Run-time 美国国家仪器IEEE488.2仪器驱动18.5.0f1 Windows/实时系统完整版及运行时下载
    4 小时前
  • 签到天数: 3808 天
    发表于 2020-3-1 17:54:27 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-488.2为使用NI GPIB控制器和带有GPIB端口的NI嵌入式控制器的客户提供支持。
    NI-488.2仪器驱动程序包含了几个实用程序,用于应用程序开发和调试。NI-488.2包含了可自动处理所有总线管理的高级命令,因而用户就无需了解GPIB硬件产品或IEEE 488.2协议的编程细节。为了提供最大灵活性和功能,NI-488.2还包含了底层命令。
    完整版:
    链接:请注册视觉论坛会员登录后购买附件下载查看
    提取码:请购买附件下载查看
    运行时:
    提取码:请购买附件下载查看
    完整版:
    请购买附件下载查看
    运行时:
    请购买附件下载查看
    488.2 18.5.0F1Win.txt (832 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-488.2 for Windows 18.5 Readme
    September 2018
    This file contains important information about NI-488.2, including installation instructions, new features, and a partial list of bugs fixed for NI-488.2.
    This readme contains the following main sections:
    Enhancements and Bug Fixes
    • Version 18.5
    • Version 17.6
    • Version 17.0
    • Version 16.0
    • Version 15.5
    • Version 15.0
    • Version 14.0
    NI-488.2 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Known Compatibility Issues with Windows 8
    NI-488.2 has known compatibility issues with the Fast Startup feature introduced in Windows 8. Leaving Fast Startup enabled can cause GPIB hardware and NI-488.2 driver software to function improperly. To prevent problems with installing or removing hardware, National Instruments recommends disabling Fast Startup. The NI-488.2 for Windows, Version 15.5 installer disables Fast Startup by default. For more information about this issue, visit ni.com/info and enter the Info Code Win8FastStartup.
    Known Driver Issues with Windows Upgrade
    Upgrading Windows on a system with NI-488.2 already installed renders DOS Support unusable. To fix this issue, run installation repair. If the driver cannot attach to GPIB hardware, run installation repair a second time.
    Win16 and DOS Support
    Win16 and DOS support are available on 32-bit Windows operating systems.
    The following table lists the application software versions, including service packs, that NI-488.2 supports. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by Product
    NI-VISA18.51
    LabVIEW2015, 2016, 2017, 2018
    LabVIEW NXG3.0
    LabWindows™/CVI™2012, 2013, 2015, 2017
    Measurement Studio2012, 2013, 2015
    1 Any version of NI-VISA prior to 5.1 on your system may cause NI-488.2 usability issues. Upgrade to NI-VISA version 5.1 or later before using any NI-488.2 devices.
    Note:  NI I/O Trace 17.0 and later support NI-488.2 17.0. Previous versions of NI I/O Trace do not support NI-488.2 17.0 or later.
    If you are using the NI-488.2 .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-488.2 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    Microsoft Visual Basic 6.0 Support
    NI-488.2 supports 32-bit Visual Basic 6.0 application development. For more information, refer to the Language-Specific Programming Instructions topic in the NI-488.2 Help.
    Unmanaged C/C++ Support
    NI-488.2 supports 32-bit and 64-bit GPIB applications using Microsoft Visual C++ 2005 and later. Microsoft Visual C/C++ 6.0 and Microsoft Visual Studio .NET 2003 only support 32-bit GPIB applications. For more information, refer to the Language-Specific Programming Instructions topic in the NI-488.2 Help.
    The following list contains the NI hardware supported by NI-488.2 on Windows:
    • GPIB-ENET/1000
    • GPIB-USB-HS
    • GPIB-USB-HS+
    • NI ExpressCard-GPIB1
    • NI PCIe-GPIB
    • NI PCIe-GPIB+
    • NI PCI-GPIB
    • NI PCI-GPIB+
    • NI PCI-GPIB/LP
    • NI PCI-8232
    • NI PMC-GPIB
    • NI PXI-GPIB
    • NI PXI-8232
    1 This hardware is end-of-life and not recommended for new designs.
    Installation InstructionsInstalling NI-488.2 for LabVIEW
    You can install all of your LabVIEW products—including NI-488.2—using the LabVIEW Platform media.
    Note
    • If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/info and enter the Info Code exjq43 for more information and steps to resolve this issue.
    Installing NI-488.2 for LabVIEW NXG
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in NI-488.2.
    Enhancements and Bug Fixes in Version 18.5The Following Issues Were Resolved in NI-488.2 18.5
    373478: In a multicontroller application, all controllers used in the application would report EPWR error if one of the controllers lost power resulting in an EPWR error.
    568289: Removing GPIB USB controllers from the system while saving configuration in MAX resulted the GPIB USB controllers not being removed in MAX.
    Enhancements and Bug Fixes in Version 17.6The Following Issues Were Resolved in NI-488.2 17.6
    670170: A hang might occur during an I/O operation if a Service Request is stuck when Autopolling is happening.
    647895: As a result of an issue introduced in a previous version of NI-488.2, ibnotify for a Service Request may cause a hang when the service request event occurs.
    Enhancements and Bug Fixes in Version 17.0
    Support for HLK signing for Windows 10.
    Support for Borland C dropped.
    Enhancements and Bug Fixes in Version 16.0
    The following issues were resolved in NI-488.2 16.0
    582112: In rare cases, connecting a GPIB-USB-HS+ interface to a system could cause the computer to crash.
    569142: Installer indicates that NI I/O Trace is required for NI-488.2.
    Enhancements and Bug Fixes in Version 15.5
    The Following Issues Were Resolved in NI-488.2 15.5
    433395: Extra delay on ibwait and ibstop was removed for GPIB Ethernet-based hardware.
    538997: An NI4882 API call in a multithreaded or multiprocess application results in an unexpected error due to unprotected API calls when opening a device handle.
    542306: When an application exits while there is asynchronous IO pending on ENET interfaces, the application crashes.
    557236: GPIB Analyzer crashes when exporting a large capture to a text file.
    Enhancements and Bug Fixes in Version 15.0
    Updated Experience in NI-MAX
    The configuration experience in Measurement & Automation Explorer (MAX) has been updated to improve consistency with other NI products. Significant changes include:
    • GPIB properties have been moved to the Settings page for GPIB interfaces.
    • It is no longer necessary to run MAX as Administrator to change GPIB settings.
    • Reset and Self-Test features are now available for all GPIB interfaces from within MAX.
    • NI-488.2 DOS Support is no longer configurable through MAX; DOS Support is enabled by default on all compatible systems. Refer to the NI-488.2 documentation for instructions to manually disable NI-488.2 DOS Support.
    • Scan for Instruments no longer displays instruments at the bottom of the properties page, which has been removed. Discovered instruments only appear in the Devices & Interfaces tree beneath the GPIB interface.
    • GPIB-ENET/100 and GPIB-ENET/1000 interfaces now display additional information such as IP address and serial number.
    • Performance of MAX has been improved during startup and when expanding Devices & Interfaces tree.
    • GPIB-ENET/100 and GPIB-ENET/1000 interfaces which cannot be reached are marked as unavailable; some operations are disabled while they are offline. (386556)
    • Windows display language can now be changed without adverse affecting GPIB labels as they appear in MAX. (428596)
    • MAX now displays network info for GPIB-ENET/1000 interface that is configured with .local address. (409559)
    Web Configuration
    GPIB interfaces are now fully configurable through the NI Web Configuration interface. Self-Test has also been added.
    Removed Troubleshooting Utility
    The NI-488.2 Troubleshooting Utility has been removed. GPIB interfaces may be tested using the Self-Test feature in Measurement & Automation Explorer, or programmatically through the System Configuration API.
    Improved Behavior When USB Transaction Errors Occur
    506688: The NI-488.2 driver is unable to recover from certain types of USB errors. These errors may occur on some systems when other USB devices are added or removed from the system while a GPIB operation is in progress. In prior versions of NI-488.2, this could lead to a hang in the process using a USB-to-GPIB interface. It could also result in a hang or blue screen error on system shutdown. This scenario now results in an EDVR error when an unrecoverable USB error occurs. To restore operation, the USB connection to the GPIB interface should be removed and reinserted, and the GPIB handle should be closed and re-opened.
    The Following Issues Were Resolved in NI-488.2 15.0
    518983: As a result of an issue introduced in NI-488.2 14.0, GPIB-USB-B or GPIB-USB-HS I/O bus communication can hang until the handle to the GPIB interface is closed when all of the following conditions are true:
    • The affected interface is not CIC (Controller in Charge)
    • A read or write is in progress
    • An ibwait including the DCAS bit is in progress
    • A device clear is received during the I/O transfer
    507376: Installer hang might occur during installation of NI software on systems with NI-488.2 14.0 already installed.
    478063: GPIB-USB-HS+ might become unresponsive upon rebooting in a virtual machine.
    121091: Calling ibonl when a board level ibwait is in progress could result in application crash.
    121181: A deadlock might occur when attempting to use a board handle with pending ibonl call on another thread.
    476357: GPIB Ethernet Wizard can incorrectly add GPIB-ENET/1000 with hostname even if it is not reachable.
    476487: GPIB Ethernet Wizard icon does not appear on Windows task bar.
    Enhancements and Bug Fixes in Version 14.0
    New Hardware Support
    This release adds support for the GPIB-USB-HS+ GPIB controller and Analyzer. Along with this, the NI GPIB Analyzer utility has undergone changes to allow it to work with the new analyzer hardware. The NI GPIB Analyzer utility allows simultaneous use of multiple GPIB-USB-HS+ analyzers, along with up to one non-USB GPIB analyzer.
    Windows Server Support
    This release adds support for Windows Server 2012 R2. Refer to the Supported Hardware section for the list of supported hardware.
    API Integer Type Changes
    The integer types used in the NI4882 API (ni4882.h) have been updated. All uses of unsigned long have been replaced with unsigned int. These types are functionally identical with all supported compilers, and this change improves the portability of 64-bit GPIB applications to other platforms. Users of ibnotify will need to update the function prototypes for callback functions. In most other cases applications will compile cleanly. This change is fully binary-compatible with applications built against previous versions of NI-488.2 and does not impact users of the GPIB-32 API (ni488.h).
    Runtime Installer
    NI-488.2 for Windows is now available in a smaller Runtime form. The NI-488.2 Runtime is a minimal installation which does not include many of the utilities and supporting software included with the full NI-488.2 distribution. When building installers from LabVIEW or other NI development environments, you will now have the option of including this smaller subset of NI-488.2 in your distribution.
    The Following Issues Were Resolved in NI-488.2 14.0
    319093: Attempting to bring a non-existent device online after setting the IbcSendLLO board configuration option causes an ENOL error instead of EBUS. This problem impacted all USB based GPIB interfaces. This has been fixed.
    122997: The EOIP status bit could remain set incorrectly if an ibwrta or ibrda call returned an EDVR error.
    171688: An ibnotify callback could fail to be triggered by END if the notify condition included END but not CMPL.
    205182: Asynchronous transfers could sometimes report EABO even though the transfer completed successfully.
    372832: A callback from ibnotify might not be invoked after an asynchronous transfer was completed if the notify mask only contained END.
    374822: Calling ibonl while ibnotify is pending could cause the process to crash under some circumstances.
    380705: Aborting an ibrda very quickly after starting it could allow a PCI-based GPIB interface to receive data when addressed as a listener, without a read in progress. This data was lost, and could not be recovered.
    404267: In some situations, the GPIB-ENET/1000 could hang while performing asynchronous transfers. This included fixes in both the NI-488.2 driver and the GPIB-ENET/1000 firmware. Users of the GPIB-ENET/1000 should update the GPIB-ENET/1000 firmware to version 1.1.0 to receive the full benefit of this fix.
    405414: In some cases the DCAS bit was not correctly cleared after being reported, causing it to be reported with subsequent calls.
    418661: In some situations, when an ibnotify callback function was triggered due to the completion of an asynchronous transfer, the ibcnt and ibcntl variables would be incorrect.
    425931: Calling ibstop with an asynchronous operation in progress would sometimes not report an EABO error as expected.
    464114: When using a GPIB-USB-B controller, the call immediately following an ibstop call could be incorrectly aborted.
    463966: Severe performance degradation when performing large writes to GPIB-USB-HS hardware through USB 3.0 ports on Windows 7.
    332479: On GPIB-USB-B and GPIB-USB-HS controllers, the first I/O operation after device insertion could be terminated prematurely.
    240000: On GPIB-USB-B and GPIB-USB-HS controllers, ibwait and ibnotify could fail to detect the CIC, LACS, and TACS bits.
    191044: The GPIB Analyzer did not automatically append the correct file extension when saving a capture.
    87073: The GPIB Analyzer did not prompt to save if the application is closed while capturing data.
    Refer to the NI-488.2 Help, accessible by selecting National Instruments»NI-488.2»GPIB Help from the Windows menu bar.
    The following sections detail considerations for using LabVIEW NXG with NI-488.2.
    LabVIEW NXG Hardware Support
    Support differs for the following devices in LabVIEW NXG:
    • GPIB-ENET/1000 must be manually added to your system.
      • To discover the GPIB-ENET/1000 on the local subnet, use LabVIEW NXG's Add Hardware to discover and then add it to your system.
      • To add the GPIB-ENET/1000 using its IP Address or Hostname, use LabVIEW NXG's Add hardware by address.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    © 1995–2018 National Instruments. All rights reserved.
    375742F-01
    NI-488.2 for LabVIEW Real-Time, Version 18.5 Readme
    September 2018
    This file contains important information about NI-488.2, including new features and a partial list of bugs fixed for NI-488.2 Version 18.5.
    • Compatible Software
    • Supported Hardware
    • Enhancements and Bug Fixes
      • Version 18.5
      • Version 17.6
      • Version 17.0
      • Version 16.0
      • Version 15.5
      • Version 15.0.1
      • Version 15.0
      • Version 14.0
    • Driver Version Naming Changes
    • Legal Information
    Compatible Software
    This driver version is recommended for use with the following National Instruments software:
    • NI-VISA 18.5
      • Any version of NI-VISA prior to 5.1 on your system may cause NI-488.2 usability issues. Upgrade to NI-VISA version 5.1 or later before using any NI-488.2 devices.
    • LabVIEW 2015, 2016, 2017, and 2018
    NI-488.2 for LabVIEW Real-Time, Version 18.5, supports the following GPIB interfaces:
    • Desktop RT with NI PCI-GPIB
    • Desktop RT with NI PCIe-GPIB
    • NI PXI controller with built-in GPIB
    • NI PMC-GPIB
    • NI PXI-8232
    • NI PXI-GPIB
    Enhancements and Bug Fixes in Version 18.5LabVIEW Real-Time 2018
    NI-488.2 for LabVIEW Real-Time, Version 18.5, adds support for LabVIEW Real-Time 2018.
    Enhancements and Bug Fixes in Version 17.6The following issues were resolved in NI-488.2 17.6
    Enhancements and Bug Fixes in Version 17.0LabVIEW Real-Time 2017
    NI-488.2 for LabVIEW Real-Time, Version 17.0, adds support for LabVIEW Real-Time 2017.
    Enhancements and Bug Fixes in Version 16.0LabVIEW Real-Time 2016
    NI-488.2 for LabVIEW Real-Time, Version 16.0, adds support for LabVIEW Real-Time 2016.
    Enhancements and Bug Fixes in Version 15.5The following issues were resolved in NI-488.2 15.5
    Issues resolved in NI-488.2 15.0.1 were ported to the NI-488.2 for LabVIEW Real-Time, Version 15.5 release.
    Enhancements and Bug Fixes in Version 15.0.1The following issues were resolved in NI-488.2 15.0.1
    547340: GPIB ports may not be reported in NI MAX, Web Configuration, and System Configuration API with NI-488.2 15.0.0.
    Enhancements and Bug Fixes in Version 15.0Updated experience in Measurement & Automation Explorer (MAX)
    The configuration experience in MAX has been updated to improve consistency with other NI products. Self-Test has also been added for GPIB interfaces.
    Web configuration
    Enhancements and Bug Fixes in Version 14.0The following issues were resolved in NI-488.2 14.0
    NI-488.2 versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: . The last version released under the old numbering scheme was NI-488.2 3.1.2. The first version released under the new numbering scheme was NI-488.2 14.0.
    375741E-01
    GMT+8, 2026-2-25 14:53
